POV-Ray : Newsgroups : povray.advanced-users : Continuing a render Server Time
15 Jun 2026 14:45:34 EDT (-0400)
  Continuing a render (Message 1 to 3 of 3)
Subject: Continuing a render
Date: 22 Sep 2005 14:23:01
Message: <4332f685@news.povray.org>
Today I tried to continue a render using the +C flag. Much to be
interest, it spent 3 minutes computing the photon maps for each and
every frame - only to notice that the frame has already been rendered.
(I wonder if a similar thing happens with frames that take an
excessively long time to parse as well?)
I can see why this happens, but... would it be hard to fix?
Subject: Re: Continuing a render
Date: 4 Oct 2005 06:34:53
Message: <43425acd$1@news.povray.org>
The problem IMO is, that povray first parses the scene file before
looking if the output file exists.
Maybe you could check for the frame file in first place and enable
photons only if the file doesn't exist, something like
#if (MACRO_TO_CHECK_IF_FILE_EXIST("file_of_interest"))
   #declare PHOTONS = off;
#else
   #declare PHOTONS = on;
#end // if else
Problem would be that for the frame rendered half way befor interuption
povray wouldn'd use photons for this particular frame.
Easier is to look which frames allready are rendered and start povray
with +C and the subset frame parameters +SF and maybe +EF
(docs: 3.1.2.1.3 Subsets of Animation Frames)
... dave
Date: 15 Oct 2005 12:50:52
Message: <4351336c$1@news.povray.org>
Indeed.
So I found...
