POV-Ray : Newsgroups : povray.advanced-users : Radiosity Server Time
17 May 2026 12:23:29 EDT (-0400)
  Radiosity (Message 11 to 18 of 18)
Subject: Re: Radiosity
Date: 12 Dec 2004 03:51:37
Message: <41bc0699$1@news.povray.org>
>>OK, so... it works by tracing backwards like normal, but with extra rays
>>being spawned for diffuse illumination, approximately? (Just like
>>specular reflection and refraction require additional rays.)
> Yes.
Cool. :-)
So... the pretrace step... Is the video from that used for anything? Or
is the only purpose of this step to fill up the cache?
>>Well, that answers the main question.
>>Just to clarify... Are rays fired evenly in all directions? Completely
>>at random? Are they set up to "avoid" the object under consideration?
>>Are their directions in any way related to the direction of the ray that
>>hit this surface in the first place? Does the total computed intensity
>>take into account the different angles the light is illuminating the
>>surface from?
> In the ideal case, you would want to use completely random rays, but POV-Ray
> does not do this. Instead it uses a pre-computed table of ray directions
> whose density falls off as the angle from the normal increases.
> This density falloff places more weight on light that is coming to the point
> head on, rather than at an angle, in accordance with Lambert's cosine law.
> It saves computing time by tracing fewer rays in angles that contribute
> less to the illumination.
> No, the directions of the gather rays are the same regardless of angle of
> the ray that hit the surface in the first place. Also, before a gather ray
> is shot, there is a check to make sure that it does not go behind the
> surface in question.
...does all of this mean that the diffuse highlight options don't affect
radiosity?
Also, while we're on the subject, does radiosity take (specular)
reflection into account as well? (Never tried it, but I assume it does...)
>>You say the process traces backwards according to the max trace limit.
>>(In fact, I think there might even be a parameter to change it for the
>>radiosity system so it's different to the main trace.) Does POV-Ray only
>>save the final intensities, or does it cache all the intermediate values
>>too?
> No, I said it uses the radiosity recursion_limit, not the max_trace limit.
> POV-Ray caches the intermediate values, too. However, it will only reuse
> samples from the irradiance cache when the bounce depth of the stored
> sample matches the bounce depth of the sample point in question.
So there's a separate cache for each depth?
>>PS. Some graphical diagram in the help file would be really useful here.
>>I /think/ I understand the overall principle now, but for a long time I
>>was very confused by this feature.
> I agree on that! I'm not on the POV-Ray team, but I'd like to make one when
> I get a chance.
Yeah, I might have a go at it too at some point...
Andrew.
Date: 12 Dec 2004 04:03:35
Message: <41bc0967$1@news.povray.org>
While I'm here - slightly different question.
They recommend you don't try to render radiosity images in parallel.
Would it be possible to run the pretrace step, save the rad data, and
then start a full render going on 2 instances of POV-Ray, both loading
back the same rad data? (I'd have to turn off additional sampling,
probably.) Would that work OK? Anyone ever tried it?
(My dad has a faster computer than me - and it's dual CPU.)
Andrew.
Date: 12 Dec 2004 09:45:00
Message: <web.41bc589f4485a722e0b13d0@news.povray.org>
Its just to seed the cache with values (somewhat evenly distributed over the
scene space).
> radiosity?
a>
What I said doesn't lead to that conclusion. However, those faked diffuse
highlights (phong, specular) are indeed deliberately disabled for radiosity
gather
rays "since this causes problems with colors being far to bright"(quoted
from lighting.cpp Diffuse_One_Light() ).
Yup, real specular reflection (not the faked highlights) is taken into
account! I've been having some fun with that lately, by disabling the
irradiance cache and taking samples for every pixel. It's slow, but
beautiful and funn :) The fun part is that I HAVE written software that
lets me (and hopefully you sometime) render in parallel, so I don't go
crazy waiting for the render :)
George
Date: 12 Dec 2004 10:15:00
Message: <web.41bc5b194485a722e0b13d0@news.povray.org>
> Andrew.
Yup, as long as both machines use the same irradiance cache to render their
subimages, and you turn off always_sample, you wont get any tiling
artifacts (*).
*If your shared irradiance cache is not sufficiently filled, however,
POV-Ray will still take samples if it can't find any to reuse, even if
always_sample is set to off. This would have the effect of not using the
same irradiance data for each tile, and may lead to the tiling artifacts
depending on how often POV-Ray is forced to sample during the final pass.
Ideally you want the caches to be the same exactly, but even having the
caches close but not matched suppresses the tiling artifacts to varying
degrees (sometimes greatly).
If you render in parallel simply by controlling POV-Ray with an external
script (using +SC/+EC/+SR/+ER), it will do a radiosity pretrace for each
tile, using only the image dimensions that tile occupies. This would make
the irradiance data used per tile drastically different, leading to the
dreaded tile artifacts. It would also by default throw away all the rad
data used after every tile.
In the parallel software I've written (which involves a patch to POV-Ray), I
do the pretrace only once per machine using the full image dimensions. (I
preserve the rad data internally after the pretrace and between individual
tiles). Then I crank out each tile (subimage) without doing any partial
image pretraces for the tiles. This greatly suppressed those tile
artifacts! I'm pleased and encouraged by this, and I want to take it
further.
As it stands now, each machine is doing duplicate work in the pretrace. The
next thing I want to try is to have each machine render a slightly
different pretrace (using jittered, or stratified sampling), then have all
the machines upload their results to the Client, combine them, and send the
full cache to each machine in preperation for the real rendering (the
tiles). Assuming
sending the rad data does not take too much time, this would be a
significant speedup over the current approach!
George
Date: 12 Dec 2004 10:43:49
Message: <41bc6735$1@news.povray.org>
> scene space).
OK. Whereas without that step, you would fill up one corner of the cache
first, potentially meaning other parts don't have the influence they should?
>>radiosity?
> gather
Right. But when I ment was, there's a keyword (roughness?) which
controls the angle at which light affects the surface. I was trying to
figure out whether the rad calculations take this into account.
Mmm... sounds interesting.
Although... I suspect photon maps are faster. ;-)
Actually, I suppose you could program POV-Ray to try to illuminate an
entire scene with photon maps. I imagine that would go real slow,
compute a lot of photons you can't see, and generally not look so great.
(Does photon mapping work for a depth of more than 1?)
Andrew.
Date: 5 Jan 2005 15:37:36
Message: <cjameshuff-795FD3.15373405012005@news.povray.org>
In article <41bb5a4c$1@news.povray.org>,
 Andrew the Orchid <voi### [at] devnull> wrote:
> I did download the source once - I wanted to find out what a Sturmian
> root solver is, and how it works. I was eventually forced to give up,
> because it made no sense at all.
Heh...probably not the best way to go about it. Try this:
http://shadowfax.homelinux.net/cs275/
http://tag.povray.org/
Date: 5 Jan 2005 15:58:49
Message: <cjameshuff-5997A2.15584705012005@news.povray.org>
In article <41bc6735$1@news.povray.org>,
You're asking whether the parameters controlling how lighting falls off
as angle to the surface changes control the weighting of the radiosity
samples? As far as I know, no...it uses a plain ol' Lambertian falloff,
where the point weighting or distribution is done according to the
cosine of the angle to the surface normal. That is, it assumes the
surface is perfectly diffuse. This is usually a good enough
approximation for things radiosity is used for.
The parameter you're thinking of is probably brilliance, which modifies
the Lambertian falloff by raising it to a power...the falloff is
pow(cos(angle), brilliance). As far as I know, the sample rays will
"see" the effects of brilliance on other surfaces, but their weighting
will be unaffected by it.
(Someone should probably check whether the "too bright" problem of
highlights still applies...)
What you describe is "global photons". Possible, can very accurately
simulate actual physical effects which are otherwise difficult or
impossible, but extremely memory hungry and not really efficient.
Multi-pass techniques might be useful...shoot a few million photons, do
a render pass with the radius of effect of each photon limited (get a
really dim, spotty picture), and continue to shoot photons and add the
results together until you get a final picture. Jitter each pass
slightly, and you get some antialiasing or focal blur in the bargain.
It wouldn't be very useful if it didn't. ;-)
You can actually specify separate max_trace_level and adc_bailout for
photons. If you don't, the values specified for rendering are used.
Date: 5 Jan 2005 16:26:50
Message: <41dc5b9a$1@news.povray.org>
Seems that WinOsi does something similar : http://www.winosi.onlinehome.de/
But indeed, it is very slow... But then it's supposed to be very
accurate as well...
Vincent
