POV-Ray : Newsgroups : povray.advanced-users : Perspective problem ... Server Time
26 Mar 2026 05:14:27 EDT (-0400)
  Perspective problem ... (Message 1 to 10 of 13)
Subject: Perspective problem ...
Date: 13 Aug 2004 19:52:31
Message: <411D61CD.8060607@yahoo.com>
Hi all,
I have a problem to generate w/ POV 3.5 an image of an existing
landscape. I got DEM data of this area, converted them to PNG files but
I have some problem to make the POV image like the reality.
The real view : http://mamaf.online.fr/Annecy/image13.htm
My image w/o angle option for the camera :
http://destroyedlolo.homeunix.org:8080/~laurent/sans_angle.jpg
and the same one specifying angle 38:
http://destroyedlolo.homeunix.org:8080/~laurent/angle_38.jpg
Has you can see, it seems far mountains appear flattened ...
Do you know a way to make my images more realistics ?
Thanks
Laurent
Subject: Re: Perspective problem ...
Date: 14 Aug 2004 03:16:29
Message: <411dbc4d$1@news.povray.org>
I guess your camara is too near. Try to increase the distance between
the camera and the mountains and lower the camera angle to keep roughly
the same display window.
This should make the near mountains smaller compared to the far ones.
Hope this helps,
Henry
Date: 14 Aug 2004 11:02:37
Message: <411e298d@news.povray.org>
if all else fails, scale 2*y or similar could help?
"destroyedlolo" <l_f### [at] yahoocom> wrote in message
news:411### [at] yahoocom...
> Hi all,
> Thanks
> Laurent
Date: 15 Aug 2004 06:43:06
Message: <411F4BC6.40302@yahoo.com>
I'm not so sure because It will also rise the 1st plan hill.
Anyway, I wander what is wrong there, why I have a so different result
in POV compared to the reality ...
Bye
Laurent
Date: 15 Aug 2004 06:58:00
Message: <411f41b8@news.povray.org>
First, it can be supposed that the camera position, angle and look_at are
different in the photo and in your POV-Ray scene.
Second, keep in mind that the maximum height of a POV-Ray height_field is
always, at its maximum, equal to 1. Also, its length and width are always 1.
This may not be the same as in the DEM specification. If the DEM files use
real-life dimensions, for instance, then the converted scene should be
scaled accordingly :
scale <DEM_size_x, DEM_size_y, DEM_size_z>
Of course, the camera should then be placed also accordingly.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 16 Aug 2004 05:20:01
Message: <web.41207b10e6dfd373e5987fa60@news.povray.org>
As it's not my own photo, I'll take another one this afternoon (if the
weather is not too cloudy) and I will provide also information given by my
camera.
I think it's OK also because I set :
- DEM_size_x and DEM_size_z accordingly to the size of my DEM file,
- DEM_size_y is set to 65535 as I use 16bits PNG file.
Anyway, I will provide also DEM datafile and script I use.
Bye
Laurent
Date: 16 Aug 2004 05:49:53
Message: <41208341@news.povray.org>
news:web.41207b10e6dfd373e5987fa60@news.povray.org...
It's not the size of the DEM file you need, but the size of the real thing
in meters (it's easier that way in any case).
For instance, if the terrain is supposed to be 2000m (width) x 2000m
(length) x 2341m (maximum height), the scaling should be <2000,2341,2000>.
Of course, this assumes that the maximum height in the DEM file is
translated as pure white in the height field, which may not be the case. It
really depends on how the heights are converted, i.e. what would be the
white value of a map from the Netherlands vs a map of the Himalayas...
G.
- Posters
Date: 16 Aug 2004 10:00:00
Message: <web.4120bd99e6dfd373e5987fa60@news.povray.org>
Sure.
My DEM file have a resolution of 75m by pixel and my files is 512x512
pixels.
So I set DEM_size_x and DEM_size_z to 512 * 75 = 38400.
The value of each dot of the DEM file is the real altitude in meters. For
example, Annecy's lac altitude is 444m so, the value of this point in 444
(red*256 + green).
As the maximum value for this 16bits value is 65535, I put 65535 as Y scale
Laurent
Date: 16 Aug 2004 10:32:20
Message: <4120c574@news.povray.org>
news:web.4120bd99e6dfd373e5987fa60@news.povray.org...
> (red*256 + green).
scale
Well, then if you're sure the conversion is correct (you can check this by
adding a vertical cylinder of known height to the scene) so it's just a
matter of finding the right camera position, angle and look_at values. It
should be quite accurate, taking into account that the map is low-def.
G.
- Posters
Date: 17 Aug 2004 04:40:01
Message: <web.4121c35fe6dfd373e5987fa60@news.povray.org>
Hi All,
First of all, Thanks to every body that help me ;-D
So, I took a photo from a know point :
http://destroyedlolo.homeunix.org:8080/~laurent/dscf0001.jpg
and I make trace :
http://destroyedlolo.homeunix.org:8080/~laurent/angle_30.jpg (with "angle
30")
http://destroyedlolo.homeunix.org:8080/~laurent/sans_angle.jpg (without
"angle")
and ... it's ok : I was confused because, due to numerical artefacts, cliffs
aren't "in the same place" and I though the 1st plan mountain was closer
Anyway, I'll make some other comparaison from a different point of view when
the weather will be better.
Thanks to all replied to me :-)
Laurent
