POV-Ray : Newsgroups : povray.advanced-users : Object Oriented POV code Server Time
10 Jun 2026 00:54:06 EDT (-0400)
  Object Oriented POV code (Message 1 to 10 of 179)
Subject: Object Oriented POV code
Date: 7 Feb 2004 18:45:01
Message: <4025787d@news.povray.org>
I've decided to have a go at creating a fairly complex scene file based on lots
of autonomous entities with simple ai and physics. So, I've been figuring out
tricks for writing pov scene code in an object-oriented manner.
i.e. there basically needs to be some way of defining classes (I won't do
inheritance), with member variables and functions. And some system of creating
and destroying these on the fly. Oh, and persistent variables.
Now, I think I've actually figured out a pretty decent way to do all this, just
using the SDL. I'm happy to give details but I don't want to clog up this
message with all that info.
But anyway, the reason I'm posting: I was just wondering has anyone done this
before? Either within the SDL, or as a modification to pov to support simple
data structures and function callbacks?
Oh, and do you think it should be oriented or orientated? ;)
Tek
www.evilsuperbrain.com
Subject: Re: Object Oriented POV code
Date: 7 Feb 2004 23:23:37
Message: <cjameshuff-EF7F20.23235207022004@news.povray.org>
In article <4025787d@news.povray.org>, "Tek" <tek### [at] evilsuperbraincom>
Never actually done it, but I've considered doing something based on
arrays...it'd be hellishly complex and inefficient. And it was limited
to passive data structures, not really anything like objects.
Oriented. "Orientated" is a synonym, but sounds odd and I've never seen
a "professional" source use that spelling in relation to object
orientation. "Oriention" isn't a word though, so orientated is probably
the original spelling.
http://tag.povray.org/
Date: 8 Feb 2004 03:02:50
Message: <4025ed2a$1@news.povray.org>
Well that's kinda similar to what I'm thinking.
my theory is I interface to everything via macros. So if I want to get the
"position" member of an object that I have "pointer" to, this would actually
work by using indeces, not pointers, and having an array of positions. But I can
write the code via macros so it looks sorta like it's using structures!
The problem with this is that I need one set of arrays for each different class
of object/structure. And those arrays would need to be long enough to hold every
instance I would be likely to create. Still, that's not a big problem.
The other, much more cunning, trick is to be able to have functions (actually
macros) invoked differently for different objects. e.g. lets imagine I have lots
of classes that have the same basic structure, but different functions (e.g.
good guys and bad guys with different AI routines). The thing is I want to be
able to invoke different functions according to what class of object I'm
accessing *without needing a big switch statement handling all classes*.
My cunning trick is to store, as a parameter in the "structure", the name of the
macro I want to invoke for this object. e.g. "GoodGuyUpdate". Then I can save
this string out to a scratch file with a string of parameters (which will be the
same since this is just an implementation of a virtual function, if you want to
look at it like that). So we get a scratch file saying
"GoodGuyUpdate(myObject,deltaTime)" or something. Then just include that scratch
file to invoke it!
It's somewhat cumbersome, but it would certainly work.
In fact, I think I'm gonna start building this framework now :)
Tek
Date: 8 Feb 2004 07:30:50
Message: <40262bfa$1@news.povray.org>
For anyone who's interested, I've just put the first building block of my
technique in p.b.s-f.
Tek
"Tek" <tek### [at] evilsuperbraincom> wrote in message news:4025787d@news.povray.org...
lots
just
> Tek
Date: 9 Feb 2004 03:15:38
Message: <vcge20l4jv2o4ikggniv4cf1hgmm5rrvbh@4ax.com>
On Sat, 7 Feb 2004 15:45:04 -0800, "Tek" <tek### [at] evilsuperbraincom> wrote:
http://news.povray.org/povray.advanced-users/19907/
ABX
Date: 9 Feb 2004 04:19:47
Message: <402750b3$1@news.povray.org>
Ooh that's a nice technique! You mind if I borrow it? :)
Tek
"ABX" <abx### [at] abxartpl> wrote in message
news:vcge20l4jv2o4ikggniv4cf1hgmm5rrvbh@4ax.com...
> ABX
Date: 9 Feb 2004 18:14:03
Message: <4028143b$1@news.povray.org>
I had a try at doing some code for data aggregation, not dealing with
functions. I wanted to do something general to construct, manipulate,
save, load print and destroy any aggregation of data, but I stopped when
I realized that I was not able to query the type of my data (hence no
print or save).
Just in case it would give you any idea, I post my files on p-t-scene-files.
JC
Date: 10 Feb 2004 00:07:08
Message: <402866fc$1@news.povray.org>
Hmm... the array of arrays idea is interesting. In my system I never need to
query the type of data (it will only be accessed by code that knows what to
expect). It certainly has some potential.
Thanks!
Tek
"JC (Exether)" <no### [at] spamfr> wrote in message news:4028143b$1@news.povray.org...
> print or save).
> JC
lots
out
creating
just
this
Date: 10 Feb 2004 11:32:36
Message: <402907a4@news.povray.org>
lots
out
creating
just
this
simple
> Tek
My principal "object" is the #include file.  Each object definition,
including macros, variables, etc. can be placed in this file.
If you want a macro to use the object, just use the filename as a string
parameter:
#macro ObUser(iFile, oFile)
    #include iFile
    #open oFile
    #write oFile, Data
    #close oFile
I use this tactic frequently.  Macros that would otherwise use a large
number of parameters are greatly simplified by this method.  Macros,
functions, and primitives that might not otherwise be available as macro
parameters can be provided for this way.
#include files also carry one extra benefit: you can add descriptive
comments and variable names that make code reading easier
Try it some time.
Date: 11 Feb 2004 01:12:49
Message: <4029c7e1$1@news.povray.org>
Maybe I'm misunderstanding you, but how does having each object as an include
file help? Or do you mean have each class as an include file?
BTW, did you see the technique I posted in p.b.s-f? That sounds pretty similar
to what you're suggesting. It solves the problem of indirect function
invocation, but but I still haven't found a nice way of defining
structures/classes. Can your system do this?
Basically I want to be able to do things like this:
myMoveableObject = new Monkey; //Monkey is a class
myMoveableObject.move(deltaTime);
if ( myMoveableObject.position == invalid ) delete myMoveableObject;
Tek
"David Wallace" <dar### [at] earthlinknet> wrote in message
news:402907a4@news.povray.org...
> lots
> out
> creating
> just
> this
> simple
> > Tek
> parameter:
>     #include iFile
>     #open oFile
>     #write oFile, Data
>     #close oFile
> #end
> Try it some time.
