POV-Ray : Newsgroups : povray.advanced-users : Bounding box test stats : how to interpret ? Server Time
9 Feb 2026 05:13:57 EST (-0500)
  Bounding box test stats : how to interpret ? (Message 1 to 2 of 2)
Subject: Bounding box test stats : how to interpret ?
Date: 7 Jan 2005 18:11:22
Message: <41df171a$1@news.povray.org>
The rendering of my not so fancy scene (100K object, a dozen meshes, one
light, one infinite object, no photon, no radiosity, few and small glass
objects,...), I get Bounding box tests = 80% of Light Buffer tests AND a
very low success ratio of 0.07% !!!!
Are these values typical ?
Is it legitimate to say that  automatic bounding is not very efficient in
this case ? 80% of all the tests necessary for the redering are made on the
hierarchy of bounding boxes with a miserable success ratio !
My few tries with manual bounding the CSG (few differences and many unions)
are not very encouraging. Should I insist ?
Subject: Re: Bounding box test stats : how to interpret ?
Date: 8 Jan 2005 00:35:39
Message: <EgwiXFAhE33BFw1k@econym.demon.co.uk>
Usually, a very low success rate for bounding box tests is very good
news. It means that you've managed to massively reduce the number of ray
tests on your actual object at the expense of a large number of quick
slab tests. If your objects are complicated, ray tests on your objects
might be considerably slower than slab tests. A success rate of 0.07%
suggests that your objects only occupy a tiny area of the image.
Mike Williams
Gentleman of Leisure
