POV-Ray : Newsgroups : povray.advanced-users : 4D geometry Server Time
17 May 2026 15:23:21 EDT (-0400)
  4D geometry (Message 11 to 18 of 18)
Subject: Re: 4D geometry
Date: 4 May 2004 08:22:55
Message: <40978B66.6060708@informatik.uni-freiburg.de>
> Here's another question... what about slicing? If I choose a particular
> value for the 4th ordinate and fix that, can I *then* do the
> intersection on 3D? (Taking a slice is after all a set intersection
> operation - and I *believe* those things are associative...)
Yes, that would work, but only if you post the images (Can't imagine what
the slices would look like).
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 5 May 2004 10:00:58
Message: <cjameshuff-371C7C.10001305052004@news.povray.org>
In article <4096893b$1@news.povray.org>,
 Andrew C on Mozilla <voi### [at] devnull> wrote:
> > I never had problems with that, but the red/green glasses might have
> > helped a lot on that one. The problems I had were with too many lines
> > when having many 4D objects in the same "scene". I'm talking about 4D
> > tetris here.
> ??!?! :-| ?!/"\@_~??!
> Four *&$^ dimensional *@$^%# tetris *@*@#?!?! :-|
> OK, my head hurts... lol!
Tetris is arrangements of axis-aligned blocks, so 4D tetris wouldn't be
that hard. Viewing it on a 2D screen would be, though. Probably have to
view it as transparent 3D objects, colored to indicate offset along the
fourth axis. Even then, objects falling along the fourth axis would
appear to overlap in the 3-space slice...you would need multiple views
as well.
Hmm...rotating the pieces might be a bit mind-bending, even if it is
restricted to 90 degree turns. I'm pretty sure a 180 degree rotation in
4-space can mirror the 3-space slice, though I'm still having trouble
figuring out just what a 4-space rotation is.
http://tag.povray.org/
Date: 5 May 2004 17:00:35
Message: <409955f3$1@news.povray.org>
Interestingly, if you slice a normal cube in the right direction, you
get a hexagon.
Not many people know that...
Presumably if I slice a hypercube right I'll get a pyramid of some
kind... if I can rotate it right! :-S
Andrew @ home.
Date: 6 May 2004 16:09:30
Message: <409a9b7a$1@news.povray.org>
An image is now in povray.binaries.images. (Simple wireframe - shame I
can't show you the animation!)
Andrew @ home
Date: 6 May 2004 16:19:01
Message: <409a9db5$1@news.povray.org>
> Andrew @ home
simple, post the source and in files
we'll render and movie it :-)
stephen
Date: 6 May 2004 16:31:55
Message: <409aa0bb@news.povray.org>
>> Andrew @ home
> stephen
oops - source + ini files for movie frames
i'll write a .par for it
stephen
Date: 7 May 2004 04:17:15
Message: <409B4659.5030004@informatik.uni-freiburg.de>
I'll post the program to p.o-t on monday (forgot to bring it today.
And yesterday.)
Date: 8 May 2004 11:58:01
Message: <409d0389$1@news.povray.org>
> get a hexagon.
See povray.binaries.animations ;-)
Andrew @ home.
