POV-Ray : Newsgroups : povray.advanced-users : Raising contrast inside POV-Ray? Server Time
11 Jan 2025 04:51:55 EST (-0500)
  Raising contrast inside POV-Ray? (Message 1 to 10 of 15)
Subject: Raising contrast inside POV-Ray?
Date: 30 Aug 2005 20:41:54
Message: <4314fcd2@news.povray.org>
Some of you might have seen my current WIP, the image currently entitled
"Windows". I make excessive use of radiosity in that image to get a soft,
realistic lighting.
Anyways, I've fiddled with some of the images in Paint Shop Pro and noticed
that some higher contrast does a lot for the image. I'm a sucker for doing
things right inside POV-Ray, so does anyone have ideas or techniques on how
to raise the contrast inside POV-Ray?
My main trouble lies within the radiosity itself, though smooth enough, I'd
like darker shadows, but simply lowering brightness will also turn the
bright areas darker.
Anyways, suggestions or techniques (using the current "standard" POV-Ray,
not some patch-version) are welcome. :-)
Tim
"Tim Nikias v2.0"
Subject: Re: Raising contrast inside POV-Ray?
Date: 30 Aug 2005 23:20:01
Message: <431521e1$1@news.povray.org>
POV-Ray 3.7 may include such a feature eventually.  But detils are still to
be determined.
	Thorsten
Date: 31 Aug 2005 00:38:37
Message: <4315344d$1@news.povray.org>
Your WIP is fine, but I would raise assumed_gamma above 1.
Personally, after 5 years of using a gammavalue of 1 I now use 2.2 together
with a brightness of 2.5.
In connection with my flat panel monitors this is a convincing solution for
contrast problems I had too.
Regards
Norbert Kern
"Tim Nikias" <JUSTTHELOWERCASE:timISNOTnikias(at)gmx.netWARE> schrieb im
Newsbeitrag news:4314fcd2@news.povray.org...
> realistic lighting.
> noticed
> how
> I'd
> Regards,
> Tim
> "Tim Nikias v2.0"
> Homepage: <http://www.nolights.de>
Date: 31 Aug 2005 00:48:54
Message: <431536b6@news.povray.org>
  Traditionally people have adjusted contrast as a post-processing step
with a third-party image manipulation program.
  However, I have always wondered if it couldn't be possible to do it
from within povray itself by adjustin assumed_gamma and the brightness
of light sources...
Date: 31 Aug 2005 02:13:13
Message: <43154a79@news.povray.org>
scenes/textures/pigments/transmitfx.pov ?
Rune
rune|vision:  http://runevision.com
POV-Ray Ring: http://webring.povray.co.uk
Date: 31 Aug 2005 03:05:47
Message: <431556cb$1@news.povray.org>
raise light source brightness and adjust material properties accordingly
and you will get higher contrast radiosity results.  A washed-out
appearance is often a result of using unrealistically low lighting levels.
Obviously you can do that with MegaPOV's post processing patch.  For
simple brightness/contrast adjustments you can also use the tone mapping
patch (see macro Brightness_Contrast() in tone_mapping.inc - much faster
than with the post processing feature).
Note it is of course often more convenient to render to a plain, not
adjusted image and do the post processing afterwards.
Christoph Hormann
http://www.tu-bs.de/~y0013390/
Date: 31 Aug 2005 05:02:37
Message: <4315722d@news.povray.org>
to
> be determined.
Looking forward to it. :-)
"Tim Nikias v2.0"
Date: 31 Aug 2005 05:03:28
Message: <43157260$1@news.povray.org>
together
Might be worth a shot, at least for a quick solution. Thanks for the tip.
"Tim Nikias v2.0"
Date: 31 Aug 2005 05:04:30
Message: <4315729e$1@news.povray.org>
Yeah, I know, but I like it if I can set an image in a window that it
doesn't require post-processing to look like I want it to. :-)
> of light sources...
That's what others suggested as well. I'll have to look into that.
Tim
"Tim Nikias v2.0"
Date: 31 Aug 2005 05:05:02
Message: <431572be@news.povray.org>
Hm. Precise answer. I'll have to find out if I does what I want. Thanks
though! :-)
"Tim Nikias v2.0"
