POV-Ray : Newsgroups : povray.advanced-users : mapped trasparency Server Time
17 May 2026 12:25:48 EDT (-0400)
  mapped trasparency (Message 1 to 4 of 4)
Subject: mapped trasparency
Date: 18 Apr 2004 15:58:44
Message: <4082ddf4@news.povray.org>
Hallo to everybody.
Could anybody suggest an example to simulate a mapped trasparency plane or
sphere, knowing the value of the trasparency at specific position?
Thank you for your help.
        Gianluca Massaccesi
Consulenza Scientifica e Tecnologica
v. Banchieri, 27 - 40133 Bologna Italy
tel: 0039-51-566391
cel:    348-4758772
Subject: Re: mapped trasparency
Date: 18 Apr 2004 21:36:17
Message: <PE$PvBADzygAFw6+@econym.demon.co.uk>
Wasn't it Gianluca Massaccesi who wrote:
>Hallo to everybody.
If you can plot the transparency to an image, then you can use that
image_map to control a pigment_pattern
#declare transTex = texture {
  pigment_pattern {image_map {jpeg "tex.jpg" interpolate 2}}
  texture_map {
     [0 pigment {rgbt <0,0,0,1>}]
     [1 pigment {MyPigment}]
If you can express your knowledge of the transparency at a specific
position as a function then you can use that function to control a
pigment_pattern.
  pigment_pattern {function{abs(sin(x*4)+cos(y*8))*0.5}}
  texture_map {
Hint: It's much easier to manage things if you ensure that your function
returns values in the range 0 to 1 (hence my use of abs() and *0.5)
rather than trying to adjust the control values of the texture_map to
work with a function that returns values outside that range.
Mike Williams
Gentleman of Leisure
Date: 19 Apr 2004 02:25:41
Message: <408370e5$1@news.povray.org>
Thank you very much.
Could it be done with a discrete set of trasparency values, given a table of
those values related to their coordinates?
This could be easier for my purpose.
Gianluca
"Mike Williams" <nos### [at] econymdemoncouk> ha scritto nel messaggio
news:PE$PvBADzygAFw6+@econym.demon.co.uk...
> >Hallo to everybody.
or
>   texture_map {
> pigment_pattern.
>   texture_map {
> Mike Williams
Date: 29 Apr 2004 17:35:45
Message: <40917531@news.povray.org>
> >   texture_map {
Another approach which preserves "sine wave" appearance as opposed to
"scallop wave" is this:
pigment_pattern {function{(sin(x*4)+cos(y*8)+2)*0.25}}
