POV-Ray : Newsgroups : povray.advanced-users : 3D mathematics question Server Time
17 May 2026 12:23:29 EDT (-0400)
  3D mathematics question (Message 11 to 18 of 18)
Subject: Re: 3D mathematics question
Date: 8 Nov 2004 17:59:35
Message: <418ffa57$1@news.povray.org>
Andrew the Orchid nous apporta ses lumieres ainsi en ce 2004-11-08
17:22... :
> Andrew.
> PS. Annoying that I have to put the underscores on those variable
> names... grrr!
Use Upercase then you don't need those underscores.
Date: 8 Nov 2004 23:34:44
Message: <cjameshuff-44B729.23344508112004@news.povray.org>
In article <418fe747$1@news.povray.org>,
 Tor Olav Kristensen <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Inverse trigonometric operations are slow.
In POV, the difference between an inverse trig operation and any other
operation is likely to be overwhelmed by the overhead of parsing the
script. Code that is simpler to parse is likely to be faster.
http://tag.povray.org/
Date: 9 Nov 2004 07:55:40
Message: <4190be4c$1@news.povray.org>
Yes, I know.
I thought it was a general mathematic question.
Tor Olav
http://subcube.net
http://subcube.com
Date: 9 Nov 2004 15:14:51
Message: <4191253b$1@news.povray.org>
>> names... grrr!
The idea is to use upercase for vectors and lowercase for scalars...
But yes, that would also work of course.
Andrew.
(I understand not being able to use "x", "y" and "z", but "t"? That's
not even *valid* as a token by itself...)
Also vaguely irritating is the need to wrap Boolean assignments with
brackets, but still...
Date: 9 Nov 2004 15:21:09
Message: <3j92p01fa2rf6oc4vj9g6t9h3g54id0c83@4ax.com>
On Tue, 09 Nov 2004 20:14:17 +0000, Andrew the Orchid <voi### [at] devnull> wrote:
http://www.povray.org/documentation/view/3.6.1/229/
  VECTOR_BUILT-IN_IDENT:
       x | y | z | t | u | v
and later
  2.2.1.4.3 Operators
and then try
#declare V=<1,2,3,4>;
#declare Vt=V.t;
ABX
Date: 9 Nov 2004 15:22:52
Message: <4191271c@news.povray.org>
> and later
>   2.2.1.4.3 Operators
> and then try
> #declare Vt=V.t;
Oh, sure... V.t is a perfectly valid expression. But - unlike "x" / "y"
/ "z", "t" by itself isn't a valid expression.
Date: 9 Nov 2004 15:29:12
Message: <2s92p0hivb564ku67h24vehqqnn6u6qi74@4ax.com>
On Tue, 09 Nov 2004 20:22:17 +0000, Andrew the Orchid <voi### [at] devnull> wrote:
Look later into "2.2.1.4.6 Built-in Constants"
All built-in vector identifiers never change value. They are defined as though
the following lines were at the start of every scene.
 #declare x = <1, 0, 0>;
 #declare y = <0, 1, 0>;
 #declare z = <0, 0, 1>;
 #declare t = <0, 0, 0, 1>;
 #declare u = <1, 0>;
 #declare v = <0, 1>;
ABX
Date: 9 Nov 2004 15:42:35
Message: <41912bbb$1@news.povray.org>
Well... you learn something every day... I never knew you could do that...
