POV-Ray : Newsgroups : povray.advanced-users : Poser, OBJ, and Mesh 2 Server Time
10 Jun 2026 00:50:39 EDT (-0400)
  Poser, OBJ, and Mesh 2 (Message 1 to 6 of 6)
Subject: Poser, OBJ, and Mesh 2
Date: 7 Mar 2004 20:36:40
Message: <404bce28@news.povray.org>
Some of you may remember me from way back, well at lest three years ago
when I was a regular here. I've got a problem and I just can't seem to
get it solved.
I am using MacOS 9.1 and I have Poser 2.0, Python 2.2, and POV-Ray 3.5.
I've created a Python script that converts an OBJ file created in Poser
into a POV-Ray include file with a mesh2 object. I add the code to use
one of the default Poser textures in the POV-Ray scene file with UV
mapping turned on, and I get something that is just not right. I've
posted an image in p.b.i that shows the problem.
Does POV-Ray use a different origin that Poser 2 for the UV mapping? I'm
taking the same coordinates from the OBJ file and writing them into the
mesh2 object one a one for one basis.
Any clues would be appreciated.
Josh English
eng### [at] spiritonecom
Subject: Re: Poser, OBJ, and Mesh 2
Date: 7 Mar 2004 22:23:24
Message: <404BE70C.391C4D67@pacbell.net>
Was it that long ago already? Wow! Can't help with your problem but just
wanted to pop in to say hi.
Ken Tyler
Date: 8 Mar 2004 00:28:36
Message: <peiiLBAFFATAFwH5@econym.demon.co.uk>
>get it solved.
The "v" values from an OBJ file translate directly to mesh2
vertex_vectors, and the "vt" values translate directly to mesh2
uv_vectors.
The "f" values need to be shifted own by one, since POV starts counting
at zero but OBJ files start counting at one. E.g. the face "f 1 2 3"
becomes <0,1,2> but if you'd missed that shift I would have expected the
output to appear wrong in other ways than just the uv mapping.
If you think that you might have made some sort of silly mistake in your
Python code, I'd be happy to take a look at it.
Despite appearances, my reply address is valid.
Mike Williams
Gentleman of Leisure
Date: 8 Mar 2004 10:36:14
Message: <404c92ee@news.povray.org>
Hello. I've been unemployed since March 2001 and and I am now two months
away from getting my Masters of Arts in Education. I've missed this
group, and I hope to return in some form soon.
Josh
Date: 8 Mar 2004 11:45:32
Message: <404ca32c@news.povray.org>
>>get it solved.
> uv_vectors.
I found a few silly mistakes and it looks better. I've posted my Python
Code at http://www.spiritone.com/~english/code/objconverter.html with an
updated picture. As far as I can see I am still successfully moving the
indexes down by one for the face index, normal index, and uv index. The
only thing I can think of is that I've confused the order of the triples
in a line like:
f 1/221/1 2/219/2 3/216/3
I'm treating this as:
postion/uv/normal position/uv/normal position/uv/normal
I imagine that if the mesh2 format found a uv vector with three
components it would break down, similiarly if it got a normal vector
with only 2 components.
My Python script is very brute force.
Thanks,
Josh English
Date: 8 Mar 2004 12:02:23
Message: <404CA6ED.3050605@hotmail.com>
Brilliant idea. I like it.
	Andrel
