POV-Ray : Newsgroups : povray.advanced-users : Isosurface question Server Time
19 Dec 2025 12:46:38 EST (-0500)
  Isosurface question (Message 1 to 10 of 12)
Subject: Isosurface question
Date: 20 Jul 2004 16:31:23
Message: <40fd811b@news.povray.org>
Isosurfaces... wonderful things, aren't they?
At the present moment, I have one that's going increadibly slowly.
That's probably because of the huge max_gradiant required to draw it.
But it surely doesn't help that I have to explain the function I want
POV-Ray to draw in a very inefficient way...
Suppose I have a macro like this:
#macro Fn1(x, y, z)
   #declare A = sin(x) * cos(y) * tan(z);
   #declare B = sqrt(x*y / z);
   #declare C = exp(log(x)*y - z);
   (A*B - C)*(tan(A+B)-log(C))
Now, suppose I wanted to draw an isosurface of that. (I completely made
up the function - I imagine it's not very interesting to look at!) The
only way I can think of to draw it is something like this:
#declare Fn1 =
   ( (sin(x) * cos(y) * tan(z))*sqrt(x*y / z) - exp(log(x)*y - z) ) *
(tan(sin(x) * cos(y) * tan(z) + sqrt(x*y / z)) - log(exp(log(x)*y - z)) )
Notice how A, B and C have to be calculated *TWICE*...
Is there any way round this??
Andrew @ home.
Subject: Re: Isosurface question
Date: 20 Jul 2004 17:49:55
Message: <opsbghm7g8cs6ysw@news.povray.org>
On Tue, 20 Jul 2004 21:28:14 +0100, Andrew C on Mozilla <voi### [at] devnull>
wrote:
> #declare Fn1 =
Something like this:
#declare Fn1_Aux =
function ( A, B, C ) {
#declare Fn1 =
function {
	Fn_1_Aux( sin(x)*cos(y)*tan(z), sqrt(x*y / z), exp(log(x)*y - z) )
FE
Date: 20 Jul 2004 22:02:50
Message: <GqstUBAz6c$AFwBa@econym.demon.co.uk>
>#macro Fn1(x, y, z)
>#end
>#declare Fn1 =
>Andrew @ home.
I don't think so.
If you write
#declare A = function {sin(x) * cos(y) * tan(z)}
#declare B = function {sqrt(x*y / z)}
#declare C = function {exp(log(x)*y - z)}
#declare Fn1 = function {(A(x,y,z)*B(x,y,z) - C(x,y,z))
              *(tan(A(x,y,z)+B(x,y,z))-log(C(x,y,z)))}
I believe that POV still calculates A B and C twice. It certainly takes
quite a bit longer to render the surface when it's written this way than
when you write
Mike Williams
Gentleman of Leisure
Date: 21 Jul 2004 07:04:47
Message: <40fe4dcf$1@news.povray.org>
In article <GqstUBAz6c$AFwBa@econym.demon.co.uk> , Mike Williams
> when you write
You can "use" the sum/prod functions to create temporary real variables.
    Thorsten
e-mail: tho### [at] trfde
Date: 21 Jul 2004 08:42:52
Message: <40fe64cc$1@news.povray.org>
> #macro Fn1(x, y, z)
> #end
> #declare Fn1 =
Yes. I once presented a solution to this.
It's halfway down in this message:
http://tinyurl.com/3f642
http://news.povray.org/povray.text.scene-files/message/%3C3fbe6e34%40news.povray.org%3E/#%3C3fbe6e34%40news.povray.org%3E
"My favourite isosurface (see p.b.i. for image)", 21. Nov. 2003
There's source code and more information in the rest of that thread:
http://tinyurl.com/6glf6
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.3fbbe555cd7b5c811235fd70%40news.povray.org%3E
Started by Alex Kluchikov 19. Nov. 2003
Tor Olav
http://subcube.net
http://subcube.com
Date: 21 Jul 2004 12:07:12
Message: <40fe94b0@news.povray.org>
Hmmm... That looks suspicious.
Are you aware that you are using the base 10 logarithm here ?
Use ln(x) for the natural logarithm.
Tor Olav
http://subcube.net
http://subcube.com
Date: 21 Jul 2004 16:45:59
Message: <40fed607$1@news.povray.org>
Oh, yeah, sure... it's not a real function, I just typed randomly to
make an example.
Andrew @ home.
Date: 21 Jul 2004 17:01:12
Message: <40fed998$1@news.povray.org>
>> #declare Fn1 =
Aaaahhhh.... I seeeee..... If a pass a variable into a second function,
POV-Ray calculates the value to pass ONCE, and then passes it, and it
can then be used multiple times within the second function... excellent!
The *real* function I want to render is recursive... POV-Ray reports
412K tokens. (!!) If I can figure out how to do it this way, it will
hopefully parse raster and render lots faster too... (Will probably have
to use the file-I/O directives to write an SDL file, then #include it
back in.)
Thanks for that!
Andrew @ home.
Date: 21 Jul 2004 21:49:03
Message: <40ff1d0f$1@news.povray.org>
Yes, you've got it.
> back in.)
In this post you can find macros that build a function
recursively:
http://tinyurl.com/5d473
http://news.povray.org/povray.text.scene-files/message/%3C3C9F86D5.778C126F%40hotmail.com%3E/#%3C3C9F86D5.778C126F%40hotmail.com%3E
"Code for NURBS surfaces as mesh2{} objects ", 25. Mar. 2002
(Look at the DeCasteljau_U() and BlendUFunction() and macros.)
First I had special versions of these macros that wrote the
function to a SDL file, but for higher order NURBS functions
this quickly became ugly (i.e. HUGE files). So I let POV-Ray
assemble these functions directly.
I guess that you are working on your fractal functions. If you
don't want to generate these functions recursively, then you
might find this post (and thread) interesting:
http://tinyurl.com/6nthl
http://news.povray.org/povray.advanced-users/message/%3CXns93AC374E6D9E5torolavkhotmailcom%40204.213.191.226%3E/#%3CXns93AC374E6D9E5torolavkhotmailcom%40204.213.191.226%3E
"Re: Use of povray functions to make fractals other than
"famous" Mandelbrot with same scalability? ", 2 Jul. 2003
> Thanks for that!
Just glad to help.
Tor Olav
http://subcube.net
http://subcube.com
Date: 22 Jul 2004 16:02:58
Message: <41001d72$1@news.povray.org>
>> function, POV-Ray calculates the value to pass ONCE, and then passes
>> it, and it can then be used multiple times within the second
> Yes, you've got it.
I tried it today in my lunch break. It *seems* to go very very much
faster this way - this WITH a higher max_gradient...
(I also figured out how to use the select() function to terminate the
iteration sequence as soon as possible. It actually make the render many
times SLOWER - until I changed it to return a positive number rather
than 0 when it "bails out". Then it was lots faster!)
>> have to use the file-I/O directives to write an SDL file, then
>> #include it back in.)
Yup.
> If you
Aahhh... use an *array* of functions... I wasn't sure if you could
actually do that... yes, that saves writing an include file and reading
it back... great!
>> Thanks for that!
> Just glad to help.
Maybe you should do it for a living. ;-)
Out of interest... is there a document anywhere that explains the messy
details of how POV-Ray's isosurface drawing system actually works?
(Other than the source code of course. :-P)
Thanks.
Andrew @ home.
