POV-Ray : Newsgroups : povray.advanced-users : Save photon map as an image? Server Time
29 Sep 2024 04:18:58 EDT (-0400)
  Save photon map as an image? (Message 1 to 8 of 8)
Subject: Save photon map as an image?
Date: 12 Feb 2004 10:23:11
Message: <402b9a5f$1@news.povray.org>
Can anyone suggest how to save a photon map as a
separate color image without any other lighting effects?
I have a surface which needs to be diffuse and white for
other reasons but this obscures the caustics.  I thought
there might be a way to open a saved photon map
as an image in Photoshop or- ??
Any advice much appreciated.
Thanks,
Bo Gehring
Subject: Re: Save photon map as an image?
Date: 12 Feb 2004 10:51:42
Message: <402ba10e$1@news.povray.org>
"louis gehring" <bog### [at] verizonnet> wrote in message
news:402b9a5f$1@news.povray.org...
No, not that I've ever heard of anyway. Only thing you might be able to do
is rerender with the loaded photon map and comment out any lights to see it
better. Might look okay then, but I'm not 100% certain.
Bob H.
Date: 12 Feb 2004 11:06:03
Message: <m8ksf1-c98.ln1@triton.imagico.de>
A photon map is a 3d data structure, there is no way to save it as an
image file.  If you want to get a render of the scene with only photon
based illumination you can try to render without light sources and a
loaded photon map as Bob suggested.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 12 Feb 2004 11:46:49
Message: <402badf9$1@news.povray.org>
That worked.  Thanks!
Bo Gehring
"Hughes, B." <omn### [at] charternet> wrote in message
news:402ba10e$1@news.povray.org...
it
> Bob H.
Date: 12 Feb 2004 11:48:49
Message: <402bae71@news.povray.org>
> image file.
  I think he is confusing photon maps with lightmaps (common rendering
technique for fast precalculated lighting).
  Theoretically you can certainly create lightmaps *from* photon maps, but
unless the renderer you are using supports lightmaps they will not be of
any help (POV-Ray does not support them because it would require UV-mapping
for all objects; lightmaps are most useful in scanline rendering).
Date: 12 Feb 2004 11:57:55
Message: <Xns948DB6C063518seed7@news.povray.org>
Not related to the thread, but would this mean that the datastructure
could be converted in a density_file (df3)?
Ingo
Date: 12 Feb 2004 12:24:03
Message: <1rosf1-317.ln1@triton.imagico.de>
To get usable data from this the density file would need an extreme
resolution (and therefore file size).  And most of it would contain no
data at all, only those grid positions where one or more photons are
located.
Date: 12 Feb 2004 16:04:31
Message: <cjameshuff-0F170B.16045212022004@news.povray.org>
In article <Xns948DB6C063518seed7@news.povray.org>,
Not as a DF3 file. DF3's store uncompressed, filled voxel data. An 8x8x8
DF3 contains 512 voxels, each at a specific point in an 8x8x8 3D
lattice. Technically you could create a voxel field from the photon
data, but you wouldn't be able to store it...it'd be too big at any
reasonable resolution, or blurred out at too low a resolution to be of
any use. A 256x256x256 resolution voxel field would consume 16MB at one
byte per voxel. 1024x1024x1024 with 24-bit RGB? 3GB. And in a field 10
units on a side, that's a distance of just under 0.01 between photons.
Now, I'm working on an extended density format that allows sparse data,
storing the location and value of each point rather than a value for
every possible point. The files would be big, and there would be loss in
location precision due to the use of integer coordinates, but it would
be far more practical. Unfortunately, there currently are no programs
capable of reading or writing this format, and the format itself isn't
fully defined...I'll be starting a thread in *.programming on the
subject soon.
http://tag.povray.org/
