POV-Ray : Newsgroups : povray.advanced-users : POVRay and XML Server Time
10 Jun 2026 05:23:06 EDT (-0400)
  POVRay and XML (Message 18 to 27 of 107)
Subject: Re: POVRay and XML
Date: 1 Jan 2005 05:50:19
Message: <41d6806b$1@news.povray.org>
Warp wrote:
> Bernd Fuhrmann <Sil### [at] gmxde> wrote:
>>Why not? It isn't that difficult. People write XHTML, MathML and even
>>SVG by hand. At least I do. So why not POVRay?
>   Because there already is a language which is ten times easier to
> write and understand.
But not to transform. Automatic code generation is an important goal. At
least I want to achieve it.
>>It would be possible to write material libraries, object libraries and
>>so on without clobbering the global namespace.
>   If this is the problem, why is XML the solution?
Because XML supports namespaces via xmlns.
>   The POV-Ray SDL is a *programming language*, XML is a markup language.
> Trying to create a programming language with a markup language is not
> the best possible idea.
Well. POVRay syntax won't stay the same forever, will it? Extensions
will surely be added. There needs to be a system that assures that these
extensions wont result in any conflicts with old scenes. How can you
know that the names you use for variables won't ever be used by POVRay
itself? Your scenes might not render in POVRay 5.
>>It would become possible to access the camera settings to adjust certain
>>values. This would make the implementation of HUD systems possible
>>(useful if you want to mark or label certain things in your scene).
>   And XML is the best solution for this because...?
It isn't. XML is a general markup language made by humans and has
certainly it's flaws. But XML is the best general markup language I know
of. In fact you might ask any IT professional for the best general
markup language and most sane will tell you: "Use XML". There is XSLT, a
general transformation language. It is (with a few tweaks) as powerful
as the lambda calculus and thus as powerful as POVRay itself.
>>One could even convert whole models to meshes and apply mesh
>>modificators on them. This is AFAIK not yet possible in POVRay.
>   And how on earth does XML make this any easier? Does XML have some
> magic which will allow you to tesselate any given surface?
Not really. You'd have to code it all yourself. But this is still
possible. I guess it will take 1/2 year. But the point is: You cannot do
this at all with POVRay since you cannot access scene objects. XSLT
could do this. Or what if you wanted an object to appear always in the
same size. You would have to access the camera data. This cannot be
written as an POVRay include file. You can write it easily as XSLT
transformation from one scene to another.
>>Ok, maybe some of these things can be done in POVRay file format. But if
>>they can be done, how clean can they be done?
>   It is aknowledged that the current SDL has reached its practical limits
> and that a better language may be necessary, but XML is certainly not
> the answer. POV-Ray needs a programming language, not a markup language.
Tell me: What is the fundamental difference between a programming
language and a markup language. Both are finite. Both have a tree-like
structure.
Bernd Fuhrmann
Date: 1 Jan 2005 06:23:36
Message: <41d68838@news.povray.org>
Thorsten Froehlich wrote:
> Whatever argument for XML you can give, it applies for any other format.
> The use of XML has been discussed to death before, and there are just no
> arguments for it that do not apply to the current format just as well. As
> such, there is no point to argue for XML.  To the contrary, there are things
> you can do in POV-Ray right now that would be incredibly difficult to
> express in XML.
And POVRay can do namespaces how? If it can do namespaces: Why isn't
there anything written in the documentation? If you have to fake
namespaces: Why isn't there a coding style guide that will advise people
how to make extensions to existing include files and libraries?
If you haven't noticed: I'm just asking if someone is interested in
writing such a system. Noone would be forced to switch to XML. But it
just doesn't make any sense for me to write such a system on my own.
Possibly other persons are interested in such a system and I'm looking
for such persons. If you are not interested, it's ok. I don't want to
change the default SDL. I just want to add one.
Additionaly I state that POVRay will run into big trouble (known as
namespace clobbering) in the future. Big projects will be more difficult
to make due to this.
Bernd Fuhrmann
Date: 1 Jan 2005 07:38:38
Message: <41d699ce@news.povray.org>
  Transform to what?
  You have to still remember that the SDL is a programming language, not
a document.
  So what you are basically saying there is that XML is the only
language in the world which supports namespaces?
  Let me rephrase the question: If namespaces are the problem, why XML
is the right solution compared to all other languages (including possible
specific languages which can be created for POV-Ray) supporting namespaces?
  C++ supports namespaces as well. Why would XML be any better than C++?
> How can you
  Why is XML the right solution to this? Why is it better than just
developing a standard convention (eg. that reserved keywords will
always be lowercase, meaning that any variable written with at least
one uppercase letter will never conflict with a keyword)?
> of.
  But that's exactly the problem: POV-Ray scenes are not documents. They
are programs. XML is a markup language, not a programming language.
People want to write, understand and execute SDL scripts, seldom print
them nicely. It just doesn't make any sense to write a program in a
markup language.
> could do this.
  In fact, you can (there have been simple tesselation SDL macros out there
which you can give objects to tesselate).
  However, that's besides the point. If accessibility of data is the
problem, why would XML be a better solution than a true programming
language with the required features? Why change a programming language
to a markup language just to get data out of elements?
> structure.
  In a programming language you typically write things like:
(x+y^2)/(k+1)
  In XML you write that like:
<mrow>
  <mfrac>
    <mrow>
      <mi>x</mi>
      <mo>+</mo>
      <msup>
        <mi>y</mi>
        <mn>2</mn>
      </msup>
    </mrow>
    <mrow>
      <mi>k</mi>
      <mo>+</mo>
      <mn>1</mn>
    </mrow>
  </mfrac>
</mrow>
Date: 1 Jan 2005 07:50:54
Message: <Xns95D18CDF8D421seed7@news.povray.org>
in news:37jat050gpl1jhjhfl290afmkdbivt0f7q@4ax.com ABX wrote:
> And usually how hard it is to solve such issue?
The first time it happend it took a day to figure it out, but generaly
it's not a big problem. Still I think namespaces wouldn't be a bad thing
to have in a future version of POV-Ray (maybe even alongside with a
"better" way of dealing with include-file packages).
- Namespaces are one honking great idea -- let's do more of those!
   -- Tim Peters  ( http://www.python.org/doc/Humor.html#zen )
Ingo
Date: 1 Jan 2005 08:19:05
Message: <41d6a349@news.povray.org>
In article <41d6806b$1@news.povray.org> , Bernd Fuhrmann
No, only the marketing department will.  Just like marketing departments
told everybody that Java is the best general programming language five years
ago.  XML is nothing but a huge hype producing documents several times the
size of a well-designed binary counterpart that can be just as "easy" to
parse (that that XML is trivial to parse).  XML certainly has its
applications, but they are limited, not universal.
Just compare the traditional VRML (POV-Ray-like) syntax version to the XML
syntax version of X3D. It will give you a very good idea why XML is
unsuitable for describing 3D data.  In fact, X3Ds XML representation is
probably one of the best examples of pointless use of XML.  Just consider
how lists of vectors are expressed in X3D XML syntax and you should really
notice.  Of course, the problem with keeping them in strings is the result
of an inherent limitation of XML expressing data only as complex, nested
collections of strings.
>  You cannot do
That is true, you cannot do this in POV-Ray currently, but it is not a
limitation of the SDL (scene description language) but the parser design,
which is 15 years old and fairly outdated (and the 4.0 rewrite will take
care of this).
    Thorsten
e-mail: tho### [at] trfde
Date: 1 Jan 2005 08:29:55
Message: <41d6a5d3$1@news.povray.org>
In article <41d68838@news.povray.org> , Bernd Fuhrmann <Sil### [at] gmxde>
Macros provide namespaces (#local), as do include files (#local in an
include file stays local to that file).  That there are no named namespaces
(which is what you are effectively asking for) is simply a matter of nobody
having written code for it.  It is easy to add even to the current parser.
Of course, namespaces are not an answer to naming convention problems.  You
can have the same namespace name in two files and run into the exact same
problem you created namespaces for in the first place.
The documentation advises users to not use all lower-case identifiers for
user defined declares and macros as lower-case identifiers are reserved for
use by POV-Ray.  This leaves plenty of names for users.  Prefixing has
almost the same effect as using namespaces, and looking at APIs of modern
operating systems, they do really well without need for namespaces despite
using tens of thousands of identifiers.  Of course named namespaces offer a
very valuable extension to any language, including POV-Ray SDL, not having
them is only a minor annoyance, not a huge problem.
    Thorsten
Date: 1 Jan 2005 09:05:14
Message: <41d6ae1a$1@news.povray.org>
There is a hype for XML, yes. XML is not universal, true. To give a
simple example: XML will never be suited to save MPEG movies. It's just
a matter of space and decoding speed. XML is not suited to contain
executable files since they don't really interoperability. But POVRay
files are rather small. Parsing speed does not matter that much. They
contain highly structured data. So XML is suited to contain that data.
XML is, however, a bit hard for newbies to write, I admit.
But who was desperately in need of some harddrive space and started to
tweak his POVRay files? Who used shorter identifiers to save some drive
space? Use of XML will result in files that have three or four times the
size of normal POVRay files. So what?
Besides: There is a binary version of XML under development. If it might
be used to contain binary data it will rock like hell, if used properly.
XML is just a way to give a document (which does include programs
aswell) structure that is easy to parse. It does not specify the
structure itself. I'd make the structure almost equivalent to POVRay's
structure. So there wouldn't be that much overhead to vectors, numbers
and things. But one would have instantly have some powerful parser that
are able to assemble scenes. You'd have to write such a parser in POVRay
which is a hard task.
>> You cannot do
> care of this).
Interesting: So you suggest to keep the SDL while adding commands to
access scene objects, right? But how can one access scene objects
without some kind of object model? Example:
Assume you have some scene like this:
camera {location <10,20,10> look_at <0,0,0>}
light_source {<-140,200,300> rgb <1.0, 1.0, 1>*2}
sphere {<-2,0,0> 1 pigment {rgb <1,0,0>}}
sphere {<0,0,0> 1 pigment {rgb <0,1,0>}}
sphere {<2,0,0> 1 pigment {rgb <0,0,1>}}
So how would you write a transformation like "Replace all sphere by a
certain mesh"? Suggest a syntax! Do you know any programming language
what is able to access it's own objects that way?
Now for the 4.0 rewrite: What will it be like? I just googled a bit, but
I couldn't find anything about it. How do you know that similar
limitations like the ones described won't appear again? Is there any
information about it available?
Bernd Fuhrmann
Date: 1 Jan 2005 09:15:19
Message: <Xns95D19B2F5289Bseed7@news.povray.org>
in news:41d51598@news.povray.org Bernd Fuhrmann wrote:
> What do you think about this idea?
After reading most of the thread, I get the impression that you have a
"problem" and that your "solution" to that "problem" is XML. I think I
have a simmilar "problem", 'all one can do with a .pov file is render it
with POV-Ray'.
I.m.o XML itself is not the solution. You gave one reason: "Obviously
this works only in one direction". Others gave many other reasons.
What we'd need is a POV-Ray parser, and currently the only one available
is POV-Ray and we can't use that for other purposes. I tried writing one
in Python, but gave up due to severe lack of skills.
Once you have a POV-parser (with a liberal enough licence and with some
API or bindings or ...) you can do many things with a scene, even
convert it to some form of XML if you like.
Ingo
Date: 1 Jan 2005 09:29:19
Message: <41d6b3bf$1@news.povray.org>
>   Transform to what?
POVXML(with a lot of extensions) -> POVXML(with fewer extensions) ->
POVXML(with no extensions) -> POVRay SDL -> BMP
> a document.
What's the difference?
C++ is VERY capable of using namespaces (and it totally rocks). I use
them everytime. C++ namespaces in POVRays SDL would be cool. They would,
if used properly, add a lot usability to POVRay. But how are you going
to do them without changing POVRay itself?
>>How can you
XML offers all these things in one standard that many people know of. Of
course you might also develop some standard conventions, but: Hell, am I
the first one who preaches people to develop and use such conventions?
Where are those people? Why isn`t it in the POVRays manual on the first
page then? If you think this is the way to go then let's go that way!
Let's develop such a naming scheme. It's about time!
You can on the other hand use a standart that is already there, like XML
instead of developing a new one.
>>of.
> markup language.
XML can also be used for programming languages. It is a _general_ markup
language. It's not limited to documents. Just look at XSLT.
>>could do this.
Because there is already a general transformation language that can
access any XML document. It's called XSLT. So why invent the wheel twice?
> (x+y^2)/(k+1)
> <mrow>
>   <mfrac>
>     <mrow>
>       <mi>x</mi>
>       <mo>+</mo>
>       <msup>
>         <mi>y</mi>
>         <mn>2</mn>
>       </msup>
>     </mrow>
>     <mrow>
>       <mi>k</mi>
>       <mo>+</mo>
>       <mn>1</mn>
>     </mrow>
>   </mfrac>
> </mrow>
Bad example. No, I'm not suggesting to do something like this:
<sphere>
	<center>
		<vector>
			<x>0</x>
			<y>0</y>
			<z>0</z>
		</vector>
	</center>
	<radius>5</radius>
</sphere>
but rather this:
<sphere center="0,0,0" radius="5"/>
compare this to:
sphere {<0,0,0> 5}
The structure doubles the size. This is still feasable. You spend more
that much time typing sphere anyway. Most time will be spent thinking
and rendering. So: Why not using XML instead of developing all kinds of
naming schemes, another document object model and so on?
Bernd Fuhrmann
Date: 1 Jan 2005 09:37:35
Message: <41d6b5af@news.povray.org>
Which is why I prefer the way namespaces are done in XML instead of C++.
If you have a domain you have your own namespace. Just that simple. Any
idea if it can be done better than that?
I know who I am. I know what I will develop. So what prefix should I
use? This isn't in the manual.
Prefixes are fine, at least partially. They can add a lot of overhead.
Namespaces would be better. But you are certainly right: It's not a huge
problem. On the other hand: Why not doing things right as soon as possible?
Bernd Fuhrmann
