POV-Ray : Newsgroups : povray.advanced-users : Isosurface question Server Time
17 May 2026 13:40:09 EDT (-0400)
  Isosurface question (Message 11 to 12 of 12)
Subject: Re: Isosurface question
Date: 23 Jul 2004 12:17:05
Message: <41013a01$1@news.povray.org>
Andrew C on Mozilla wrote:
>> If you
>> don't want to generate these functions recursively, then you
>> might find this post (and thread) interesting:
>> http://tinyurl.com/6nthl
http://news.povray.org/povray.advanced-users/message/%3CXns93AC374E6D9E5torolavkhotmailcom%40204.213.191.226%3E/#%3CXns93AC374E6D9E5torolavkhotmailcom%40204.213.191.226%3E
> Aahhh... use an *array* of functions... I wasn't sure if you could
> actually do that... yes, that saves writing an include file and reading
> it back... great!
Yes that's one possible solution. But you can also make a
recursive macro that assembles the function directly without
using an include file. (Like the ones in my NURBS code.)
I guess that functions built the latter way will be faster,
because calling other functions within a function takes time.
>>> Thanks for that!
>> Just glad to help.
> Maybe you should do it for a living. ;-)
Hehe - I have been working as a math and electronics teacher
for the last half year. Now I'm looking for a new job.
> Out of interest... is there a document anywhere that explains the messy
> details of how POV-Ray's isosurface drawing system actually works?
> (Other than the source code of course. :-P)
Christoph Hormann has written a little about this:
http://www-public.tu-bs.de:8080/~y0013390/fast_iso/patch.html
On that page you'll also find a link to a news posting where
Ryoichi Suzuki gives a brief explanation of the algorithm he
used.
Apart from this I haven't seen anything.
- But reading a little about numerical analysis won't hurt :)
(Especially about root finding methods.)
Tor Olav
http://subcube.net
http://subcube.com
Date: 24 Jul 2004 04:21:16
Message: <41021bfc$1@news.povray.org>
>> reading it back... great!
Yeah, but the whole point is that passing a value to another function
allows me to reuse a number multiple times without recalculating it...
>>>> Thanks for that!
>>> Just glad to help.
Hmm... fair enough!
>> messy details of how POV-Ray's isosurface drawing system actually
>> works? (Other than the source code of course. :-P)
> used.
Right... so... essentially, POV-Ray starts with the segment of the ray
that's inside the isosurface's container, and then does a straight
binary chop looking for intervals where the sign changes (or where the
sign could potentially change, given the specified max_gradient). Is
that about right?
So POV-Ray doesn't use (and hence isn't bothered about), e.g., "flat"
areas in the function? (And presumably it won't be too upset about
single points where the function reaches infinity or isn't defined.)
I take it POV-Ray also doesn't save any of the points it's sampled and
reuse them in any way to speed up subsequent ray intersection tests?
(I presume max_gradient = 17 means that for every POV-unit you travel,
the function's value changes up or down by a maximum of 17? Yes? In that
case, I would imagine if the function evaluates to 1,287 at one
particular point, you can safely say that there are no intersections
within about 75 POV-units of that point. This would seem to be useful
information to reuse...)
(...but then... how to recall that information in an efficient way?... I
suppose you could generate a low-resolution voxel grid and mark all
areas which definitely DON'T contain part of the surface... but it looks
like that's exactly what Christoph's patch does!)
Thanks.
Andrew @ home.
