POV-Ray : Newsgroups : povray.advanced-users : POVRay and XML Server Time
10 Jun 2026 03:28:40 EDT (-0400)
  POVRay and XML (Message 28 to 37 of 107)
Subject: Re: POVRay and XML
Date: 1 Jan 2005 09:51:03
Message: <41d6b8d7$1@news.povray.org>
ingo wrote:
> in news:41d51598@news.povray.org Bernd Fuhrmann wrote:
>>What do you think about this idea?
> After reading most of the thread, I get the impression that you have a
> "problem" and that your "solution" to that "problem" is XML. I think I
> have a simmilar "problem", 'all one can do with a .pov file is render it
> with POV-Ray'.
Exactly. You got my point. I want to do more with my scenes.
> I.m.o XML itself is not the solution. You gave one reason: "Obviously
> this works only in one direction". Others gave many other reasons.
Depends on what you see as solution. It's might be possible to parse
POVRay SDL with XSLT. But it's slow and a lot of work. As long as there
are no other solutions XML might be the best of many bad ones.
> What we'd need is a POV-Ray parser, and currently the only one available
> is POV-Ray and we can't use that for other purposes. I tried writing one
> in Python, but gave up due to severe lack of skills.
With the right help this is possible. Are you interested in anything
like this? Write me an email.
> Once you have a POV-parser (with a liberal enough licence and with some
> API or bindings or ...) you can do many things with a scene, even
> convert it to some form of XML if you like.
Is (L)GPL ok?
Bernd Fuhrmann
Date: 1 Jan 2005 09:53:18
Message: <41d6b95e$1@news.povray.org>
In article <41d6b8d7$1@news.povray.org> , Bernd Fuhrmann
> Is (L)GPL ok?
No, only a BSD license would be OK to facilitate use of a format in
commercial applications and allow them to make changes to the code (not the
format, but that cannot be prevented by either license).
    Thorsten
e-mail: tho### [at] trfde
Date: 1 Jan 2005 09:55:05
Message: <41d6b9c9$1@news.povray.org>
BSD? Agreed. Interested?
Bernd Fuhrmann
Date: 1 Jan 2005 09:56:13
Message: <41d6ba0d$1@news.povray.org>
In article <41d6ae1a$1@news.povray.org> , Bernd Fuhrmann
> XML is just a way to give a document (which does include programs
> aswell) structure that is easy to parse. It does not specify the
> structure itself. I'd make the structure almost equivalent to POVRay's
> structure.
OK, please provide XSLT that transforms a non-trivial X3D XML mesh to a
POV-Ray mesh.  Just the geometry.  I would love to see the XSLT and its
complexity ... so show me that I am wrong if you can!
    Thorsten
Date: 1 Jan 2005 10:34:40
Message: <41d6c310$1@news.povray.org>
>>structure.
No I won't. Its quite a task to write such a XSLT. I have never worked
with X3D. It would take me weeks to learn X3D just to proove that it is
possible.
But if you want to see XSLT in action:
I have attached a little XSLT transformation that transforms data from a
log file (almost plaintext, written by a simple PHP script), analyzes it
and displays some statistical information about it. I hope the power of
XSLT becomes visible. XSLT can also output plain text. So I could even
render this data with POVRay. That would just be a few lines. Ok it
would be useless. But at least it's possible. And I wouldn't have to
write my own parser for it. This saves me a LOT of time. It would be
cool if I could access POVRay SDL the same way and display automatic
generated data from it aswell. That is what I try to achieve (among
other things).
Bernd Fuhrmann
Download 'us-ascii' (3 KB)
Date: 1 Jan 2005 10:44:13
Message: <41d6c54d$1@news.povray.org>
In article <41d6c310$1@news.povray.org> , Bernd Fuhrmann
Exactly that was my point ;-)
> I have never worked
> possible.
Well, the only real difference is that there are no commas (well, they are
optional in VRML, they are just like spaces) and no < > around vectors, and
X3D keeps all coordinates in a *single* string.  It takes almost nothing to
transform a classic VRML-style X3D mesh to POV-Ray (one can do it with a
simple regular expression), but to transform the same X3D XML lots of manual
tweaking is needed to just *remove* redundant XML syntax that serves no
useful purpose at all!
    Thorsten
Date: 1 Jan 2005 11:27:10
Message: <41d6cf5e$1@news.povray.org>
>>I have never worked
>>possible.
I just wrote a little demo XSLT that puts commas where once were spaces
in transform/translation attributes and adds < and > to the beginning
and end. If you want anything more complex please send me an example
what transformation you want. Btw: I'm not a very good XSLT programmer.
I just use it for the creation of my small private webpage. So don't
expect me to write complex parsers that would take a pro months.
<?xml version="1.0" encoding="iso-8859-1"?>
<xsl:stylesheet	version="2.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform" xmlns=""
<xsl:output method="xml" encoding="iso-8859-1"/>
<xsl:template match="*|@*|text()|processing-instruction()">
<xsl:copy>
<xsl:apply-templates select="*|@*|text()|processing-instruction()"/>
</xsl:copy>
</xsl:template>
<xsl:template match="Transform">
<Transform>
<xsl:attribute name="translation"><<xsl:analyze-string
select="@translation" regex=" +">
<xsl:matching-substring>,</xsl:matching-substring>
<xsl:non-matching-substring><xsl:value-of
select="."/></xsl:non-matching-substring>
</xsl:analyze-string>></xsl:attribute>
</Transform>
</xsl:template>
</xsl:stylesheet>
Tested with this input:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE X3D PUBLIC "ISO//Web3D//DTD X3D 3.0//EN"
"http://www.web3d.org/specifications/x3d-3.0.dtd">
<X3D profile='Immersive'
xmlns:xsd='http://www.w3.org/2001/XMLSchema-instance'
xsd:noNamespaceSchemaLocation='http://www.web3d.org/specifications/x3d-3.0.xsd'>
<head>
<meta name='filename' content='Figure02.1Hut.x3d'/>
<meta name='author' content='The VRML 2.0 Sourcebook, Copyright [1997]
By Andrea L.
Ames, David R. Nadeau, and John L. Moreland'/>
<meta name='translator' content='Don Brutzman'/>
<meta name='created' content='6 August 2000'/>
<meta name='revised' content='9 July 2003'/>
<meta name='description' content='Your first VRML world - a brown hut.'/>
<meta name='url'
content='http://www.web3d.org/x3d/content/examples/Vrml2.0Sourcebook/Chapter02-Introdu
ction/Figure02.1Hut.x3d'/>
<meta name='generator' content='X3D-Edit,
http://www.web3d.org/x3d/content/README.X3D-Edit.html'/>
</head>
Index for DEF node: BROWN
<Scene>
<!-- This NavigationInfo node is added to many scenes, making
examination of objects
easier -->
<NavigationInfo type='"EXAMINE" "ANY"'/>
<Group>
<Shape>
<Appearance DEF='BROWN'>
<Material diffuseColor='0.8 0.6 0.3'/>
</Appearance>
<!-- Default Cylinder height=2, centered about origin -->
<Cylinder radius='2'/>
</Shape>
<Transform translation='0 2 0'>
<Shape>
<Appearance USE='BROWN'/>
<!-- Default Cone height=2, centered about local origin -->
<Cone bottomRadius='2.5'/>
</Shape>
</Transform>
</Group>
</Scene>
</X3D>
[Taken from
http://www.web3d.org/x3d/content/examples/Vrml2.0Sourcebook/Chapter02-Introduction/_pages/page01.html]
I know this is not what you wanted. But this script could be extended so
that it might do things more complete. I do not yet know enough about
X3D to write anything that actually makes sense. Please provide an
example if you are interested.
Bernd Fuhrmann
Date: 1 Jan 2005 12:45:01
Message: <cr6nei$a80$1@chho.imagico.de>
> But POVRay
> files are rather small. Parsing speed does not matter that much.
I just wanted to point out this particular statement for those who do
not follow this thread very closely...
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 1 Jan 2005 13:54:48
Message: <41d6f1f8@news.povray.org>
>> Do you know any programming language what is able to access it's own
>> objects that way?
> Quite a few. LISP, Tcl, Forth, etc. The term you're looking for is
> either "introspection" or "reflection", depending on precisely what
> kinds of data you're looking for.
Thanks for that hint. You're right. Some commonly used languages are
indeed introspective.
Bernd Fuhrmann
Date: 1 Jan 2005 14:22:43
Message: <Xns95D1CF4D9F7BDseed7@news.povray.org>
in news:41d6b8d7$1@news.povray.org Bernd Fuhrmann wrote:
>> I tried writing one in Python, but gave up due to severe lack of
>> skills.
I'm interested in a POV-Ray parser, but I have no time to work on anything
like that at the moment. And, I've set my hopes on POV-Ray 4, let it come
with a libpovparse, libpovwrite (so we can have decent and uniform output
from modellers), libpovNURBSs, libpovspline, .... (dream on).
>> some API or bindings or ...)
> Is (L)GPL ok?
Nope, BSD/MIT or Public Domain.
Ingo
