POV-Ray : Newsgroups : povray.advanced-users : image_map transparency vs. difference Server Time
9 Jun 2026 19:09:18 EDT (-0400)
  image_map transparency vs. difference (Message 11 to 11 of 11)
Subject: Re: image_map transparency vs. difference
Date: 14 Oct 2003 11:10:22
Message: <3f8c11de$1@news.povray.org>
"Christopher James Huff" <cja### [at] earthlinknet> wrote in message
news:cja### [at] netplexaussieorg...
> In article <3f8ad0f5$1@news.povray.org>,
>  "Scott Gammans" <dee### [at] yahoocom> wrote:
> It doesn't create a hole, the surface is still there, it is just
> transparent. This technique is a sometimes-useful hack, but does not
> have any actual effect on the geometry of the object.
Well yes, my choice of words was poor. I realize that there isn't an actual
CSG operation performed, but the effect to the viewer is essentially the
same: you now have a transparent area in the shape of the transparent area
in your image map.
> > The amount of
> > memory used jumped considerably, of course, but the average rendering
time
> > between the 1000x1000 and 4000x4000 image maps was essentially
unchanged. Is
> > that about right?
> It will be slightly slower due to more memory being accessed, but
> probably not by enough to reliably measure. Unless you run out of RAM
> and start swapping...
Which is what I'm seeing. Thank you very much for taking the time to
respond!
