POV-Ray : Newsgroups : povray.advanced-users : Radiosity Server Time
17 May 2026 17:32:31 EDT (-0400)
  Radiosity (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Radiosity
Date: 23 Jun 2003 16:44:35
Message: <3ef766b3@news.povray.org>
I have utterly utterly no idea why, but I had to do strange things to OE to
get this thread to appear! Anyway...
> > Does POV-Ray do *real* radiosity?
>   What is "real radiosity"?
>   Firstly, the exact meaning of "radiosity" is a specific algorithm where
> lightmaps are calculated projecting (usually with scanline rendering) the
> scene onto each surface of the scene. This algorithm has nothing to do
> with raytracing nor with light sources per se.
...which would render my initial assumption invalid. I clearly don't know
what I'm on about.
>   I suppose that you are using the term "radiosity" as meaning any
> global illumination algorithm. Even so, there's no such a thing as
> a "real" algorithm. There are several different algorithms, but we
> can't say any of them is more "real" than the other. They are all
> approximations, different ways of calculating a similar thing.
>   One algorithm can be "better" than another (by whatever criteria
> you happen to choose), but quality does not make it the "real" algorithm
> (and the other ones "fake").
Quite right.
> > According to my understanding (which may or may not be correct)
"radiosity"
> > algorithms start from the light source(s) and follow the paths of the
rays
> > forwards into the scene, eventually reaching the camera.
>   That's just *one* way of doing it. In no way it's the only way, nor
> necessarily the "best" way. And as I already said, there's nothing in
> this algorithm which would make it "real".
As established, my initial assumption was not correct. I assumed there was a
class of programs which do what raytracers do, but in the other direction,
yielding heigher quality images with much larger render times. Apparently
that's not the case at all...
> > However, POV-Ray is
> > "radiosity mode" seems to still follow light backwards, only this time
> > attempting to take diffuse interreflections into account.
>   Right. There are good advantages (and perhaps some disadvantages) of
> doing it that way.
OK. That makes sense.
> > Does this really count as radiosity?
Dumb-ass question.
> > Could the
> > photon mapping algorithm be changed to include diffuse elements also?
Would
> > this be worth doing?
>   This is a FAQ.
>   Nathan Kopp tried to implement global illumination using photon mapping,
> but AFAIK the results were not very promising.
That's a shame.
>   If you think about the amount of samples needed to calculate global
> illumination for a huge scene, you will understand why this is so.
Yeah, actually... caustics are heigh-detail, but they don't take up such
surface area, so the photon maps don't cover very much. Global lighting
would take too much memory I suppose.
> It's
> very difficult to calculate more samples where they are needed and less
> samples where they aren't. This is an advantage of the stochastic
algorithm
> used by POV-Ray.
Ah well - I guess I'm just trying to get it to solve the wrong sort of
problems.
(Actually, I tried it with a ambient white sky over a matt white floor, with
a green ball in the middle. Didn't take long to find parameters that worked
perfectly. Looked good too.)
Thanks.
Andrew.
Date: 24 Jun 2003 01:37:34
Message: <3ef7e39e@news.povray.org>
  Photon mapping for caustics works well because they can be concentrated on
very specific areas of the scene (you tell which specific objects need to
be shot photons at).
  Global illumination would require shooting photons at *everything*. And
lots of them.
  Even caustics can sometimes show odd artifacts when the lights spreads
too much, in which case you need to increase the photon mapping parameters
to shoot more photons. This slows down, but not unacceptably because the
total amount is still quite limited. However, having to do this for the
entire scene is just enormous (I'm not saying it's not possible for simple
scenes, but just imagine a huge one).
  The advantage of the global illumination method used in POV-Ray is that
it can concentrate on the parts which really need it. It only calculates
the illumination of the parts of the scene which are visible on the final
image or have some indirect effect on visible areas. Areas which are not
visible nor have any effect are simply skipped. It also calculates more
samples where they are needed.
  The algorithm shows often some artifacts. It's still quite unclear to me
whether this is a problem with the algorithm itself or whether its
implemention in POV-Ray has some problems (bugs, misunderstandings or bad
designs). AFAIK the same algorithm is used in the Radiance renderer, which
is used professionally, and its results are great (at least based on the
few images I have seen).
Date: 24 Jun 2003 01:38:49
Message: <3ef7e3e9@news.povray.org>
squidian <squ### [at] localhostlocaldomain> wrote:
> 	I know I tried radiosity which looked ok on a single frame. I know the
> "radios" contribution changed with each frame. What else is there to
> know? That it is not noise with causes the problem? That it does not use
> the same random number each time?
  Perhaps you should study how the global illumination algorithm used
in POV-Ray works before you talk about it.
Date: 24 Jun 2003 07:29:15
Message: <3ef8360b$1@news.povray.org>
In article <3ef81d3f$1@news.povray.org> , squidian
>  As the algorithm sucks for animations what more is there to know and why
> should I stroke your all-knowing, all-seeing ego when I am right?
>  I have retested it without panning. Shall I upload it to show what I am
> talking about?
>  OTOH: You could have simply posted how to make radiosity work with
> animation and have been done with it. You did not. Therefore you do not
> know. QED
I strongly recommend you do not continue this way of discussion because you
really do not appear to know anything helpful about the topic being
discussed.  A prerequisite would be to "know" at least as much as the
documentation explains.  Having read previous replies to this thread, like
the one from Warp, could also have told you that your short comment might
not be a suitable answer.
This is povray.advanced-users, and if you don't understand something
discussed here there is no shame.  However, disrupting a discussion with
remarks of the kind you posted - which offer no help solving with the
problem a user is having and assume something the user has not said would be
his problem - is strongly discouraged!
    Thorsten Froehlich, POV-Team
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 Jun 2003 13:10:01
Message: <web.3ef884b34485a7259735c0c0@news.povray.org>
>>  Tried that with 3.1. 3.1 uses noise as an input. Each frame uses a
>> different noise making a mess like leaving jitter on. Doesn't work.
>  You really don't have the slightest clue about what you are talking about,
>do you?
>#macro M(A,N,D,L)plane{-z,-9pigment{mandel L*9translate N color_map{[0rgb x]
>-1<.7438.1795>1,20)M(1<.77595.13699>30,20)M(3<.75923.07145>80,99)// - Warp -
Sorry Warp, I believe he does have a valid point, even if he is not
expressing himself very well.
In render.cpp, function Start_Tracing_Radiosity_Preview(), line about 1022:
  while ((skip >= 2) && (skip >= EndPixelSize))
    /* for each pass */
    jitter_range  = 3;
    jitter_offset = skip / 2 - 1;       /* add a very small amount of jitter
    if ( skip <= 8 ) Smooth_Preview = 1;
    for (Current_Line_Number = opts.First_Line; Current_Line_Number <
opts.Last_Line; Current_Line_Number += skip)
      check_stats(Current_Line_Number, 1, skip);
      Do_Cooperate(0);
      for (x = opts.First_Column; x < opts.Last_Column; x += skip)
        Check_User_Abort(false);
        offset_x = jitter_offset + (POV_RAND() % jitter_range);
        offset_y = jitter_offset + (POV_RAND() % jitter_range);
        /* don't use focal blur for radiosity preview! */
        save_use_blur = Focal_Blur_Is_Used;
        Focal_Blur_Is_Used = false;
        trace_pixel(x + offset_x, Current_Line_Number + offset_y, Colour);
Thus random noise is introduced into the radiosity trace. And it is
different for each frame of an animation. Some scenes show it more than
others, but it is there.
When I compile custom versions I always remove this jitter ...
Mike Andrews.
Date: 24 Jun 2003 17:19:28
Message: <3ef8c060@news.povray.org>
In article <web.3ef884b34485a7259735c0c0@news.povray.org> , "Mike Andrews"
No, this is something different and not directly related to the observed
effect.  If you see excessive changes of colors from one frame to the other
it implies the number of samples you takes is too small.
If you like grid artifacts ... if you really have a problem with the
"randomness" of the same distribution, you should increase the number of
samples taken.  And you cannot expect pixel to pixel equivalent images for
_different_ camera positions.  Nevertheless, the effect you will see
rendering the same scene twice will be identical because the "random
distribution" will be identical as well.  Even if you move the camera, the
"randomness" will be absolutely identical, however, it applies to pixels
that represent different objects in the scene now, and that will create
artifacts when the sample count is too low.  Thus, the "randomness" is not
different for each frame of the animation.  Further, this has nothing to do
with noise.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Jun 2003 03:03:43
Message: <3EF9494E.D311820B@gmx.de>
squidian wrote:
>         Then can one of these advanced users or team members explain how to make
> radiosity work for animations instead of waxing long upon the theory?
If you describe your problem clearly including a sample of what you want
to avoid someone might be able to come up with a solution.  It is very
likely though that you will have difficulties using that solution without
understanding the basics how radiosity works.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 25 Jun 2003 06:27:50
Message: <3ef97926@news.povray.org>
In article <3ef96f37$1@news.povray.org> , squidian
> Another
> person here posted how to eliminate the problem by eliminating that and
> recompiling.
As said, that only hides the incorrect radiosity settings.  There is no
noise as the "randomness" used for the pretrace is actually always the same
for the same image size.  the only difference is that is changes depending
on the image size.  The benefit is that there is no need to build a several
MB size table that would do exactly the same, but to just call the pseudo
random number generator at runtime.  It is inited prior to rendering a new
scene, thus it always generates exactly the same sequence.
    Thorsten
Date: 25 Jun 2003 06:28:29
Message: <3ef9794d@news.povray.org>
In article <3ef946f0$1@news.povray.org> , squidian
As always, a complete but minimal scene will be required to help you.
    Thorsten
Date: 28 Jun 2003 11:41:40
Message: <3EFDB736.F5B7421E@excite.com>
Hi.
(BTW, I'm the guy who wrote the radiosity subsystem way back when)
There are many problems with getting the radiosity solution to be
smooth from frame to frame in an animation, of which this is but
one, and not the most major one.
(without the jitter, the same places in each frame would at least
be tried for the pre-pass for static-camera scenes, which is a plus,
but no help for moving cameras or sample points on moving objects)
Keeping the radiosity samples from frame to frame has as its
biggest problem this:
- if you use the same old samples from frame to frame, the lighting
won't change with the moving objects in the animation
- if you don't, you will get very different sample locations from
scene to scene, which will result in lighting shades flickering.  No
matter how low the error bound, in practice you will get some error,
which will be different from frame to frame.
The theoretically correct solution, I speculate, to this is to extend the ray
sampling from 3D to 4D.  Right now each sample has a location
and a range of effectivity in X, Y, and Z:  it could also have it in time.
The octree structure would become a 16-tree.  (hexadecatree?).
This part is easy...I used a 2D search algorithm extended to 3D already.
The software to try this isn't really all
that hard:  the problem is coming up with rule for the range
of time intervals that a sample is good for, based on the measured
magnitude of the effect of the moving objects on it.
X,Y,Z are symmetrical in this respect, but time isn't.
I speculate as follows:
First, you'd have to have each varying thing in the animation as
a function of time that could be evaluated randomly.  This is
possible, but a pretty major change if there is software which makes
decisions on the fly as it goes from frame to frame.  I'm not an
expert on the things you can do during an animation, so I can't
really say much about how hard this would be.  Object sort buffers
would be one obvious problem point, and anything else in the way
of frame overhead.  My suggested
solution would require sampling through time, so T would have to
be varying from ray to ray.  Might be a show stopper right there,
but let's continue:
-   you'd do a very large number of rays per sample location, sampling
in all directions (as now) as well as randomly across time.
- rays which were affected by time-variance would be tagged.  For
example, "I hit a moving object".  (there are lots of other things that
could happen too).
- You would calculate the variance and sensitivity of the gathered and
cached sample to the time-variant objects.  e.g., "this sample of 8000
rays would not vary by more than 1% if no moving objects had been
hit"
- From here, you might try different things:  if the variance due to
those objects were high, subdivide the rays by time, and create
two samples. Or, split it into 3:  the range before we hit the moving
object, the range during, and the range afterwards.  Recurse till the change in
contribution is negligible.
So, in the end, you might have an irradiance cache sample that
was good to within an error of 0.30 if you were at location
(4,5,6) +/- 1, and a time of frame=17 +/- 4.
The calculation time for the first frame would be huge, but it would
be much faster after that!
So far as I know, no one has ever tried this.  There might be an
acedemic paper in it if someone made it work.
A totally different approach might be to calculate the samples all
at the beginning, without any of the animation-dependent objects,
like an empty room, then approximate the incremental effects of
the objects and composite their change in light contribution into
the system.  Not clear in my own mind how this might work, but I have
a hunch that this is the type of solution that an animation studio would
follow, since it would likely be practical enough for real-seeming
scenes (a relatively coherent space with some static and some moving
objects and characters in it), and would scale up well, and would
parallelize well.
This technique has been used before for light sources:  they composite
perfectly.  That is:  you can do a radiosity calculation separately for
each lamp, then on the fly (in real time) composite the final lighting
values and render the scene with any combination of lights turned on.
At the less aggressive end of the spectrum, you could calculate
all the radiosity samples as you do now, calculating some sort of
metric of how sensitive each one was to animation-variant objects.
(for example, samples where over 5% of the rays shot hit a moving
object).  These samples would be deleted after each frame, and all
other samples would be kept from frame to frame.
This one (unlike the other approaches above) might actually be
mostly doable, at least for some simpler classes of animation like moving
objects and camera in a largely coherent setting.  It would be hard to
calculate the sensitivity for some kinds of things that vary in an animation,
(a light gets turned off?) but fairly easy for other things.  Might have to be
specified directly in the scene file by the animator.
Quick and easy to prototype, relatively speaking.
Jim
