POV-Ray : Newsgroups : povray.advanced-users : Randomizing pattern functions Server Time
26 May 2026 13:40:07 EDT (-0400)
  Randomizing pattern functions (Message 1 to 6 of 6)
Subject: Randomizing pattern functions
Date: 5 Jan 2004 21:51:01
Message: <3ffa2295@news.povray.org>
I'm attempting to generate a macro that spits out an isosurface that
generates a boulder depending upon a seed. Then, I will take and write a
macro that spits them all out on a grid so that I can pick and choose from a
contact sheet.
I figured that translating a pattern would be like translating a pigment and
that randomly translating it's position would give me different forms.
However, I can't pass another parameter to a pattern function, so I'm not
sure how to get the translation inside of the pattern{} block.
Has anyone tried this kind of thing? Thanks!
-- >8 Code --
#declare f_rock1_1  =
function
 pattern
  wrinkles
#declare f_rock1_2  =
function
 pattern
  bozo
#macro rock1 (n)
 #declare R_ROCK1 = seed(n);
 isosurface
  function { (f_sphere (x, y, z, 1) + f_rock1_1(x, y, z) + f_rock1_2(x, y,
z) ) / 3 }
  max_gradient 5
  evaluate 5, 1, 0.2
  #ifdef (DRAFT)
   accuracy 0.1
  #ifndef (DRAFT)
   pigment
    granite
    color_map
     [0 rgb <0.7, 0.7, 0.7> ]
     [1 White ]
    translate <rand(R_ROCK1), rand(R_ROCK1)>
  #else
   pigment { color White }
- Respectfully,
Dan
"When it is not in our power to follow what is true,
we ought to follow what is most probable."
                                         - Rene Descartes
Subject: Re: Randomizing pattern functions
Date: 6 Jan 2004 00:35:55
Message: <iDTbvBAKjk+$EwQ6@econym.demon.co.uk>
>contact sheet.
I'd tend to do it by sticking the translation inside the isosurface {}
by variable substitution
(see http://www.econym.demon.co.uk/isotut/substitute.htm)
like this:
#macro rock1 (n,m)
 #declare R_ROCK2 = seed(m);
 #local R1=rand(R_ROCK2);
 #local R2=rand(R_ROCK2);
 #local R3=rand(R_ROCK2);
 isosurface
            + f_rock1_1(x+R1, y+R2, z+R3)
            + f_rock1_2(x+R1, y+R2, z+R3) )
             / 3 }
Note that you can't use rand() inside the isosurface function definition
itself.
Mike Williams
Gentleman of Leisure
Date: 6 Jan 2004 01:23:25
Message: <3ffa545d$1@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:iDTbvBAKjk+$EwQ### [at] econymdemoncouk...
<snip>
and
Ah, brilliant! I hadn't thought of it from that angle. Thank you!!!
Date: 11 Jan 2004 22:01:34
Message: <40020e0e@news.povray.org>
If you are going to generate a large number of rocks you might want to pass
an actual seed into the macro rather than just an integer.  That way you get
new rocks each time you call the macro.
from a
> >contact sheet.
and
> like this:
---- edited code ----
#declare rs = seed(4394); // Use your own number
 #macro rock1 (sd, sz)
 #local R1=rand(sd)*sz;
 #local R2=rand(sd)*sz;
 #local R3=rand(sd)*sz;
  isosurface
              / 3 }
> itself.
David Wallace
TenArbor Consulting
"Just in Time Cash"
http://www.tenarbor.com
Date: 12 Jan 2004 01:07:21
Message: <nEMqeCAOmjAAFwON@econym.demon.co.uk>
But that very fact makes it less appropriate for Daniel's original
purpose. He wanted to LOOK at a a large number of rocks, and then choose
a few that happened to look nice to use in a real scene. So it's more
appropriate to have a macro that produces the same rock when passed the
same parameters.
Mike Williams
Date: 12 Jan 2004 19:04:46
Message: <4003361e$1@news.povray.org>
news:nEM### [at] econymdemoncouk...
pass
get
> same parameters.
No matter what, though, Mike's way of translating it before it gets to the
function works. They're both good ideas depending upon the usage. For
example, David's idea would be great for automagically creating a rock bed.
