POV-Ray : Newsgroups : povray.advanced-users : Creating blurred image via textures...? Server Time
17 May 2026 17:32:30 EDT (-0400)
  Creating blurred image via textures...? (Message 9 to 18 of 18)
<<< Previous 8 Messages Goto Initial 10 Messages
Subject: Re: Creating blurred image via textures...?
Date: 17 Jun 2003 18:04:03
Message: <3eef9053@news.povray.org>
Did it with pigment-patterns alone, but had to
go through a function once to apply my own
color-map for transparencies. Thanks for
the suggestion anyways!
Tim Nikias v2.0
Email: Tim### [at] gmxde
> > But it will render a *lot* quicker if you can find some way to blur the
> > texture before you apply it.
> Use an image_map of a function image of a pigment function with the
> blurred pigment.
> image_map {
>     function xRes, yRes {
>         pigment {average...}
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
> POV-Ray TAG: chr### [at] tagpovrayorg
> http://tag.povray.org/
Date: 17 Jun 2003 18:05:21
Message: <3eef90a1$1@news.povray.org>
I've done it averaging quasi-even distributed samples
in a pigment and pass that through a function to
apply my own color-map for transparency-handling.
Want to experiment a little with how many samples
may be used for that...
Tim Nikias v2.0
> > Lets say I have a picture. Via patterns, averaging
> > pigments, layered textures etc I'd like to blur the
> > image_map.
> It should be possible with functions, but will that will
> be slow and limited to grayscale.
> You can also mildly blur an image_map with my bicubic
> interpolation patch, but thats's limited to 16 samples, so
> no huge blur radius.
> Lutz-Peter
Date: 17 Jun 2003 19:42:51
Message: <cjameshuff-ACC062.18333417062003@netplex.aussie.org>
In article <3eef9053@news.povray.org>,
The point of using a function image would be for rendering
speed...evaluating the function/average pigment can get quite slow, you
can do it once at parse time and get a faster render. If you're just
rendering the image on a plane to just do a post-process filter, this
probably won't help.
Date: 17 Jun 2003 19:44:56
Message: <cjameshuff-1E88FC.18353917062003@netplex.aussie.org>
In article <3eef8eba$1@news.povray.org>,
pigment {average
    pigment_map {
        [1 function {R_Func(x, y, z)} color_map {[0 rgb 0][1 red 3]}]
        [1 function {G_Func(x, y, z)} color_map {[0 rgb 0][1 green 3]}]
        [1 function {B_Func(x, y, z)} color_map {[0 rgb 0][1 blue 3]}]
Date: 18 Jun 2003 04:04:36
Message: <3ef01d14$1@news.povray.org>
Hm.. I don't understand what you're after.
What I'm doing now is take several pigments
and average them for the blurring effect. I then
wrap this into a function and apply my own
color_map. So I'm passing it through the function
like you suggested. Or am I misunderstanding
something?
Do note that I do need transparency based on
the brightness, so I'm not sure what you're after.
Are you suggesting I should use image_map function
to create an internal image-map, then pass that to
a function again, for me to apply the transparency?
Tim Nikias v2.0
Date: 18 Jun 2003 04:26:20
Message: <3ef0222c$1@news.povray.org>
I've just tried and compared the image_map
approach to the approach I used. You're
idea about passing the pigment through the
image_map function moves the load off of
the tracing process onto the parsing process.
So, depending if I want quick renders or
quick parsing, I set up a switch so that one might
choose freely where the timing should rise.. :-)
I'm wondering though, if there'd be a method
to output that image_map function on the fly,
that'd be neat!
Tim Nikias v2.0
> something?
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
Date: 19 Jun 2003 10:33:09
Message: <cjameshuff-DC15C5.09231519062003@netplex.aussie.org>
In article <3ef0222c$1@news.povray.org>,
Exactly. If you were using the blurred pigment in an actual scene, you
could save rendering time this way. But if you are just putting the
pigment on a plane to render a blurred image, it isn't as useful.
> that'd be neat!
I'm not sure what you mean...are you talking about automatically
generating the function-of-image-map-of-pigment-function construct? That
could be done with a simple macro.
Date: 19 Jun 2003 12:41:31
Message: <3ef1e7bb@news.povray.org>
What I meant is that if POV-Ray creates an internal
image-map, that one could be saved to disk, couldn't
it? And I don't mean rendering it alone to get an
image. While POV-Ray parses, it could output the
data it saves for the internal image-map to an
image...
Tim Nikias v2.0
> > that'd be neat!
Date: 20 Jun 2003 10:56:03
Message: <cjameshuff-E738C6.09455120062003@netplex.aussie.org>
In article <3ef1e7bb@news.povray.org>,
> image...
This would be possible to implement. You could even do it in POV Script
with an ASCII image format. Unless there is some use for this within the
scene file, it might be better as part of a post-process stage...one
thing I've always wanted was the ability to create and save multiple
image buffers. You could create multiple post-processed versions, and
combine them into more versions, etc.
Date: 30 Jun 2003 11:23:41
Message: <3f0055fd$1@news.povray.org>
I used this to create a blurred image texture by adding small scale bozo to
the coordinates.  It looks a little like smeared chalk.
Bye,
Hans Mikelson
Christopher James Huff wrote:
> pigment {average
>     pigment_map {
#declare fbi    = function  {pattern {bozo turbulence .015 octaves 5 omega
1.3 lambda 1.5 scale .001}} ;
#declare fimage = function {pigment {image_map {png "image8.png"}}} ;
#declare T_Blur01 =
texture
    //pigment {
    //image_map {
    //    function 100, 100 {fimage(x,y,z)}
  pigment
   {average
    pigment_map
        [1 function {fimage(x+fbi(x,y,z)*.1, y+fbi(x,y,z)*.1,
z+fbi(x,y,z)*.1).red} color_map {[0 rgb 0][1 red 3]}]
z+fbi(x,y,z)*.1).green} color_map {[0 rgb 0][1 green 3]}]
z+fbi(x,y,z)*.1).blue} color_map {[0 rgb 0][1 blue 3]}]
    finish {
        ambient 1.0
        diffuse 0.0
