POV-Ray : Newsgroups : povray.advanced-users : Perspective problem ... Server Time
9 Jun 2026 17:49:01 EDT (-0400)
  Perspective problem ... (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Perspective problem ...
Date: 15 Aug 2004 06:43:06
Message: <411F4BC6.40302@yahoo.com>
Doppelganger wrote:
> if all else fails, scale 2*y or similar could help?
I'm not so sure because It will also rise the 1st plan hill.
Anyway, I wander what is wrong there, why I have a so different result
in POV compared to the reality ...
Bye
Laurent
Date: 15 Aug 2004 06:58:00
Message: <411f41b8@news.povray.org>
news:411### [at] yahoocom...
First, it can be supposed that the camera position, angle and look_at are
different in the photo and in your POV-Ray scene.
Second, keep in mind that the maximum height of a POV-Ray height_field is
always, at its maximum, equal to 1. Also, its length and width are always 1.
This may not be the same as in the DEM specification. If the DEM files use
real-life dimensions, for instance, then the converted scene should be
scaled accordingly :
scale <DEM_size_x, DEM_size_y, DEM_size_z>
Of course, the camera should then be placed also accordingly.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 16 Aug 2004 05:20:01
Message: <web.41207b10e6dfd373e5987fa60@news.povray.org>
As it's not my own photo, I'll take another one this afternoon (if the
weather is not too cloudy) and I will provide also information given by my
camera.
I think it's OK also because I set :
- DEM_size_x and DEM_size_z accordingly to the size of my DEM file,
- DEM_size_y is set to 65535 as I use 16bits PNG file.
Anyway, I will provide also DEM datafile and script I use.
Bye
Laurent
Date: 16 Aug 2004 05:49:53
Message: <41208341@news.povray.org>
news:web.41207b10e6dfd373e5987fa60@news.povray.org...
It's not the size of the DEM file you need, but the size of the real thing
in meters (it's easier that way in any case).
For instance, if the terrain is supposed to be 2000m (width) x 2000m
(length) x 2341m (maximum height), the scaling should be <2000,2341,2000>.
Of course, this assumes that the maximum height in the DEM file is
translated as pure white in the height field, which may not be the case. It
really depends on how the heights are converted, i.e. what would be the
white value of a map from the Netherlands vs a map of the Himalayas...
G.
- Posters
Date: 16 Aug 2004 10:00:00
Message: <web.4120bd99e6dfd373e5987fa60@news.povray.org>
Sure.
My DEM file have a resolution of 75m by pixel and my files is 512x512
pixels.
So I set DEM_size_x and DEM_size_z to 512 * 75 = 38400.
The value of each dot of the DEM file is the real altitude in meters. For
example, Annecy's lac altitude is 444m so, the value of this point in 444
(red*256 + green).
As the maximum value for this 16bits value is 65535, I put 65535 as Y scale
Laurent
Date: 16 Aug 2004 10:32:20
Message: <4120c574@news.povray.org>
news:web.4120bd99e6dfd373e5987fa60@news.povray.org...
> (red*256 + green).
scale
Well, then if you're sure the conversion is correct (you can check this by
adding a vertical cylinder of known height to the scene) so it's just a
matter of finding the right camera position, angle and look_at values. It
should be quite accurate, taking into account that the map is low-def.
G.
- Posters
Date: 17 Aug 2004 04:40:01
Message: <web.4121c35fe6dfd373e5987fa60@news.povray.org>
Hi All,
First of all, Thanks to every body that help me ;-D
So, I took a photo from a know point :
http://destroyedlolo.homeunix.org:8080/~laurent/dscf0001.jpg
and I make trace :
http://destroyedlolo.homeunix.org:8080/~laurent/angle_30.jpg (with "angle
30")
http://destroyedlolo.homeunix.org:8080/~laurent/sans_angle.jpg (without
"angle")
and ... it's ok : I was confused because, due to numerical artefacts, cliffs
aren't "in the same place" and I though the 1st plan mountain was closer
Anyway, I'll make some other comparaison from a different point of view when
the weather will be better.
Thanks to all replied to me :-)
Laurent
Date: 17 Aug 2004 05:41:46
Message: <4121d2da$1@news.povray.org>
news:web.4121c35fe6dfd373e5987fa60@news.povray.org...
> and I make trace :
> 30")
> "angle")
It's certainly looking better and quite accurate. Too bad that the DEM
resolution is so low. I wonder if it would look better without the smoothing
in fact (the black outlines are artifacts). With some fog, and realistic
textures and sky, it could be pretty close to the real thing.
Note that with the default "direction 1*z", "without angle" is actually 67
degrees : direction_length = 0.5 * right_length / tan(angle / 2)
It's just that using angle instead of direction may give a more intuitive
control of the camera.
G.
- Posters
Date: 17 Aug 2004 06:15:25
Message: <4121dabd@news.povray.org>
By the way, those renders are apparently suffering from the normal
inversion problem in POV-Ray. For more details and workarounds, see:
http://tag.povray.org/povQandT/SmoothTriangleArtifact/index.html
Date: 18 Aug 2004 04:15:00
Message: <web.41230fb0e6dfd373e5987fa60@news.povray.org>
Hi Gilles,
> > and I make trace :
> > 30")
> > "angle")
And I have also discover some "scanning noise" on some area (oblique lines
close to some mountains). Unfortunatly, it's the better sources I found
that is not too expensive (30 Euro for all France area in 75 meters
resolution). Otherwise, I have to by DEM data from french IGN institute it
cost more money and I have to pay for every area I need.
As you can see my script
http://destroyedlolo.homeunix.org:8080/~laurent/Lac_SlMap.pov is very
simple : my goal there was only to find if I can generate something
acceptable using POV and my DEM. Now, I will play w/ textures to improve
the result and, I hope, hide scanning noise.
Thanks and regards,
Laurent
