POV-Ray : Newsgroups : povray.advanced-users : POVRay and XML Server Time
9 Feb 2026 05:13:58 EST (-0500)
  POVRay and XML (Message 1 to 10 of 107)
Subject: POVRay and XML
Date: 31 Dec 2004 04:02:16
Message: <41d51598@news.povray.org>
Hi!
I just thought if it might be possible to use XML to describe a scene.
In my opinion, this would have a lot of advantages: Namespaces, ability
to transform whole scenes using XSLT and the ability to retrieve data
from POVXML-files and use them somewhere else.
It wouldn't pose AFAIK any problem to write a XSLT-script that would
transform an XML-document to POVRay file format. Obviously this works
only in one direction. It is, however some work to do so since all
POVRay features would have to be mapped to XML.
I'd like to know if there is already such a system planned or implemented.
If not: Is anyone except me interested in implementing such a system?
What do you think about this idea?
Thanks in advance
Bernd Fuhrmann
Subject: Re: POVRay and XML
Date: 31 Dec 2004 04:25:02
Message: <cr35li$26h$1@chho.imagico.de>
Bernd Fuhrmann wrote:
> Hi!
In short: nothing prevents you from doing so (at least theoretically)
but you should bear in mind the following thing: no one sane who uses
POV-Ray for serious work will write a scene in XML or use XML to store
scene data.  If you have trouble imagining why this is the case just
have a look at Yafray.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 31 Dec 2004 04:53:09
Message: <41d52185$1@news.povray.org>
I just had a look at it. Yafray seems to support only meshes. This is
certainly not a good approach. This will lead to big XML files. XML as
low level language can't be a good idea since processing speed does
matter. But what about a high level XML representation? There wouldn't
be that bad processing speed impacts.
On the other hand: The POVRay file format is not that open to
extensions. There isn't a reasonable naming scheme which would allow to
use codesnippets from all kinds of people in one single project. So for
real big and long-term projects XML would definately be the markup
language of choice.
Bernd Fuhrmann
Date: 31 Dec 2004 05:03:33
Message: <js8at0t1356q5dasacqfgggsk44aqefhhk@4ax.com>
On Fri, 31 Dec 2004 10:02:16 +0100, Bernd Fuhrmann <Sil### [at] gmxde>
As Christoph said.
FYI: http://www.web3d.org/x3d/overview.html
ABX
Date: 31 Dec 2004 05:47:25
Message: <41d52e3c@news.povray.org>
  I really don't see those as advantages.
  No-one will write XML scenes by hand, so what's the point?
Date: 31 Dec 2004 07:12:45
Message: <41d5423d$1@news.povray.org>
Why not? It isn't that difficult. People write XHTML, MathML and even
SVG by hand. At least I do. So why not POVRay? There are a lot of
advantages:
It would be possible to write material libraries, object libraries and
so on without clobbering the global namespace.
It would become possible to access the camera settings to adjust certain
values. This would make the implementation of HUD systems possible
(useful if you want to mark or label certain things in your scene).
One could even convert whole models to meshes and apply mesh
modificators on them. This is AFAIK not yet possible in POVRay.
Ok, maybe some of these things can be done in POVRay file format. But if
they can be done, how clean can they be done?
Bernd Fuhrmann
Date: 31 Dec 2004 07:40:02
Message: <cr3h66$4de$1@chho.imagico.de>
That's not the point.  You can either take my word on it that people
won't do it or ignore the fact - the result will be the same.  The same
ideas are brought up from time to time in these newsgroups -
interestingly usually not by people who use POV-SDL a lot.
You can easily find previous discussions on this matter by searching
these newsgroups, for example:
http://news.povray.org/povray.general/thread/<Xns94B1A5863FF0DZenZenPsychocom%40203.29.75.35>
http://news.povray.org/povray.programming/thread/<38CE3B1A.80B4F27%40nigels.com>
Date: 31 Dec 2004 07:40:15
Message: <s1hat0h78j5s8q34g4e8308c8aubiv6230@4ax.com>
On Fri, 31 Dec 2004 13:12:46 +0100, Bernd Fuhrmann <Sil### [at] gmxde>
You know, there are a few not technical users of POV-Ray. While average
"artist" can easily write and understand sphere{0 r scale x*4 pigment{Red}}
anything more complicated would make understanding harder.
You have material and object libraries nowadays in include files.
Can you point me an example of useful namespace application within POV-Ray
scene from average unskilled user point of view?
> values.
See screens.inc include file solutions.
Head Up Displays you mean? Which application you mean exactly?
? Anything you can't do currently?
That depends what you mean by "convert" and "modificators".
ie. http://www.geocities.com/SiliconValley/Lakes/1434/images/createmesh.jpg
IMO that's not POV-Ray file format but POV-Ray features which makes things
possible.
> But if they can be done, how clean can they be done?
Some prefer question: how hard can they be done. I think writing simple
include file is easier than introducing new parser and changing habits of
large community.
ABX
Date: 31 Dec 2004 07:54:35
Message: <Xns95D08D7F3869Fseed7@news.povray.org>
> POV-Ray scene from average unskilled user point of view?
A problem I ran into several times is using multiple include files, where
in two or more inc's objects are defined with the same name.
Ingo
Date: 31 Dec 2004 07:59:52
Message: <37jat050gpl1jhjhfl290afmkdbivt0f7q@4ax.com>
And usually how hard it is to solve such issue?
ABX
