POV-Ray : Newsgroups : povray.advanced-users : Converting MegaPOV 0.5 to Povray 3.5 Server Time
12 Oct 2025 12:02:21 EDT (-0400)
  Converting MegaPOV 0.5 to Povray 3.5 (Message 1 to 6 of 6)
Subject: Converting MegaPOV 0.5 to Povray 3.5
Date: 15 Jun 2005 18:41:51
Message: <42B0AE2F.2010005@yahoo.com>
Hello,
I'm trying to convert to POVray 3.5 an Ant model made Micha Riser for
MegaPOV 0.5 (found http://objects.povworld.org/).
When I trace the example file, I got the following error
Parsing.....................File: ant.inc  Line: 122
sphere_sweep{
	catmull_rom_spline_sphere_sweep
<----ERROR
Parse Error: Invalid type of interpolation.
and the corresponding source file is :
union{
sphere_sweep{
		#declare rscale=0.4;
		6
		0,0.275*rscale
		0,0.25*rscale
		<-.2,0,1>,.22*rscale
		<-.3,0.15,2.8>,.3*rscale
		<0,0.3,4.8>,.35*rscale
		rotate y*90
		rotate z*90
There is another 'sphere_sweep' later :
sphere_sweep{
	linear_sphere_sweep
	21
	0,0.25
	#while(ss_anz<10)
and pov complain about linear_sphere_sweep.
So my question is obvious : how can I convert these bit of code to
something understandable by POVRay ?
Thanks & regards,
Laurent
Subject: Re: Converting MegaPOV 0.5 to Povray 3.5
Date: 15 Jun 2005 19:46:03
Message: <38BuABAL2LsCFwnT@econym.demon.co.uk>
Wasn't it destroyedlolo who wrote:
>Hello,
Use "cubic_spline" and "linear_spline" instead of
"catmull_rom_spline_sphere_sweep" and "linear_spline_sphere_sweep".
Mike Williams
Gentleman of Leisure
Date: 16 Jun 2005 18:13:44
Message: <42B1F917.90508@yahoo.com>
>>Hello,
Unfortunately, I got many errors :
.File: ant.inc  Line: 171
Warning: Should have at least 2 objects in csg.
File: ant_example_scene.pov  Line: 68
Warning: Unnecessary bounding object removed.
I will install MegaPov, anyway, thanks for your reply.
Laurent
Date: 16 Jun 2005 20:09:00
Message: <42b2149c$1@news.povray.org>
destroyedlolo nous apporta ses lumieres en ce 2005-06-16 18:11:
>>> Hello,
Probably an union with only one component, you may change "union" for "object"
The file contains some manual bounding "object" that are not needed. Remove any
"bounded_by..." you
can find.
> Laurent
Date: 16 Jun 2005 22:32:52
Message: <4l292AAU5isCFwWl@econym.demon.co.uk>
>>>Hello,
I believe you'll get those same warnings with MegaPOV. Warning messages
don't stop the image rendering, they just notify you of things that the
program suspects might be badly written.
Mike Williams
Date: 17 Jun 2005 17:42:42
Message: <42B34352.5060806@yahoo.com>
Yes, you're right : so I remove offending lines and now the test scene
compute succesfully w/o warning using POV 3.5 on my SUN workstation.
The result is very pretty and ants are very realistics.
A big "thank you" for Alain & you for your help, and obviously for Micha
for he original code.
Bye
Laurent
PS: I'll make some cleaning and I will upload this new version to
