POV-Ray : Newsgroups : povray.advanced-users : POVRay and XML Server Time
10 Jun 2026 00:45:41 EDT (-0400)
  POVRay and XML (Message 38 to 47 of 107)
Subject: Re: POVRay and XML
Date: 1 Jan 2005 16:24:15
Message: <41d714ff@news.povray.org>
Bernd Fuhrmann <Sil### [at] gmxde> wrote:
> >   Transform to what?
> POVXML(with a lot of extensions) -> POVXML(with fewer extensions) ->
> POVXML(with no extensions) -> POVRay SDL -> BMP
  So what you want is a *separate* application which converts your
pov-XML to SDL and then uses POV-Ray to render the image?
  Then why not just go ahead and create such XML specification? Let's see
how much people will be using it...
> >   You have to still remember that the SDL is a programming language, not
> > a document.
> What's the difference?
  By definition in a markup language you have to tell for each distinct
item its type (in XML in the most cumbersome way with starting and
ending tags). An XML parser can then do something with each type
according to some specification of how each type should be interpreted.
  In a programming language you don't need to specify the type of
each item which appears in the program source code. This is because
a programming language is typically not designed so that it can be
parsed with a generic markup parser but needs a parser specific to
that programming language. The advantage of this is, naturally, that
it makes it easier for the user to write programs using this language
because it's the language parser which performs the task of tokenizing
the input, not the user.
  If you write XML by hand you are burdened with this extra task which
should be something the parser does.
  Besides, being a very generic markup language which does not offer
anything specific to any programming language, most programmatical
constructs need to be done either with extremely bloated syntax
where you (not the parser) tell the program for each single item
what it is, or either you use a very artificial syntax of putting
the whole thing into a string (which you should not be required to do
in the first place; just the fact that the quotation marks and other
extra syntax around these strings are not part of the expression should
immediately give you a hint that there's something unneeded there).
  In a programming language you say typically: a=b;
  Now, just think about how you would do that same thing in XML and
how much of that line will be additional bloat which is not really
part of the command but is required by XML. Also think why the user
should write that extra stuff when there's no need.
  The user and the program (in this case POV-Ray) are not interested
in the markup of the input, they are only interested in its meaning.
It just doesn't make any sense to force the user to specify any
markup on the input since none is needed for anything.
> XML offers all these things in one standard that many people know of.
  Can't you understand that XML is not the right tool for writing a
program? Programs are usually written by hand, and this task should be
made as easy as possible.
  What you are suggesting is making the life of the users harder in order
to make the life of the programs easier.
> <sphere center="0,0,0" radius="5"/>
> compare this to:
> sphere {<0,0,0> 5}
  Why should the user be burdened with all that additional syntax?
What does it benefit the user that he is forced to write all those
extra symbols and keywords?
  Besides, that extremely simplistic example is too naive. How would
you write this in XML so that it makes the life easier for someone
(for the user, or the parser, or the renderer or anyone):
union
{ #declare IndX = 0;
  #while(IndX < MaxX)
    #declare IndY = 0;
    #while(IndY < MaxY)
      sphere
      { <IndX*5+1, IndY*0.25-1.25, -5>, IndX*IndY/10
        #if(IndX < MaxX/2)
          pigment { rgb <IndX/MaxX, IndY/MaxY, 0> }
      #declare IndY = IndY*.125;
    #declare IndX = IndX*.5;
  pigment { rgb x } finish { specular .5 roughness .03 }
Date: 1 Jan 2005 16:26:22
Message: <41d7157e@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> > But POVRay
> > files are rather small. Parsing speed does not matter that much.
> I just wanted to point out this particular statement for those who do
> not follow this thread very closely...
  Thanks for the ROTFL. I missed that one. :)
Date: 1 Jan 2005 18:17:29
Message: <41d72f89@news.povray.org>
>>>  Transform to what?
Exactly!
I can do that, sure. I'd have to spend a lot of time for that. But why
should I do that if I would become the only user of this specification?
If one single person (me) works on such a specification it would
certainly have errors. I need people to correct it and just test it. So
I thought: "Maybe it's a good idea to search for other people who are
interested in such a thing for it might prove really useful". That is
why I posted.
So: Is there anybody interested?
>>>a document.
I think I start to get your point. As you observed: I don't think it is
wise to force anybody to another syntax. I just think there should be an
alternative. POVRay SDL is ok for a wide range of tasks. But not for all.
So it's basically a trade-off between parser complexity and
syntax-ease-of-use. But there are cases in which I want to parse a
POVRay SDL myself, for example to do certain conversions or adaptions.
If there was some API for that parser my problem would be (almost)
solved. But there is none. There are still features missing in that damn
thing and POVRay 4.0 isn't even in development yet. At least I couldn't
find a bit of information about it except that it is supposed to be
great and so on; nothing specific. What do you suggest to solve this
problem? Write an own parser for POVRay SDL? Change POVRay SDL?
I do understand that. But POVRay SDL isn't a full featured programming
langugage. It seems to me to be comparable to BASIC but not even to
Pascal or gems like C++. So POVRay SDL has to move on, definately. But I
don't see that neccessary movement yet.
Almost right. If you write parsers you will be glad of this.
>>compare this to:
>>sphere {<0,0,0> 5}
> union
>   #while(IndX < MaxX)
>     #declare IndY = 0;
>     #while(IndY < MaxY)
>       sphere
>         #if(IndX < MaxX/2)
>         #end
>     #end
>   #end
Hm, interesting example. You might have a 1:1 translation like this:
<union>
<declare l="IndX" v="0"/>
<while cond="IndX<MaxX">
<declare l="IndY" v="0"/>
<while cond="IndY<MaxY">
and so on...
</while>
</union>
You also might also leave it to XSLT to execute your programming stuff.
That might look like this:
<!-- MaxX and MaxY have to be known at transformation time-->
<xsl:template name="myloopinner">
<xsl:param name="IndY"/>
<xsl:param name="IndX"/>
<xsl:if test="$IndX < $MaxX"/>
<sphere center="$IndX*5+1, $IndY/4-1.25, -5" radius="$IndX*$IndY/10">
<rgbpigment value="$IndX/$MaxX, IndY/MaxY, 0"/>
</sphere>
<xsl:call-template name="myloopinner">
<xsl:with-param name="IndX" select="$IndX"/>
<xsl:with-param name="IndY" select="$IndY/8"/>
</xsl:if>
</xsl:template>
<xsl:template name="myloopouter">
<xsl:with-param name="IndY" select="0"/>
</xsl:call-template>
<xsl:with-param name="IndX" select="$IndX/2"/>
</xsl:if>
</xsl:template>
<union>
<xsl:call-template name="myloopouter"/>
<xsl:with-param name="IndX" select="0"/>
<rgbpigment and so on>
</union>
This is terrible code. I do hate pure XSLT. There are, however, some
systems that simplify the use of loops and so on. I just haven't had a
closer look at them yet. A very promising project seems to be here:
http://sourceforge.net/projects/xsltsl/
One other thing: I haven't tested this code. It's quite likely that it
won't work. But I hope you see that it is at least possible. People who
are used to work with XSLT will most likely find much cleaner and
simpler solutions.
Besides: Your code is nonsense. 0*0.125 is always 0. Your code will
either do nothing or never finish.
Bernd Fuhrmann
Date: 1 Jan 2005 18:25:47
Message: <MPG.1c40df0c97fb20dc989c9c@news.povray.org>
In article <41d6ae1a$1@news.povray.org>, Sil### [at] gmxde says...
> Thorsten Froehlich wrote:
> But POVRay
Ah.. A real professional user of POV-Ray are we? Some SDL takes longer to
parse than the actually rendering. The very idea that size, complexity
and speed in that step is irrelevant is.... incomprehensible..
> Now for the 4.0 rewrite: What will it be like? I just googled a bit, but
> I couldn't find anything about it. How do you know that similar
> limitations like the ones described won't appear again? Is there any
> information about it available?
First off... Thorsten Froehlich is on the development team for this
program, so one would think he would have a clue what the flaws are and
why your idea is purely nuts. Yeah, there is one application of XML I can
think of that provides for programming, but it does so by borrowing the
<script></script> tags from HTML and using real languages to do the work.
The rest of it is just parsing of user readable information that defines
simple behaviours and settings for inbuilt functions, not complex
objects. It also uses name spaces to keep things straight, but doesn't
allow directly talking between things in different name spaces. Why?
Because the same 'include' might be used in several different XML
plugins. Each of them could use the same function names, the same names
for objects, etc. and keeping all of them straight, even with namespaces,
is easier is they never directly interface in any way. The interfaces
that are supported involve using a unique UID for each one, to make sure
they don't interfere. With POV-Ray, even with separate spaces, these
things have to interoperate and coexist. That has to be handled 'by the
application'.
What form the data takes in the source file has nothing to do with the
function, only the time wasted a) coding it and b) parsing it. Making it
intentionally more complex doesn't fix the problem, which is not in the
file, but in the way the application handles the information. You could
use bloody Sanskrit on punch cards, Tolkein's elven language transmitted
by brain waves or even your XML idea and it wouldn't alter the fact that
the problem is in the limitation of how the data is handled 'in the
program', not how it is represented in the SDL itself.
Argh.. Its like arguing with someone that insists printing Bible quotes
on toilet paper would be sacrilegious, it has to be exactly such and such
font, this specific size, the paper made from only the finest rose wood
pulp, blah, blah, blah. Only the real argument is if the Reader's Digest
Condensed version leaving out all the verse names and insisting on
calling Moses, "the bearded guys with a stick" was the best way to get
the story across. lol Which is more important, that the program supposed
the feature everyone admits is missing, or that it was painted in the
most recent style? BTW, I equate XML with pointillism. Complicated,
insanely anal and totally pointless if there is a more efficient method
to solve the problem. Maybe, given 50-60 years it will actually look
'useful' for some programming applications, much the way pointillism more
or less accidentally hit on the idea for digital video, years before it
was remotely practical for anyone without a lot of patience and several
loose screws to use the idea. However, I strongly suspect it won't. lol
And for the 99,999th time on these news groups. Version 4.0 features are
not yet even technically 'in development' yet, which makes it a bit hard
to discuss what or how anything will be implemented in it.... Nor has the
team expressed a desire to discuss it and have 500 people telling them
not what will improve the ideas, but how they are doing it all totally
wrong.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 2 Jan 2005 06:51:02
Message: <41d7e026$1@news.povray.org>
>>But POVRay
To be honest: I am not a professional user of POVRay. I just want to
render some illustrations for my documents and my webpage with POVRay.
No landscapes, no complex meshes and so on. The sentence you quoted lost
its context: In MPEG parsing speed is essential. It can make the
difference if you can watch a movie on a 300Mhz processor or if you need
a 1000Mhz processor. Assembler optimization is absolutely neccessary for
such parsers. But in POVRay its different: There is no time limitation
of that kind. You don't render 25 pics per second, do you? So what if
you need twice the time for parsing? It won't do that much harm. You
just have to wait a bit longer or buy a faster computer or simplify your
scene a bit.
Besides: Parsing is just transforming the program to a treelike internal
representation form. It's not executing or evaluating the program except
you do everything with the preprocessor. So does it really take that
long to process handwritten code? I cannot believe that. It will take
much longer to execute and evaluate the internal treelike representation.
> application'.
Right. That is why I suggest to put some processing outside of POVRay.
POVRay is a good raytracer. I'm really impressed by it's fine
performance. But I think that not all processing of data should be done
by POVRay. There are e.g. programs that build meshes out of other data.
A good example might be the creation of humanoids out of a collection of
sizes. I will never be able to write anything like human{<0,0,0> 30 40
10} because I cannot define my own objects. It wouldn't make sense
anyway if I could because this would lead to total anarchy in the lower
namespace. But it is still incredible difficult for me to write a parser
that will just replace all "human {...}" with something that POVRay can
render like a mesh. That is what I want. I don't want to touch the
POVRay parser. I just want to get my own preprocessing done. This is
possible with XSLT (though it sometimes looks ugly, I admit).
> most recent style?
No, that isn't the point. Example: BASIC is a language that is capable
of many things. But C/C++ is better. At least for professional
programmers. No sane man would ever start to write a complex software
project (like Mozilla or sth similar) with BASIC. So it's not a question
of style but a question of language features. POVRay SDL lacks a lot
features I'd like to see. So what do I do? Change POVRay? No! I cannot
because I don't have the time. I'll rather invent some cool system that
is able to emulate the features I'd like to have.
Do whatever you like.
> wrong.
Exactly. And that is why I won't base my faith upon it. I never said
that it should be done this way or that way. I just asked if someone
would like to design an XML version of the POVRay SDL in order to gain
customizable proprocessing levels. No change in POVRay was suggested. If
I did, I apologize.
Besides: If that has been discussed so many times: Why don't you put it
in the FAQ?
Bernd Fuhrmann
Date: 2 Jan 2005 08:40:50
Message: <41d7f9e2@news.povray.org>
In article <41d7e026$1@news.povray.org> , Bernd Fuhrmann
> scene a bit.
Sorry, but you just disqualified yourself. There is no point to continue
this whole thread based on your current knowledge.
    Thorsten
e-mail: tho### [at] trfde
Date: 2 Jan 2005 10:23:03
Message: <41d811d7@news.povray.org>
> But POVRay SDL isn't a full featured programming langugage.
  What is, in your opinion, a "full featured programming language"?
  The SDL is turing-complete.
> and so on...
  Exactly my point. Too tedious to write?
  Besides, you conveniently skipped the hard parts of the code, for
example the conditional inside the sphere.
  What good does it do to simply put the code into quotation marks and
add some extra junk around them? That doesn't help the user nor the
program trying to interpret the code (it simply gets the code as a
bunch of strings which it has to parse and interpret anyways, without
the help of any XML parser).
  Besides the point. It was just an abstract example. Set the initial
values to 1 if you want to feel better about it. ;)
Date: 2 Jan 2005 11:17:25
Message: <41d81e95$1@news.povray.org>
Yes, it is. There are a lot of features missing that are used in a lot
of modern programming languages. Examples:
* Structs/Classes
* References, esp. to functions
* Namespaces
* strict type checking
Other possibly cool features
* Inheritance
* Java-like classes inside classes
* C++ like multiple inheritance
* Lambda expressions (Scheme)
>>and so on...
Well, yes. But I'm even more tedious to rewrite that POVRay parser.
Ooops. Sorry for that. What you're missing is this:
<xsl:if test="$IndX<MaxX/2">
</xsl:if>
</sphere>
But as I just found out: XSLT won't be able to do all transformations
that POVRay would be able to do, since POVRay knows sometimes more about
objects (like max_extent) and so on. Sorry for not knowing this.
Still, this does not solve those namespace and data access problems.
There still needs something to be done. I just have to think about
another way...
XSLT can process it. Nothing more nothing less.
Ok, never mind.
I must admit that using XML/XSLT exclusively for scene design and
parsing is mad. But on the other hand I will still require a SDL that
has more features, with configurable preprocessing levels. To give you a
nice example: What about a JavaDoc/Doxygen-like processing? Wouldn't
that be cool?
Bernd Fuhrmann
Date: 2 Jan 2005 13:40:24
Message: <41d84018$1@news.povray.org>
>> * Structs/Classes
>> * Namespaces
> There are plenty of large high-performance production servers as well as
> end user desktop software written in languages that lack most or all of
> these features. Their lack doesn't make programming languages "not real".
> The problem with doing something like this is, you then get to ask a
> question like "transform this scene to remove items that fail this
> condition."  How about "select in this scene objects that don't
> intersect the sphere"?
This is not possible without giving XSLT some information about what a
sphere is. This is possible, but it will get
> If you're not going to code everything in XML, anything you don't code
> in XML is going to be opaque to whatever transforms you want to do. You
> won't even be able to say "shift this element 10 units right."
Right.
>> another way...
> Write a parser for SDL. Since the help files describe the SDL using
> basically BNF notation, you can use yacc/bison to write a parser for it.
> I'm not understanding why it would be difficult, unless the docs don't
> match the reality, in which case you have a bug report. I mean, you
> even get the source to an existing parser, yes? :-)
I could write my own parser, sure. But that wouldn't fix the problem.
I'd still have unprocessable code.
As mentioned earlier: I will have to think about something different to
solve my problem. XML is a solution but due to certain limits of XSLT
not the best one.
Regards and thanks for all your comments,
Bernd Fuhrmann
Date: 2 Jan 2005 14:08:41
Message: <41d846b9@news.povray.org>
This thread was intersting to read.
I think you guys both (Warp, Bernd) made the point.
I really did think that xml might be more universal way to code.
Povray is just very specific and only for 3d modeling.
But then you realize all the drawbacks... XML is really bloated and less
convenient to read and code, no doubts, even though it may have some
advanced features, which most of people will use very rarely.
It took me 3-4 days to learn and start understanding Povray codings, but
xml I'm not sure at all. For me it would be annoying even to always
write < /> and at the same time it is really easy to learn Povray (if
you familiar with progr. languages).
Another point made by Bernd and he is right that Povray SDL indeed needs
more features to be implemented, I very much support his idea about
1.Namespaces
2.Classes and inheritance
3.References
So you see closer to C++ cooler:)
And they should be easier and more intersting to implement than to write
another parser (for the language which standart may change). Sure that's
a heck of a work, but eventually it should be done.
I'd love too see some of these features in the next version of Povray.
Andrey Skvortsov
