POV-Ray : Newsgroups : povray.advanced-users : Parse weirdness Server Time
16 Jun 2026 13:09:17 EDT (-0400)
  Parse weirdness (Message 1 to 7 of 7)
Subject: Parse weirdness
Date: 6 Jun 2004 10:55:26
Message: <40c3305e$1@news.povray.org>
Here's an interesting one for you...
I've got a scene that won't parse; I get an error message half way
through one of the include files. Here's a snippet of the source:
#declare Thingy =
object
   sphere...
I get an error on the line with the open bracket. The error reads
Parse Error: Expected 'object or directive', { found instead.
...ok, so that's strange.
But is gets stranger... if I comment out a certain macro call, the error
dissapears! :-0 (The scene renders correctly. Trouble is, the bit I have
to comment out is the main animation control function!)
OK, so I've now spent about 2 hours trying to find a cause for this
bizzare behaviour... I eventually tracked down the source; there was an
#fclose command without a file handle.
This is really irritating. Why can't POV-Ray just issue and error
message if you reach the #end of a macro and the target for #fclose
hasn't been reached yet?
Andrew @ home.
Subject: Re: Parse weirdness
Date: 6 Jun 2004 16:00:02
Message: <40c377c2$1@news.povray.org>
In article <40c3305e$1@news.povray.org> , Andrew C on Mozilla
> #declare Thingy =
> object
>    sphere...
Without a complete but minimal scene, I don't think there is a way to help
you.
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Jun 2004 16:24:53
Message: <40c62095@news.povray.org>
> you.
The scene I have is *huge*. It will take you years to wade through it all.
If I can come up with something more minimal, I'll post it.
Thanks.
Andrew @ home.
Date: 8 Jun 2004 16:47:03
Message: <40c625c7$1@news.povray.org>
> #declare Thingy =
> object
>   sphere...
> ....ok, so that's strange.
cos it might not be in that macro, but in another macro?
'missing argument to fclose' might be a better message though
or maybe 'fclose missing argument defaulting to handle NNN'
> Andrew @ home.
that suggests a bracket mismatch in what you've commented out
maybe a ) instead of a } ??
easy to do
whats the syntax hi-lighting like in the editor you use?
try re-indenting that section ?
stephen
Date: 18 Jun 2004 09:45:19
Message: <40d2f1ef$1@news.povray.org>
>> help you.
OK, try this...
#macro Save(X, Y)
   #fopen Datafile "Test.data" write
   #write(Datafile, X, ", ", Y, ", ")
   #fclose
Save(7, 9)
object {sphere {+1*z, 0} pigment {red 1}}
light_source {+1*y, 1}
On the penultimate line, I get
   Parse Error: expected 'object or directive', found {
If you comment out the "Save(7, 9)" line, it renders fine.
The cause is the #fclose command - I forgot to type *which* file to
close! But rather than POV-Ray saying "you didn't say which file to
close", it gives me the (rather baffling) error indicated above. Given
that the mistake was in one include file and the error was reported in a
totally different include file, this took me a rather long time to track
down. :-S
I would suggest that if #fclose is followed by the end of the current
macro (or the end of the current file) this should at the very least
generate a warning.
(Personally I would feel happier if both #fopen and #fclose took
arguments in brackets like #read and #write do - but that would break
existing scenes.)
Thanks.
Andrew.
Date: 18 Jun 2004 21:36:30
Message: <40d3989e@news.povray.org>
> generate a warning.
The reason why it doesn't, in case you're not aware, is because your macro
could be used validly as follows:
Save(7,9) Datafile
And there may be obscure reasons that one would want to use a macro in this
way.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 19 Jun 2004 14:13:45
Message: <40d48259$1@news.povray.org>
>>generate a warning.
> Save(7,9) Datafile
> way.
Yeah, I figured as much...
There are also reasons why you might want a camera *inside* a non-hollow
object. But it still warns you about it. That's all I was suggesting -
that POV-Ray might give you a warning to say "hey man, did you really
mean this?"
Andrew @ home.
