POV-Ray : Newsgroups : povray.advanced-users : A question of speed Server Time
17 May 2026 18:56:25 EDT (-0400)
  A question of speed (Message 21 to 25 of 25)
Subject: Re: A question of speed
Date: 10 Jun 2003 14:41:54
Message: <3ee62672@news.povray.org>
> Yes, the display routines are not intended to display a high framerate.
> The time taken to display the image is not long enough to bother
> optimizing though...what's a few hundred milliseconds when the render
> takes seconds, let alone minutes or hours?
Yeah, entirely as I expected.
> In addition to that, parsing is pretty slow, especially when you're
> talking about doing real-time stuff.
Mmm... that's true... I wonder how much time the actual physics simulation
took up? hehehe
> > ...such as building polyhedrons out of planes using CSG? (I do this all
the
> > time... *is* there any other way to build polyhedrons in POV?!?)
> Yes, that is one good example. POV can't bound an intersection of
> infinite shapes, you really need to manually bound when making
> polyhedrons that way.
...and remember to tell POV-Ray *not* to remove them ;-)
> There are alternate methods: you could use boxes
> or meshes. An intersection of two boxes makes an efficient octahedron,
> and of course a box is the best way to do a cube.
Usually I just want to build million-sided mirror balls or gemstones or
such... and I don't like meshes. Somehow seems like a "trick". (OK, I'm
weird!)
Thanks.
Andrew.
Date: 10 Jun 2003 18:53:19
Message: <3ee6615f@news.povray.org>
Micha Riser <mri### [at] gmxnet> wrote:
> I've just read a paper which states that real-time ray-tracing might become
> doable
  "Real-time raytracing" is not an unambiguous term.
  There have been real-time raytracers in the mid-90's for the first Pentium,
so in that sense that's old news. It doesn't *become* doable because it
has been doable for over 5 years.
  All this comes down to how we really want to define "realtime raytracing".
What kind of frame rates, scene complexity and image resolution is enough
to satisfy the conditions?
Date: 10 Jun 2003 19:07:11
Message: <3ee6649f@news.povray.org>
Thorsten Froehlich wrote:
> In article <3ee4e321$1@news.povray.org> , sascha
> <sas### [at] userssourceforgenet>  wrote:
> No, the problem is, you cannot optimise the scanline algorithm further
> than
> what I outlined (at least not bringing down the complexity).  In fact, the
> complexity I outlined holds for the first implementations 30 or so years
> ago
> and it still holds in the 3d hardware accelerators of today.  The main
> benefit of the scanline algorithm is that you can make the constant time
> factor very, very small compared to ray-tracing.
>> But couldn't the same (or other - e.g. octree) optimizations be applied
>> to the scanline algorithm too?
> No, because the scanline algorithm requires you to draw everything in the
> viewing area to determine its visibility.  You can cull backfacing
> triangles, but that only divides to constant factor by about two.
Well, there is further optimisation possible: view-frustum culling and
occlusion culling. You can determine on the CPU (using some Bounding Volume
Hierarchies) which groups of triangles are not visible from the viewpoint.
For example a scene in a house you can quickly determine which rooms one
sees into at all and which you don't. So there is no need to move these
triangles down the rendering pipline. Of course this triangle exculsion is
only an conservative estimation and no exact solution.
Another interesting thing to think about is: Why do we use triangles? As
today there are often tens of triangles per pixel in a detailed model one
doesn't really need the full triangles. So another idea is to stick to
points and not store the interconnections of the points but only the points
assosiated with a normal and a texture. This reduces the memory
requirements. For the rendering you draw either a small box for each point
(which is supported by todays GPUs) or more exact a small ellipse. Using
points as basing privmitives has another advantage: You can quickly
generate different LODs of models (which is much slower for triangle
meshs), so you can use a reduced-point version when an object is farther
away.
That this actuallly works can be seen in the video from:
http://www9.informatik.uni-erlangen.de/Research/Rendering/SPT
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 10 Jun 2003 19:10:59
Message: <3ee66583@news.povray.org>
>> become doable
>   Pentium,
I know that it has been made on CPUs already.. but, if you had properly
quoted my statement it would say:
"I've just read a paper which states that real-time ray-tracing might become
doable on the next generation GPUs using their fragment shaders:"
so the new thing is that it's getting possible on the standard GPUs.
- Micha
Date: 12 Jun 2003 22:12:55
Message: <cjameshuff-92229A.21043712062003@netplex.aussie.org>
In article <3ee6649f@news.povray.org>, Micha Riser <mri### [at] gmxnet>
> away.
Point fields can be raytraced as well...there's an algorithm that
basically uses a disc for each point, intersecting with several nearby
discs and interpolating normals and intersection points. I've been
working on an implementation, but it isn't even rendering plain discs
yet.
http://tag.povray.org/
