POV-Ray : Newsgroups : povray.advanced-users : Normal distribution Server Time
17 May 2026 13:41:56 EDT (-0400)
  Normal distribution (Message 11 to 13 of 13)
Subject: Re: Normal distribution
Date: 7 May 2004 16:21:57
Message: <409befe5$1@news.povray.org>
-[Not quite correct]-
That's why I said "about 2^-52" not "2^-52". I wasn't going to go into the
details of floating point when it is rendered irrelevant by the fixed-point
form of the random number generator.
-[At most, it may be even less]-
It wouldn't be a 32-bit linear congruential generator if it didn't use
32-bits. I looked at the pov-ray source before I posted to make sure it was
a 32-bit generator, rather than the C library rand() function, which is
often only 15- or 16-bit.
-Chris
Date: 7 May 2004 17:31:06
Message: <cjameshuff-7537DE.16302607052004@news.povray.org>
In article <409befe5$1@news.povray.org>,
However, it may not be full period, meaning it may cycle through a
subset of that range. There are various choices for the different
coefficients that will give full period generators, and a small mistake
in choosing them will cause the generator to only cycle through some
numbers in the range before repeating.
POV-Ray's PRNG actually isn't a typical LCG generator. Such generators
are of the form:
r[n] = (r[n - 1]*a + c) mod m
POV-Ray's generator lets overflow wraparound take care of the modulus,
and then takes a subset of the bits of the resulting number for the
result. It uses "12345" for c, which makes me think the coder didn't put
much work into choosing the parameters. It uses a non-prime m due to the
way it works around computing a modulus, and I'm pretty sure that alone
makes it non-full period. Finally, and most important to this
discussion, it does a bit shift and bitwise AND with 0x7FFF on the
result of the LCG, and thus can not return numbers out of the range [0,
32767].
http://tag.povray.org/
Date: 16 May 2004 14:12:38
Message: <40a7af16@news.povray.org>
> -[because the means of different samples from a given population are
> normally distributed around the true mean of the population]-
> Yes - or rather, they approach a normal distribution as the number in each
> sample tends to infinity (the Central Limit Theorem)
Ah... I *knew* reading an entire book on statistics would be useful one
day! :-)
Andrew @ home.
