POV-Ray : Newsgroups : povray.advanced-users : Speaking of Mathematics Server Time
15 Jun 2026 16:17:03 EDT (-0400)
  Speaking of Mathematics (Message 1 to 7 of 7)
Subject: Speaking of Mathematics
Date: 6 Dec 2004 14:01:32
Message: <41b4ac8c$1@news.povray.org>
Someone posted a scene involving a spline. It interested me, I played
with it.... I liked it... it was neat, I hadn't messed around with
splines much in the past, but natural spline seems to be nice.
Anyway, the critter (ever endearing spline critter, that is) inspired me
to make some sort of arbitrary_object_sweep type object. I played around
with it some more, banged my head against a few dozen brick walls, and
finally threw up my hands.
All I wanted to do was take 2 points, get a vector, normalize it, and
calculate the X,Y and Z rotations to reorient it..
this is what I had so far:
(d is the normalised vector
#local rx = degrees(acos(vdot(d, <0, d.y, d.z>)));
#local ry = degrees(acos(vdot(d, <d.x, 0, d.z>)));
#local rz = degrees(acos(vdot(d, <d.x, d.y, 0>)));
But... it still doesn't seem quite right.
~Mike
Subject: Re: Speaking of Mathematics
Date: 6 Dec 2004 17:20:55
Message: <41b4db47@news.povray.org>
I'm not sure exactly what you were trying to do here (I'm sure there's logic
to it but I'm just not following it), but chances are after you do the
rotate rx*x (if that's what you're doing), the ry and rz rotations are no
longer useful for the object's new position.
Another thing to consider is that only two rotations should be needed to
make an object point in a certain direction. (This is because a direction
can be represented as a point on the surface of the unit sphere, and the
surface of a sphere is 2 dimensional.) For instance, if an object is
pointing in the positive x direction, a rotation between -90 and +90 degrees
around the z axis, followed by a rotation between -180 and +180 degrees
around the y axis is enough to orient the object in any direction. (A
rotation around the x axis could be done before either of these to have
control over how the object is rotated around the axis it's going to point
in.)
In any case, there's no point (besides educational reasons) to go through
all this work, since you can just use the Reorient_Trans macro in
transforms.inc to do what you want. (The macro doesn't use rotations, it
instead creates a matrix transformation; this is a more straightforward way
of approaching the problem if you understand the math.)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 7 Dec 2004 02:15:00
Message: <web.41b55745864be4ea301d03a70@news.povray.org>
> in.)
>  - Slime
I'm not adding anything new here, just saying that the Reorient_Trans marco
is good and it works.
Date: 7 Dec 2004 07:49:03
Message: <41b5a6bf@news.povray.org>
> in.)
>  - Slime
The macro did work for me, except one small problem: there's a "twist"
at one part in the spline that doesn't seem to make sense. Other than
that, it worked as expected. I might have been overthinking the problem
a bit, and .. yeah, it was a bit of an accedemic exercise for me, but,
It started to bug me that there seemed to be no solution. (The rotations
being null and void after a rotation occurred to me, but for some reason
I felt that the effect could be negated by some mathematical "magic"
What I had done, or think I had done was get the angles from the X, Y
and Z axes. The two other coordinates were left so the angle would be
calculated from the same pane (axis, oriented in the direction of the
remaining coordinates, that should get the angle from the plane, right?)
I've done similar stuff at work, but due to the nature of what I was
doing it was always in 2-space, and thus doesn't suffer the exponential
increase in problems that 3-space tends to.  (There's really only 1 axis
of rotation in 2D, unless you consider perspective transforms to be
another "axis")
~Mike
Date: 7 Dec 2004 17:50:00
Message: <web.41b632af864be4ea2d4ac62a0@news.povray.org>
I belive the twist occurs because the Reorient_Trans macro uses cross
products to get perpendicular vectors for it's new axes and there are
always two solutions that are perpendicular to any two vectors - one going
one way, and one going in exactly the opposite direction.
For some evil reason the macro chose the cross product vector in the
opposite direction - I have had this problem before too.
The only way I overcame it (but not the only way to fix the problem) was
that I designed the shape (or spline or whatever) to be fixed in one axis
(kind of).
For example, I made sure the shape never crossed the positive z axis and
stayed in the negative z axis area. I believe the direction changed when I
crossed the z axis.
What I have said does not give a solution to the problem but I hope it give
some insight into why the problem is occurring.
Nathan
Date: 8 Dec 2004 08:06:33
Message: <41b6fc59$1@news.povray.org>
> (kind of).
> crossed the z axis.
> Nathan
That makes sense. The point where I'm seeing the twist is right where it
would cross +/- Z.
~Mike
Date: 8 Dec 2004 22:35:01
Message: <web.41b7c7a2864be4eac3fafbf50@news.povray.org>
> would cross +/- Z.
I suppose to fix it (maybe) you could create a modified version of
Reorient_Trans and when it does it's cross products, multiply one of them
by the sign of z so when z is positive, there is no change and when z goes
negative, one of the axis vecotrs gets reversed and the cross product
vector stays the same.
....or something like that.
Nathan
