POV-Ray : Newsgroups : povray.advanced-users : A question of speed Server Time
17 May 2026 17:33:12 EDT (-0400)
  A question of speed (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Re: A question of speed
Date: 9 Jun 2003 15:42:25
Message: <3ee4e321$1@news.povray.org>
Thanks for that really long explanation!
If I understand right you say that both, a scanline algorithm and an
unoptimized ray-tracing algorithm will take [image pixel] * [objects in
scene] * [some constant factor] time (the objects could be triangles).
Then you explain how the raytracing algorithm could be optimized and
compare it again with the (unoptimized!) scanline algorithm. Hmmm...
But couldn't the same (or other - e.g. octree) optimizations be applied
to the scanline algorithm too?
Maybe I'm completely wrong, but doesn't your posting suggest that a
raytracer will always outperform a scanline-renderer if just the number
of objects is large enough?
I really don't want to start another scanline vs. raytracing flame-war
here - each has its pros and cons which have already been discussed a
million times - I just doubt that speed is a pro of raytracing...
Sascha
Thorsten Froehlich wrote:
> In article <3ee46215@news.povray.org> , "Thorsten Froehlich"
> <tho### [at] trfde> wrote:
>>c2*m*sqrt(n^(1/3)) = c2*m*n^(1/6)
> Ups, this should be c2*m*sqrt((n^(1/3))^2*3) and thus c2*m*n^(1/3), but it
> does not change anything.
>     Thorsten
> ____________________________________________________
> Thorsten Froehlich, Duisburg, Germany
> e-mail: tho### [at] trfde
> Visit POV-Ray on the web: http://mac.povray.org
Date: 9 Jun 2003 16:42:57
Message: <cjameshuff-102F9F.15342409062003@netplex.aussie.org>
In article <3ee4de11$1@news.povray.org>,
 "Andrew Coppin" <orp### [at] btinternetcom> wrote:
> I'd be interested to see one go in realtime... (Actually, some of my Chaos
> Pendulunm renders nearly had POV-Ray in realtime... I presume it's preview
> window isn't designed with realtime performance in mind. It goes way faster
> if I switch it off!)
Yes, the display routines are not intended to display a high framerate.
The time taken to display the image is not long enough to bother
optimizing though...what's a few hundred milliseconds when the render
takes seconds, let alone minutes or hours?
In addition to that, parsing is pretty slow, especially when you're
talking about doing real-time stuff.
> I've yet to see texturing have any significant effect on my renders...
Texturing and lighting can have a surprisingly large impact, though you
can easily overpower it with some forms of geometry. One of my earliest
patches was a depth buffer render mode...it was much faster than doing
all the texture calculations, and I used it as a quick preview for a
while. You could use the quality switches to cut out most of these
calculations in the official version.
> > POV builds such a structure automatically,
> > though manual bounding can still give better results in some cases.
> ...such as building polyhedrons out of planes using CSG? (I do this all the
> time... *is* there any other way to build polyhedrons in POV?!?)
Yes, that is one good example. POV can't bound an intersection of
infinite shapes, you really need to manually bound when making
polyhedrons that way. There are alternate methods: you could use boxes
or meshes. An intersection of two boxes makes an efficient octahedron,
and of course a box is the best way to do a cube.
http://tag.povray.org/
Date: 10 Jun 2003 03:02:51
Message: <3ee5829b$1@news.povray.org>
In article <3ee4e321$1@news.povray.org> , sascha
I knew somebody would ask, but answering it right along would have made a
long post even longer :-)
No, the problem is, you cannot optimise the scanline algorithm further than
what I outlined (at least not bringing down the complexity).  In fact, the
complexity I outlined holds for the first implementations 30 or so years ago
and it still holds in the 3d hardware accelerators of today.  The main
benefit of the scanline algorithm is that you can make the constant time
factor very, very small compared to ray-tracing.
No, because the scanline algorithm requires you to draw everything in the
viewing area to determine its visibility.  You can cull backfacing
triangles, but that only divides to constant factor by about two.
Yes, it does.  The problem is, the one million to one difference of the
constant factors.  And due to the simplicity of the scanline algorithm, it
is, compared to ray-tracing, much easier to implement it in hardware (you
need only a few thousand gates, most of the logic on today's accelerator
chips is used for texture and geometry computations.
    Thorsten
Date: 10 Jun 2003 05:50:02
Message: <3ee5a9ca@news.povray.org>
 > made a long post even longer :-)
Well, with all your privious posts you gave the impression that you
enjoy writing long posts :-)
Just one more stupid question: Are you talking about hardware-scanline
renderers (OpenGL and the like) only or about REYES too? As far as I
understand REYES is more related to scanline than raytracing and is in
fact highly optimized to render huge amounts of primitives.
There are some test results and analysis about its time-complexity here:
http://www.cis.ohio-state.edu/~stuart/cis781/final.html
[And again: I'm not trying to say that REYES is "better" than raytracing]
 > the viewing area to determine its visibility.
I agree with you that raytracing would be the winner if there were *a
lot* of primitives which appear smaller than a single pixel so that
their bounding-boxes will never get hit by a ray - but usually both,
REYES and game-engines use some sort of level-of-detail optimizations to
prevent this scenario...
sascha
>     Thorsten
Date: 10 Jun 2003 07:15:41
Message: <3ee5bddd$1@news.povray.org>
In article <3ee5a9ca@news.povray.org> , sascha
They take a real lot of time, and I usually have a lot more things to do
that end up having to wait :-(
It is still a scanline algorithm.  It simply uses a different subdivision
method to turn objects into triangles.  As the triangle size will be a
constant factor or some kind, it does not change the complexity.
Hmm, it says O(n*4^p/g) and g being "somewhat constant", which would suggest
the complexity really is O(n*4^p), or O(n*4^m) using the variable names I
used.  It would only make sense if g > p would always be true, and the
authors imply the best case will be g =< p.
Thus, I don't think this makes sense because it implies that the average
case, and not only the upper bound, is also n*4^m, which would make the
problem not solvable in polynomial time!  But I didn't read the whole paper,
maybe I missed something important ... Warp?
    Thorsten
Date: 10 Jun 2003 09:42:12
Message: <cjameshuff-68971E.08334310062003@netplex.aussie.org>
In article <3ee5829b$1@news.povray.org>,
You could probably do something somewhat similar to bounding...do an
assay render on the bounding box of a group of triangles. If it would
have been drawn, fully render the individual triangles, if it would not
have been drawn then ignore them. Probably not as efficient as in
raytracing, but it could work...I don't see a way to get it to work with
hardware accelerated rendering though, unless there's a way to check if
the depth buffer would have been modified without actually modifying it.
You could save/render/compare/restore, but that'd probably take longer,
especially on large resolutions.
It can also be done easily with integer math, while raytracing requires
floating point...even 64 bits isn't enough for practical fixed point
raytracing. This lets the logic be simplified, cutting development costs
and allowing higher speeds to be attained more easily.
Date: 10 Jun 2003 09:50:18
Message: <cjameshuff-60CCFE.08414910062003@netplex.aussie.org>
In article <3ee5a9ca@news.povray.org>,
The shapes don't need to appear smaller than a pixel, they just need to
have another shape be hit in front of their bounds so the bounded shape
isn't tested. If you have a lot of shapes partially or totally obscured
by other shapes, raytracing gets better by testing fewer shapes while
scanlining stays about the same, having to draw the same number of
triangles and shade the same number of pixels.
Date: 10 Jun 2003 11:06:15
Message: <3ee5f3e7@news.povray.org>
In article <cja### [at] netplexaussieorg> ,
No, because you would have to be able to keep multiple levels.  A bounding
box is bigger than the actual geometry.  So only looking at the frontmost
bounding box isn't enough.
    Thorsten
Date: 10 Jun 2003 12:02:20
Message: <cjameshuff-9565EA.10535110062003@netplex.aussie.org>
In article <3ee5f3e7@news.povray.org>,
I don't think you understood what I meant. Draw from front to back. Use
single bounding boxes for closely spatially related groups of triangles,
maybe with an oct-tree structure. If the bounding box of a group is
occluded by triangles that have already been drawn (it has no pixels at
lesser depth), all those triangles are also occluded, so no need to draw
them. I'm assuming no alpha-style transparency, because you mentioned
backside culling. Nothing to do with the frontmost bounding box, except
that you could skip the test for the frontmost few levels because they
are so unlikely to be occluded.
Date: 10 Jun 2003 13:06:07
Message: <3ee60fff@news.povray.org>
I've just read a paper which states that real-time ray-tracing might become
doable on the next generation GPUs using their fragment shaders:
Ray Tracing on Programmable Graphics Hardware - Purcell et al., SIGGRAPH
2002
http://graphics.stanford.edu/papers/rtongfx/
- Micha
POV-Ray Objects Collection: http://bjects.povworld.org
