POV-Ray : Newsgroups : povray.advanced-users : POVRay and XML Server Time
9 Jun 2026 16:40:41 EDT (-0400)
  POVRay and XML (Message 78 to 87 of 107)
Subject: Re: POVRay and XML
Date: 4 Jan 2005 16:52:43
Message: <Xns95D4E8BBB1668seed7@news.povray.org>
in news:41daff5b$1@news.povray.org Bernd Fuhrmann wrote:
> Thanks for the hint. Btw: What is you opinion of a facility like it is
> shown in that Python code piece?
In general it works fine. In this specific case there's a few things I'd
have done differently, the syntax is 'relative' close to POV-SDL. I'd
probably prefer something like VPython http://vpython.org/ with an
export to POV-Ray, becaus when working in one language I probably don't
want to bothered by another. For generating POV-Ray SDL from another
language I've been looking at templating systems and I think most what
one needs can be done with them, as after all, it's only text.
Here's yet another one:
http://www.4dsolutions.net/ocn/numeracy0.html
and other pages on the site.
Personaly, I think there are three interesting options:
One is a standalone parser that interfaces with, in my case, Python. It
would suit my current needs, but it lacks interaction, so no "trace"
ability.
Two, the possibility to call, in my case python, scripts from POV-Ray as
a kind of include files. I guess the chanches for the latter to happen
are rather small.
A third and maybe most interesting option, is something like Jython
http://www.jython.org/ . POV-Ray SDL implemented in another programming
language in such a way that it completely interacts with that language
and you can use any library available in the two languages. And
regardless what you use, everything looks like POV-Ray-SDL syntax.
All that, from a non-programmers view,
Ingo
Date: 4 Jan 2005 18:51:28
Message: <cjameshuff-91D1F6.18512504012005@news.povray.org>
In article <41dade0b$1@news.povray.org>, Darren New <dne### [at] sanrrcom>
wrote:
> Warp wrote:
> >   POV-Ray needs a language specific for POV-Ray. Using a generic
> > programming language will make many things too awkward and hard to
> > use (too many things will have to be kludged).
> I disagree that this would be the case for several languages designed
> specifically for this purpose, such as FORTH and Tcl. I'd be interested
> in an example of something that current SDL does that would be severely
> awkward in (say) Tcl.
Uh...what? You disagree that Forth would be more awkward? Your brain
must be inside out. ;-)
I actually considered a similar language (more similar to PostScript,
actually) for driving my own raytracer, but I'd never construct a
complex scene in it directly. I've had enough of that stuff with some
hand coded PostScript logos I did. (I finally decided that C++ was good
enough, considering that it was primarily a testbed for raytracing
algorithms.)
I don't know much about Tcl, but I doubt it would be as convenient as a
special purpose language. Simply having a built-in syntax for specifying
vectors is a huge advantage. A quick web search tells me it's designed
to be easily extended though, so maybe you could modify it to support a
fairly POV-like syntax...
In a general purpose language, you're pretty much restricted to
manipulating the raytracing engine through an API, rather than writing a
scene in a scene description language. For just general scene coding,
this is usually more work. For example, something like:
sphere {< 0, 1, 0>, 1
    scale < 1, 0.2, 1>
    rotate < 45, 0, 0>
typically turns into something like:
Sphere mySphere(Vect3(0, 1, 0), 1);
mySphere.Scale(Vect3(1, 0.2, 1));
mySphere.Rotate(Vect3(45, 0, 0));
scene.AddShape(mySphere);
It gets worse when you throw things like transformations into the mix.
You end up with either a complex, hard to maintain API, or complex, hard
to write and maintain scene code. An "elegant" way to handle
transformations would be to give objects a single method for applying a
transformation:
mySphere.Transform(Transforms::Rotation(Vect3(45, 0, 0)));
The "convenient" way would be to provide a method for each type of
transformation, with different versions for vectors, scalars, and
triples of vectors:
mySphere.Rotate(45, 0, 0);
Much easier to write and read. But the API now has at least 3 rotation
methods in addition to the general Transform() method. If you add an
axial rotation transform, you need to add at least another method to the
shape classes.
Some languages (including Lisp, I think) allow parts of the language
itself to be modified by programs written in the language...this could
be a very useful feature, since you could build the scene description
language with the base programming language. However, I don't know of
any which would be good candidates for a POV-Ray input language.
Another thing to consider is that most scripting languages aren't
designed for efficiently processing floating point math. The current
POV-Ray SDL is one of the worst at this, but the new one should be good
enough to use as a shader language and to specify functions for
isosurfaces without needing an entirely separate VM.
http://tag.povray.org/
Date: 4 Jan 2005 19:09:56
Message: <cjameshuff-AC7CAD.19095404012005@news.povray.org>
In article <41d98ce0$1@news.povray.org>,
 Bernd Fuhrmann <Sil### [at] gmxde> wrote:
> What should be thought of is this: There are a lot of good programming
> languages out there: C/C++, Java, Pascal/Delphi, JavaScript, XML,
> Scheme, Prolog, PHP, and so on. Why does POVRay need to have it's very
> own programming language that is compatible to none of the existing
> ones? The only thing that POVRay needs to do is this (simplified):
Simplicity. None of those really cut it.
> So one has to ask: How can I get all that date in a clean and easy way
> from all kinds of different sources to the renderer? What sources might
> that be?
Primarily hand-written scene files. XML is basically useless for that,
those other languages are usually just very awkward, and require
knowledge of a complex programming language. The existing SDL is
limited, but it's also simple. People can do substantial things while
knowing very little about programming.
Then there's maintenance issues...keeping up with updates to the
language, changing the language if the developers take it in a direction
that makes it less useful to POV-Ray, etc. Plus debugging someone else's
code base.
For someone with experience in those languages, learning the POV-Ray SDL
shouldn't be a challenge, but the POV language will be better at what it
needs to do.
> Cool. Where do I have to go to join development team? #4 doesn't seem to
> be under development. Or is it? Couldn't find any info, any invitation,
> anything.
That was probably because you weren't invited. POV 4 isn't even
partially released yet, but that you can't see it doesn't mean there
hasn't been any design or code written. You can write and distribute
modifications as allowed by the license, but you'll have to work with
3.6 for now.
Date: 5 Jan 2005 03:59:56
Message: <41dbac8c@news.povray.org>
If you say so. Are you quite sure of what you're talking? Some of those
languages are very powerful, especially for large projects.
>>that be?
But they can't do advanced things as easy as they could if there existed
some default front-end for one of those programming lanugages mentioned
above. So there should be an alternative for those who want to do the
more advanced stuff.
> code base.
Programming languages don't change that much. Last change of C++ was in
2001, I guess, and that was just a minor issue. Ok, C++ is complex. You
might consider the use of any other programming language. They are well
defined and if there are substantial changes you might stick to the old
version for a while. You might even use external compilers so the POVRay
team can concentrate on the raytracer.
> needs to do.
It's not learning POVRay SDL but getting complex work done with it. I
can tell you that it is not motivating if you are just experienced
enough to know that the code you are writing will not be maintainable.
>>anything.
> 3.6 for now.
So there would be another POVRay modification. I don't have the time for
this. I would have to redesign half of the program. This is useless
since I would have to spend so much time and in the end noone would use
my version (except me). All the advanced features of the next version
and it's bugfixes would not be in my version. Therefore this is pointless.
Bernd Fuhrmann
Date: 5 Jan 2005 05:59:24
Message: <41dbc88c@news.povray.org>
> I once had to do a couple of things
> with Scheme and I was really pretty upset because of certain things.
  Typical example of "extrapolation from one or less examples".
Date: 5 Jan 2005 06:01:38
Message: <41dbc912@news.povray.org>
> I don't understand that one. Why should people _need_ to learn new
> languages. If there is just a frontend that is able to create SDL code
> they'd still have SDL code to work with. They won't be able to
> effectively modify it but they aren't now either in many cases (those
> that are just to hard to be treated with common SDL).
  I don't understand what you are talking about.
Date: 5 Jan 2005 06:16:08
Message: <41dbcc78$1@news.povray.org>
Look at this stuff
http://www.photon.at/~werner/light/
http://www.photon.at/~werner/light/doc/a00451.html
And also you can try to search the web for other projects I didn't do it
thorougly.
What do you think?
Andrey.
Date: 5 Jan 2005 10:32:58
Message: <41dc08aa@news.povray.org>
If you say so. No, really. I developed (with my partner) about 10
programs that were more or less complex. So I don't think what and how
you say about my Scheme experience is not really fair. I won't answer
that anymore since it's really pointless.
Bernd Fuhrmann
Date: 5 Jan 2005 13:33:35
Message: <cjameshuff-A750B9.13332805012005@news.povray.org>
In article <41dbac8c@news.povray.org>,
Yes, I am quite sure. I have done complex simulations in POV-Ray, it's a
pain in the ass. I have also done scenes coded directly in Java and C++,
that's a bigger pain in the ass than writing the raytracers. As I
mentioned before, simply the lack of a built-in vector syntax makes
things much harder to write and read. My C++ tracer can be made to do
Monte-carlo path tracing by simply coding the materials in a certain
way, but building a scene of any complexity is maddening due to all the
C++ syntax I have to work through.
Pascal, Delphi, JavaScript, and PHP would all have similar problems to
C++ and Java related to the requirement of using an API. A Prolog SDL
would be...very interesting, but probably not very good for general use.
Scheme might make a useful, but idiosyncratic SDL. XML is useless for
hand coding, and no easier for automated programs to write than a custom
SDL would be.
> Some of those languages are very powerful, especially for large projects.
And this shows you completely miss the point. It doesn't matter how
powerful the language is if you must be a programmer to use it. Most POV
users aren't programmers, despite hand coding their scenes in a
Turing-complete programming language.
They can't do them *now*. They could with a improved scene description
language, more easily than they could with a general programming
language.
The POV-Team, and all the people developing patches, will concentrate on
what they want. Much of the time, that is extending the language to be
more powerful for describing scenes. It is not just a minor subsystem
for loading scene data.
In addition, an external language will either lose a great deal of
versatility because it can't tie directly into the tracer, or lose
portability due to having to dynamically load the POV-Ray renderer as a
library. Evaluation of pigments, transformations, and ray intersections
during scene construction are extremely important features. You just
can't do this without adding problems with portability, dependency on
other libraries or utilities, etc. And then you have the issues with
ensuring security from malicious scripts, convincing users that they
have to learn a complex programming language and scene API, etc...
You miss the point again...that can be fixed by improving the SDL,
without losing its advantages...which would be lost by moving to a
general programming language. Ease of learning the language and using it
for things which are simple in terms of programming are far more
important than you seem to realize.
I think this should be obvious, but if nobody finds it useful, it
shouldn't be in the official version.
Date: 5 Jan 2005 14:58:10
Message: <cjameshuff-74285D.14580805012005@news.povray.org>
In article <41db3709$1@news.povray.org>, Darren New <dne### [at] sanrrcom>
> You can write OO-ness in Tcl, entirely in Tcl. Many of Tcl's control
> structures are written in Tcl.  Adding a vector type to Tcl is *trivial*.
After looking at some examples online, I begin to see...it's one of
those "mutable" languages I was talking about.
> Yes. That's called an "extensible" language, and includes Tcl, FORTH,
> and Lisp. Lisp still has the ((())) syntax to deal with, FORTH has the
> postscript, and Tcl has very few drawbacks in this regard. Altho, as you
> mention, Tcl expression syntax can be a little bit ugly, just a tad.
Sounds like we're talking about the same thing, just that I don't know
anything about Tcl.
> Tcl, I'd venture. :)
> Mind, Tcl isn't really good at math as such, but on the other hand since
> math isn't technically built into the language, that would probably be
> pretty easy to improve.
Well, I'll have to put Tcl near the top of my list of alternative
existing languages. However, I'd still prefer a custom one, for the
control over architecture and reduction in dependency, and more clear
responsibility for bugfixes and such. Based in spirit on languages like
Tcl, but not in actual code. Writing a language parser isn't all that
difficult, it's mainly tedious after you get basic expression parsing
done...and once it's done, adding or minor modification is pretty easy.
And, if it's not designed for it from the start, making the VM
high-performance for things like shaders would probably be quite
difficult. Going from dynamic dispatch of an operator method to
performing a VM operation on a numeric primitive type is quite a change.
Something like overlapping it with a far more static language...
