POV-Ray : Newsgroups : povray.advanced-users : A question of speed Server Time
17 May 2026 17:34:39 EDT (-0400)
  A question of speed (Message 16 to 25 of 25)
Subject: Re: A question of speed
Date: 10 Jun 2003 09:42:12
Message: <cjameshuff-68971E.08334310062003@netplex.aussie.org>
In article <3ee5829b$1@news.povray.org>,
 "Thorsten Froehlich" <tho### [at] trfde> wrote:
> No, the problem is, you cannot optimise the scanline algorithm further than
> what I outlined (at least not bringing down the complexity).  In fact, the
> complexity I outlined holds for the first implementations 30 or so years ago
> and it still holds in the 3d hardware accelerators of today.  The main
> benefit of the scanline algorithm is that you can make the constant time
> factor very, very small compared to ray-tracing.
You could probably do something somewhat similar to bounding...do an
assay render on the bounding box of a group of triangles. If it would
have been drawn, fully render the individual triangles, if it would not
have been drawn then ignore them. Probably not as efficient as in
raytracing, but it could work...I don't see a way to get it to work with
hardware accelerated rendering though, unless there's a way to check if
the depth buffer would have been modified without actually modifying it.
You could save/render/compare/restore, but that'd probably take longer,
especially on large resolutions.
> Yes, it does.  The problem is, the one million to one difference of the
> constant factors.  And due to the simplicity of the scanline algorithm, it
> is, compared to ray-tracing, much easier to implement it in hardware (you
> need only a few thousand gates, most of the logic on today's accelerator
> chips is used for texture and geometry computations.
It can also be done easily with integer math, while raytracing requires
floating point...even 64 bits isn't enough for practical fixed point
raytracing. This lets the logic be simplified, cutting development costs
and allowing higher speeds to be attained more easily.
http://tag.povray.org/
Date: 10 Jun 2003 09:50:18
Message: <cjameshuff-60CCFE.08414910062003@netplex.aussie.org>
In article <3ee5a9ca@news.povray.org>,
 sascha <sas### [at] userssourceforgenet> wrote:
> I agree with you that raytracing would be the winner if there were *a
> lot* of primitives which appear smaller than a single pixel so that
> their bounding-boxes will never get hit by a ray - but usually both,
> REYES and game-engines use some sort of level-of-detail optimizations to
> prevent this scenario...
The shapes don't need to appear smaller than a pixel, they just need to
have another shape be hit in front of their bounds so the bounded shape
isn't tested. If you have a lot of shapes partially or totally obscured
by other shapes, raytracing gets better by testing fewer shapes while
scanlining stays about the same, having to draw the same number of
triangles and shade the same number of pixels.
Date: 10 Jun 2003 11:06:15
Message: <3ee5f3e7@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
No, because you would have to be able to keep multiple levels.  A bounding
box is bigger than the actual geometry.  So only looking at the frontmost
bounding box isn't enough.
    Thorsten
e-mail: tho### [at] trfde
Date: 10 Jun 2003 12:02:20
Message: <cjameshuff-9565EA.10535110062003@netplex.aussie.org>
In article <3ee5f3e7@news.povray.org>,
I don't think you understood what I meant. Draw from front to back. Use
single bounding boxes for closely spatially related groups of triangles,
maybe with an oct-tree structure. If the bounding box of a group is
occluded by triangles that have already been drawn (it has no pixels at
lesser depth), all those triangles are also occluded, so no need to draw
them. I'm assuming no alpha-style transparency, because you mentioned
backside culling. Nothing to do with the frontmost bounding box, except
that you could skip the test for the frontmost few levels because they
are so unlikely to be occluded.
Date: 10 Jun 2003 13:06:07
Message: <3ee60fff@news.povray.org>
I've just read a paper which states that real-time ray-tracing might become
doable on the next generation GPUs using their fragment shaders:
Ray Tracing on Programmable Graphics Hardware - Purcell et al., SIGGRAPH
2002
http://graphics.stanford.edu/papers/rtongfx/
- Micha
POV-Ray Objects Collection: http://bjects.povworld.org
Date: 10 Jun 2003 14:41:54
Message: <3ee62672@news.povray.org>
> Yes, the display routines are not intended to display a high framerate.
> The time taken to display the image is not long enough to bother
> optimizing though...what's a few hundred milliseconds when the render
> takes seconds, let alone minutes or hours?
Yeah, entirely as I expected.
> In addition to that, parsing is pretty slow, especially when you're
> talking about doing real-time stuff.
Mmm... that's true... I wonder how much time the actual physics simulation
took up? hehehe
> > ...such as building polyhedrons out of planes using CSG? (I do this all
the
> > time... *is* there any other way to build polyhedrons in POV?!?)
> Yes, that is one good example. POV can't bound an intersection of
> infinite shapes, you really need to manually bound when making
> polyhedrons that way.
...and remember to tell POV-Ray *not* to remove them ;-)
> There are alternate methods: you could use boxes
> or meshes. An intersection of two boxes makes an efficient octahedron,
> and of course a box is the best way to do a cube.
Usually I just want to build million-sided mirror balls or gemstones or
such... and I don't like meshes. Somehow seems like a "trick". (OK, I'm
weird!)
Thanks.
Andrew.
Date: 10 Jun 2003 18:53:19
Message: <3ee6615f@news.povray.org>
> doable
  "Real-time raytracing" is not an unambiguous term.
  There have been real-time raytracers in the mid-90's for the first Pentium,
so in that sense that's old news. It doesn't *become* doable because it
has been doable for over 5 years.
  All this comes down to how we really want to define "realtime raytracing".
What kind of frame rates, scene complexity and image resolution is enough
to satisfy the conditions?
Date: 10 Jun 2003 19:07:11
Message: <3ee6649f@news.povray.org>
Thorsten Froehlich wrote:
> In article <3ee4e321$1@news.povray.org> , sascha
> than
> ago
>> But couldn't the same (or other - e.g. octree) optimizations be applied
>> to the scanline algorithm too?
> No, because the scanline algorithm requires you to draw everything in the
> viewing area to determine its visibility.  You can cull backfacing
> triangles, but that only divides to constant factor by about two.
Well, there is further optimisation possible: view-frustum culling and
occlusion culling. You can determine on the CPU (using some Bounding Volume
Hierarchies) which groups of triangles are not visible from the viewpoint.
For example a scene in a house you can quickly determine which rooms one
sees into at all and which you don't. So there is no need to move these
triangles down the rendering pipline. Of course this triangle exculsion is
only an conservative estimation and no exact solution.
Another interesting thing to think about is: Why do we use triangles? As
today there are often tens of triangles per pixel in a detailed model one
doesn't really need the full triangles. So another idea is to stick to
points and not store the interconnections of the points but only the points
assosiated with a normal and a texture. This reduces the memory
requirements. For the rendering you draw either a small box for each point
(which is supported by todays GPUs) or more exact a small ellipse. Using
points as basing privmitives has another advantage: You can quickly
generate different LODs of models (which is much slower for triangle
meshs), so you can use a reduced-point version when an object is farther
away.
That this actuallly works can be seen in the video from:
http://www9.informatik.uni-erlangen.de/Research/Rendering/SPT
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 10 Jun 2003 19:10:59
Message: <3ee66583@news.povray.org>
>> become doable
>   Pentium,
I know that it has been made on CPUs already.. but, if you had properly
quoted my statement it would say:
"I've just read a paper which states that real-time ray-tracing might become
doable on the next generation GPUs using their fragment shaders:"
so the new thing is that it's getting possible on the standard GPUs.
- Micha
Date: 12 Jun 2003 22:12:55
Message: <cjameshuff-92229A.21043712062003@netplex.aussie.org>
In article <3ee6649f@news.povray.org>, Micha Riser <mri### [at] gmxnet>
> away.
Point fields can be raytraced as well...there's an algorithm that
basically uses a disc for each point, intersecting with several nearby
discs and interpolating normals and intersection points. I've been
working on an implementation, but it isn't even rendering plain discs
yet.
