Greetings.
Not entirely POV-related, but... I've got 2 images, one of which was
rendered using +UA. What's the simplest and easiest way to combine the
two images? (I'm using WinXP, if it makes any odds.)
Andrew.
At least with the gimp you can do it.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
If you don't have a 2D image editing program, then you can always put the
images as image maps on two planes with finish{diffuse 0 ambient 1} and
carefully line up an orthographic camera with them.
- Slime
[ http://www.slimeland.com/ ]
