POV-Ray : Newsgroups : povray.advanced-users : Adding toon-style outlines to objects Server Time
17 May 2026 12:25:58 EDT (-0400)
  Adding toon-style outlines to objects (Message 1 to 2 of 2)
Subject: Adding toon-style outlines to objects
Date: 26 Feb 2004 16:38:15
Message: <403e6747@news.povray.org>
Hello,
An idea popped into my head about implementing a simple toon shader in
POV-Ray (actually, just outlining the object in the scene with a black
outline).
What I was trying to do was the same thing scanline renderers do when trying
to fake this effect - take an object, translate the vertices along the
normals a bit, then apply a black diffuse- and specularless texture to it.
This makes only the interior (or backside) of the object visible and
transparent while looking at it square-on.
So I thought I'd write up a simple scene, containing an outlined sphere,
using something like this:
sphere {0, 1
    texture {pigment {color red 1}}
sphere {0, 1.05
    texture {pigment {color rgbt 1}}
    interior_texture {pigment {color rgb 0}}
    no_shadow
Intiutively, this means that the front side of the outer hull would be
totally transparent while the interior would be completely black. The only
problem is, when i added a pure white background, the radiosity calculation
skipped the whole of the inner sphere when calculating ambient lighting -
resulting in the very same rendering as without radiosity.
Anyone know how to modify the textures in this scene to make radiosity work?
I tried raising the recursion_limit, but i guess it only handles reflections
and doesn't take transmitted rays into account.
    Thanks,
    -Klemen
Subject: Re: Adding toon-style outlines to objects
Date: 11 Jun 2004 18:55:01
Message: <web.40ca375a3444f533f5e060ef0@news.povray.org>
Hi Klemen,
The problem is that the interior texture isn't transparent at all (at least
to POV-Ray...if you change it to:
interior_texture {pigment color rgbt <0, 0, 0, .5>}
then your radiosity will show through.  The PROBLEM is, then your black
outline doesn't really work.
I did try translating the "inner" sphere by <0, .06, -.06> (i.e., towards
the camera) and it looks good, but that might not be the best solution.  It
works for the sphere, with this particular camera, at least.  Maybe a macro
to move things toward the camera would make it a viable answer?
Good luck!
~Dale
"Klemen" <She### [at] emailsi> wrote:
> Hello,
> outline).
> sphere {0, 1
> sphere {0, 1.05
>     no_shadow
>     Thanks,
>     -Klemen
