POV-Ray : Newsgroups : povray.advanced-users : Glare Server Time
22 Feb 2025 03:57:24 EST (-0500)
  Glare (Message 1 to 4 of 4)
Subject: Glare
Date: 11 Dec 2004 15:50:50
Message: <41bb5daa$1@news.povray.org>
I'm talking about glare.
For example, the lights on your Christmas tree. Each light measures
about 5mm across, and about 15mm long. If you took a lump of wood that
size and looked at it from across the room, it's barely visible. If you
render it with POV-Ray, the same thing happens.
And yet, because a light glows, you CAN see if from many meters away,
even though it's very small. Why?
[And how do I tell POV-Ray about this? ;-) ]
Surely I'm not the first person to wonder...
Andrew.
Subject: Re: Glare
Date: 11 Dec 2004 17:30:37
Message: <41bb750d$1@news.povray.org>
Andrew the Orchid nous apporta ses lumieres ainsi en ce 2004-12-11
15:49... :
> you render it with POV-Ray, the same thing happens.
> Andrew.
A small luminous object alway apears larger than it realy is. It's a
byproduct of the way the light censitive cells in your retina are
connected together and to some scattering inside the eye and the retina
itself.
You can add a little media containing sphere around the lights, around 2
to 4 time the size of the "lights". That media could be emissive or
scattering.
Subject: Re: Glare
Date: 11 Dec 2004 17:34:02
Message: <41bb75da@news.povray.org>
http://www.geocities.com/ccolefax/lenseffects.html
Subject: Re: Glare
Date: 12 Dec 2004 03:46:00
Message: <41bc0548$1@news.povray.org>
YAY! :-D
http://www.geocities.com/ccolefax/images/le_samp1.jpg
See, now that's exactly the kind of effect I *don't* want...
http://www.geocities.com/ccolefax/images/le_samp5.jpg
That's more what I'm after!
OK, let's go give that a try...
Andrew.
