POV-Ray : Newsgroups : povray.advanced-users : ?: Server Time
11 Jan 2025 04:52:52 EST (-0500)
  ?: (Message 1 to 6 of 6)
Subject: ?:
Date: 24 Feb 2005 16:35:11
Message: <421e488f$1@news.povray.org>
It appears that A?B:C doesn't work inside functions - but select() does.
Is this documented somewhere? (I presume this is the reason that both
constructs exist in the first place...?)
Subject: Re: ?:
Date: 24 Feb 2005 18:04:28
Message: <421e5d7b@news.povray.org>
  Well, is the ?: operator listed as valid operator in user-defined
functions?
  While it might not be very clear from the documentation (it should
perhaps be), the SDL and the user-defined functions are basically two
completely different and independent languages. They somewhat resemble
each other, but the user-defined functions are basically a language
inside the SDL, not SDL itself. They are even interpreted at
completely different levels. For this reason not everything that
works in the SDL works in the user-defined functions.
  You can create the body of a user-defined function using SDL, but
that's just kind of user-defined function metaprogramming, that is,
a program (in a different language) which creates a program (in the
other language).
Subject: Re: ?:
Date: 25 Feb 2005 04:20:31
Message: <qoqt11l2o96i0tc6uls8dfmn58glungs2q@4ax.com>
On Thu, 24 Feb 2005 21:33:37 +0000, Andrew the Orchid <voi### [at] devnull> wrote:
http://www.povray.org/documentation/view/3.6.1/506/
A?B:C is part of FULL_EXPRESSION which is part of NUMERIC_EXPRESSION
If you would compare it with:
http://www.povray.org/documentation/view/3.6.1/509/
none of the is part of USER_FUNCTION specs.
ABX
Subject: Re: ?:
Date: 28 Feb 2005 16:15:20
Message: <422389e8$1@news.povray.org>
Ouch... man, I shouldn't have asked! :-/
Subject: Re: ?:
Date: 28 Feb 2005 16:24:46
Message: <42238c1e$1@news.povray.org>
> other language).
Yeah - directives execute at parse time, functions execute at runtime.
I think in this case it's more a question of it not being immediately
obviouse that one construct belongs to one set, and the other belongs to
another... (I only checked the function reference)
Subject: Re: ?:
Date: 1 Mar 2005 05:41:02
Message: <422446be@news.povray.org>
  Functions can be used at parse time as well, but it's a completely
different engine which runs them (the SDL parser just calls this
function VM).
