POV-Ray : Newsgroups : povray.advanced-users : Difference between +A0 and +A0.0001? Server Time
11 Jan 2025 13:58:49 EST (-0500)
  Difference between +A0 and +A0.0001? (Message 1 to 6 of 6)
Subject: Difference between +A0 and +A0.0001?
Date: 25 Apr 2004 11:00:11
Message: <408bd27b@news.povray.org>
Am I mistaken that there is a difference? I started a print quality render
on a work computer before leaving this weekend. The image is not really
slow, but there are a lot of thin lines, so I tried the settings:
+A0.0001;  +AM1;  +R9;
Assuming that this would supersample any pixels with a visual difference. I
waited to see the first lines at the top of the image, and they looked bad.
They weren't thin enough to be missed, they just looked pixelated. Changing
to:
+A0;  +AM1;  +R9;
Supersampled even the white background, but the lines looked great. Am I
misunderstanding something about command line options?
 -Shay
Subject: Re: Difference between +A0 and +A0.0001?
Date: 25 Apr 2004 12:05:02
Message: <c6gnfv$9ot$1@chho.imagico.de>
> to:
> +A0;  +AM1;  +R9;
This is correct, '+a0.0' will supersample all pixels so it will be
really slow but you will also get good results of course.  For better
performance it is often a good idea to use adaptive antialiasing and a
threshold slightly above 0.  To avoid persistent artefacts you can try a
fairly strong jitter.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 25 Apr 2004 12:26:23
Message: <cjameshuff-AAA08F.12251925042004@news.povray.org>
In article <408bd27b@news.povray.org>, Shay <sah### [at] simcopartscom> wrote:
+A0 will supersample even when there is no difference in the initial
samples. +A0.0001 will only supersample if there is a difference greater
than the given threshold, and it's those zero-difference pixels that are
causing a problem.
It might be useful to have some way of forcing POV to supersample to
some level before going into adaptive mode, making it more likely to
find these pixels while wasting less time on fully supersampling pixels
which really don't need it.
http://tag.povray.org/
Date: 26 Apr 2004 11:20:00
Message: <408d28a0$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cjameshuff-AAA08F.12251925042004@news.povray.org...
| initial samples. +A0.0001 will only supersample if there is a
| difference greater than the given threshold, and it's those
| zero-difference pixels that are causing a problem.
Of course! I've got to admit that was a pretty brain-dead question.
Makes perfect sense now that I see it in print. Looking now, it's easy
to see that the AA on the right side of a thin line looks better than
that on the left.
| supersample to some level before going into adaptive
| mode, making it more likely to find these pixels while
Absolutely. I remember someone writing a patch like this once. Each ray
would check the center and the corners of each pixel before deciding
whether to super-sample.
Thanks, guys.
 -Shay
Date: 17 Jun 2004 20:28:20
Message: <40d23724@news.povray.org>
What about using focal blur with variance 0 and confidence 0.99999999999
instead?
Date: 9 Aug 2005 06:26:52
Message: <42f884ec@news.povray.org>
> 0.99999999999 instead?
Or what about just rendering at 2x the resolution with "normal" AA settings?
