POV-Ray : Newsgroups : povray.advanced-users : Fractal isosurface Server Time
12 Oct 2025 19:54:09 EDT (-0400)
  Fractal isosurface (Message 1 to 7 of 7)
Subject: Fractal isosurface
Date: 20 Jun 2004 06:02:42
Message: <40d560c2$1@news.povray.org>
Hey folks...
I just made an isosurface in the shape of the quadratic Mandelbrot set. :-D
...but I did it the hard way! :-/
Due to the slightly bizzare way POV-Ray's macro feature works, you can
actaully write this:
#macro Cr() x #end
#macro Ci() y #end
#macro Zr(Iter)
   #if (Iter=0)
     Cr()
   #else
     ( Zr(Iter-1) * Zr(Iter-1) - Zi(Iter-1) * Zi(Iter-1) + Cr() )
#macro Zi(Iter)
   #if (Iter=0)
     Ci()
   #else
     ( 2 * Zr(Iter-1) * Zi(Iter-1) + Ci() )
#declare MaxIter = 1;
#declare Fn =
function {Zr(MaxIter) * Zr(MaxIter) + Zi(MaxIter) * Zr(MaxIter)}
...which is actually equivilent to
#declare Fn =
function { ( x*x - y*y + x)*(x*x - y*y + x) + (2*x*y + y)*(2*x*y + y) }
Nothing exciting there. However, replace MaxIter=1 with MaxIter=2 and
you get a more complicated expression... an expression too complicated
for me to write out here. But it's the expression for 2 iterations of
the complex quadratic map Z := Z^2 + C (in case that wasn't already
obviouse.)
The above fails when MaxIter=10 (but works for 9). Actually, you can
drastically speed up the parsing *and* rendering by using pow(..., 2) to
do the squaring. (I don't know how high you can go then - but easily
high enough for the resulting function to render indescribably slowly.)
You know how POV-Ray tells you the max gradient of an isosurface when it
finishes? Well, I ran POV-Ray for (I think) MaxIter=5. The reported max
gradient went into about 16 figures. (!!)
I seem to have fixed this by using min() and max() to limit Zr and Zi to
+/-4. This has no effect on the part of the image that POV-Ray is
actually trying to draw, but does prevent POV-Ray struggling to do
computations with enoumouse numbers. It also results in a drastically
smaller max gradient being reported.
(Actually, for MaxIter=5, POV-Ray says the max gradient should be 2,000.
This is unspeakably slow to render. However, rendering with 50 seems to
work just fine. Unless I'm very much mistaken, the max gradient near
where the actual surfaces are is much less; the function only changes
this rapidly round the edges, where the orbits have "escaped" to infinity.)
BTW, with the pow() speedup and the magnitude limiting, a 640x480 image
with no AA is currently rendering at about 350 pixels/sec on my AMD 1.4
GHz laptop. (...at least I *think* it's 1.4 GHz... might be lower... but
definitely over 1 Ghz.)
..."and WHY are you doing this?" I hear you cry.
Well, firstly I want to make a Mandelbrot hight field isosurface-style.
(*NO TRIANGLES*!) I can also do a similar thing with julibrot slices.
(See FractInt if you don't know what I'm talking about...)
But secondly, and more importantly, I want to do the same trick to
render 3D slices of the (4-dimensional) cubic Mandelbrot set(s). That
is, the Mandelbrot set(s) of the mapping
   Z := Z^3 - 3(A^2)Z + B
I've always wanted to know what it would look like... (Well, actually
I've *seen* it in a book, and it looks cool!)
Will post if I come up with any particularly interesting images.
Andrew @ home.
Subject: Re: Fractal isosurface
Date: 20 Jun 2004 07:36:26
Message: <40d576b9@news.povray.org>
Wouldn't using the internal mandelbrot pattern speed up things a bit?
Date: 20 Jun 2004 07:51:07
Message: <40d57a2b$1@news.povray.org>
Can we see a pic?
regards
Date: 20 Jun 2004 08:17:05
Message: <40d58041@news.povray.org>
Hell yeah!
...but there *isn't* one for the cubic Mandelbrot...
Andrew @ home.
PS. I just remembered about the "select" function... I think I may be
able to use this to truncate the computation of escaping orbits... the
isosurface function will be yet more complex, but might well go a tad
faster...
Date: 20 Jun 2004 08:18:25
Message: <40d58091$1@news.povray.org>
> Can we see a pic?
Yups. I plan to run a few renders overnight, and post the results
tomorrow (or their abouts).
Thanks.
Andrew @ home.
PS. Can you say "19 pixels/second"? :-S
Date: 20 Jun 2004 12:20:15
Message: <40d5b93f$1@news.povray.org>
> Can we see a pic?
There's now a 3D Julibrot slice in povray.binaries.images. (Not very
exciting, but took an extremely long time to render.)
Andrew @ home.
Date: 20 Jun 2004 19:01:22
Message: <40d61742@news.povray.org>
Cool pic nevertheless!
