POV-Ray : Newsgroups : povray.advanced-users : JPG-output with povray for windows v3.5 Server Time
17 May 2026 17:59:27 EDT (-0400)
  JPG-output with povray for windows v3.5 (Message 20 to 29 of 49)
Subject: Re: JPG-output with povray for windows v3.5
Date: 19 Feb 2004 09:19:43
Message: <4034c5ff@news.povray.org>
Tim Nikias v2.0 <tim.nikias (@) nolights.de> wrote:
> I think he was attempting to add some humor into his reply: since we're
> dealing with POV-Ray and thus, mainly 16 to 32 bit images, 256 colors would
> be a loss, and thus, GIF would be "lossy" for saving the output-images.
  Then every existing image format is lossy because POV-Ray calculates
the color components as 32-bit floats. Converting them eg. to
8 bits-per-component or even 16 bits-per-component image (eg. PNG)
is lossy.
Date: 19 Feb 2004 10:59:37
Message: <4034dd69@news.povray.org>
In article <4034c5ff@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> is lossy.
I would not be surprised if floating-point colors were part of some TIFF
format specification ;-)
    Thorsten
e-mail: tho### [at] trfde
Date: 19 Feb 2004 13:56:56
Message: <403506f7@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Technically true, but since your eyes have a very difficult (if not
> impossible) time distinguishing more than 8 bits of color, one could
> argue differently too. :-)
  Actually for B/W images 8 bits can sometimes be too little, specially
when dealing with large areas of very slowly changing shades of gray.
Date: 19 Feb 2004 15:48:31
Message: <4035211f$1@news.povray.org>
To add to that: I'm on 32bit for my Desktop, because I'm seeing bands of
colors when using only 16bit with my raytraced images (which is hence the
reason why I output to 24bit BMP most of the time). Since Windows offers me
only 16 or 32, I'm on 32.
Tim
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 19 Feb 2004 15:59:01
Message: <40352395$1@news.povray.org>
me
And eventhough you are using 32-bit mode, you see only 24-colors, unless you
have some specialiced video card. I also agree that 8-bits/channel is way
too little with color gradations. And for editing purposes 16-bit/channel is
sometimes mandatory. Sadly there are not many (consumer grade) video cards
showing 48-bit colors.
Severi
Date: 19 Feb 2004 16:55:40
Message: <v3ca301hage8ai0djo6divhvsn364rifp3@4ax.com>
On Wed, 18 Feb 2004 21:33:09 -0800, Darren New <dne### [at] sanrrcom>
wrote:
>Christopher James Huff wrote:
>> it isn't lossy, it's just really limited in the number
>> of colors it can represent.
>True, it depends on how many colors you're trying to represent. Given
>this is a ray-tracing newsgroup and GIF only supports 256 colors, I
>think it's safe to say it's lossy. ;-)
It's close to black & white, isn't it?
Andreas
Date: 19 Feb 2004 19:13:43
Message: <cjameshuff-F3536F.19142019022004@news.povray.org>
In article <4035211f$1@news.povray.org>,
Why BMP? You should use PNG...aside from the compression, it stores the
gamma value in the file, and lets you save images in 48 bit...16 bits
per channel, or 65536 levels per channel instead of 256.
http://tag.povray.org/
Date: 19 Feb 2004 19:19:08
Message: <cjameshuff-5524B6.19194519022004@news.povray.org>
In article <40352395$1@news.povray.org>,
"32 bit color" is just 24 bit color with an extra byte every 3 bytes.
This keeps memory nicely aligned, but contributes nothing to the color
precision. It's just a memory/speed tradeoff, though the fourth value is
often used for things like alpha.
You don't necessarily need to view it to get a benefit from it.
Date: 19 Feb 2004 19:27:58
Message: <cjameshuff-E5DC6E.19283519022004@news.povray.org>
In article <4034dd69@news.povray.org>,
There is...96 bits per pixel. Not often used for this reason...a
1600x1200 image would take 21MB. There are other formats that use about
half as much. They do so with less precision, but 32 bits per component
is overkill for most things.
Date: 19 Feb 2004 20:15:03
Message: <40355f97$1@news.povray.org>
Well, for one, I can use BMP directly as wallpaper on my Windows OS. I don't
need more than the 24bit it comes with, that's another. And, most of the
time, the image gets converted to JPG anyway, either for posting on these
very newsgroups that I've got open and running almost every hour my PC is
running, or for my website. Only seldomly do I need other formats, like for
a book publishing. And even then, 24bit was sufficient so far.
So, though your points are valid and true, I'm too lazy. :-)
But I've never really understood that gamma issue with PNGs... How exactly
does it work, and how is it supposed to work? I've heard that it stores the
gamma value it has been made with, and a viewing app would adjust the gamma
to compensate for different screens, but does it really work?
"Tim Nikias v2.0"
