POV-Ray : Newsgroups : povray.advanced-users : Texture transition Server Time
19 Dec 2025 19:39:28 EST (-0500)
  Texture transition (Message 1 to 10 of 11)
Subject: Texture transition
Date: 1 Jun 2003 16:42:24
Message: <3eda6530@news.povray.org>
If I use the "planar" map, I get a texture that goes from one colour, to
another, and back to the first again, creating a thin band of the alternate
colour. How do I make it so that everything above the line is one colour and
everything below it is another? (Still with the nice smooth transition in
between.)
What I want is for all points where y >= +100 to be red, all points where y
<= -100 to be blue, and the points inbetween to be linearly interpolated. I
can get red -> blue -> red, and I can get blue -> red -> blue, but how do I
get red -> blue?
Thanks.
Andrew.
Subject: Re: Texture transition
Date: 1 Jun 2003 17:54:04
Message: <3eda75fc@news.povray.org>
"Andrew Coppin" <orp### [at] btinternetcom> wrote in message
news:3eda6530@news.povray.org...
alternate
and
> between.)
y
I
I
> get red -> blue?
I think you're describing the reversal of the pattern, opposite on either
side of the y plane. I can't think of any workaround except to translate and
scale (or vice versa).
Bob H.
Date: 1 Jun 2003 21:35:31
Message: <cjameshuff-FABF6D.20280201062003@netplex.aussie.org>
In article <3eda6530@news.povray.org>,
> get red -> blue?
You could use the object pattern with a plane to remove the undesired
portion. Something like:
    object {plane {y, 0}
        pigment {color Red},
        pigment {planar
            color_map {[0 color Blue] [1 color Red]}
I've been thinking of a generalization of the waveform feature that
would make this a lot easier, it would be done with a gradient pattern
and a clamp waveform.
You could also do it with a simple function pattern:
#include "math.inc"
pigment {function {clip(y, 0, 1)}
    color_map {[0 color Red] [1 color Blue]}
http://tag.povray.org/
Date: 2 Jun 2003 01:53:50
Message: <3edae66e@news.povray.org>
y
I
I
> get red -> blue?
If all else fails:
function {
    select(y-100,
        // if y < 100
        select(y-(-100),
            0 // if y < -100
            (y-(-100))/200 // else (y >= -100)
        1 // else (y >= 100)
color_map {
    [0 rgb <0,0,1>]
    [1 rgb <1,0,0>]
 - Slime
[ http://www.slimeland.com/ ]
Date: 2 Jun 2003 20:46:56
Message: <cjameshuff-4C9236.19393102062003@netplex.aussie.org>
In article <3edae66e@news.povray.org>, "Slime" <slm### [at] slimelandcom>
wrote:
> function {
>     select(y-100,
>         // if y < 100
>         select(y-(-100),
>             0 // if y < -100
I think select() is a bit overkill for this. My suggestions were more
general, but if you want something that fits this precise situation:
function {max(-100, min(100, y))/200 + 0.5}
Plus, I think you're missing a comma in the inner select().
Date: 3 Jun 2003 03:59:16
Message: <3EDC558F.9000703@informatik.uni-freiburg.de>
> get red -> blue?
I would take a checker and scale it so large that only two cubes are
in the visible scene, their frontier being at y=100. One of the
patterns I would make red, for the other I repeat the trick for a
second frontier at y=-100. One of those textures I make blue, the
other will be a gradient or however that was called.
Probably NOT the best solution.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 3 Jun 2003 23:10:59
Message: <3edd6343@news.povray.org>
That's right... I could tell I was overcomplicating it, but I couldn't tell
how.
 - Slime
Date: 8 Jun 2003 08:33:58
Message: <3ee32d36$1@news.povray.org>
> portion.
Well, it's the best idea I've heard so far...
Yeah, I thought it should be possible... I thought that changing from
triangle_wave to ramp_wave would do it, but no...
Thanks.
Andrew.
Date: 10 Jun 2003 00:57:00
Message: <3ee5651c$1@news.povray.org>
// Hi Andrew,
// if your object(s) is/are not infinite in the direction of the
// gradient (y in your case), a simple gradient pattern will suffice.
// If the range (along the direction of the gradient) of the object(s)
// to be textured is completely contained in  Bottom ... Top  and the
// range where blending is desired is  Min ... Max,  then the macro call
// Blending_pigment (Direction, Bottom, Top, Min, Max, Color_min, Color_max)
// creates a pigment with Color_min for Y<Min, Color_max for Y>Max and
// linearly blending from Color_min to Color_max in the y-range  Min to
// Max  if Direction=y, similar for other directions. This pattern repeats
// above Top and below Bottom. The range Bottom to Top should be slightly
// larger than the dimensions of the object(s) in the given direction to
// give rounding errors no chance.
// Because this pigment is a single gradient pattern with a very simple
// color_map, it should be faster than all other solutions.
// The same principle can be used with pigments or textures instead of
// colors; then it will be helpful for waterline texturing and the like.
// In case of infinite objects (like planes), it usually is acceptable
// to use very large values for Bottom and Top, the coloring errors
// in such a large distance will almost certainly be invisible.
// I'll post the picture created by the following demo code to p.b.i.
//    Sputnik
// fr### [at] computermuseumfh-kielde
//===== macro for pigment with blending colors ============================
#macro Blending_pigment (
  Direction,   // direction of blending
  Bottom, Top, // usable y-range
  Min, Max,    // range of colors blending from Color_min to Color_max
  Color_min,   // color for y=Bottom .. Min
  Color_max    // color for y=Max .. Top
    gradient Direction
    color_map {
      [ (Min-Bottom)/(Top-Bottom) Color_min ]
      [ (Max-Bottom)/(Top-Bottom) Color_max ]
    scale Top-Bottom
    translate Bottom*Direction
  #end//macro Blending_pigment
//===== examples ==========================================================
// create a box, Y=-400 to 400, blue to red from -100 to 100
box { <-1200, -400, -300>, <-600, 400, 300>
    // give it a pigment covering a little more than its y-range
    // which is blue below y=-100, red above y=100 and
    // linearly blending in the range between
    Blending_pigment ( y, -401,401, -100,100, rgb<0,0,1>,rgb<1,0,0> )
    finish {
      ambient .4
      diffuse .6
// another box, Y=-400 to 600, light blue to orange from -300 to 0
box { <-300, -400, -300>, <300, 600, 300>
    Blending_pigment ( y, -401,601, -300,0, rgb<.2,.6,1>,rgb<1,.6,.2> )
    finish {
      ambient .4
      diffuse .6
// bad example: large parts of box are outside Bottom ... Top
box { <600, -400, -300>, <1200, 400, 300>
    Blending_pigment ( y, -81,81, -40,40, rgb<0,1,0>,rgb<1,1,0> )
    finish {
      ambient .4
      diffuse .6
// infinite plane, blending in z-direction
plane { y, -400
    Blending_pigment ( z, -1E7, 1E7, -1000,1000, rgb<0,1,1>,rgb<1,0,1> )
    finish {
      ambient .4
      diffuse .6
light_source { <-1000, 3500, -2000>, color rgb 1 }
camera { location -6000*z look_at 300*y angle 30
  rotate <12, -20, 0>
// END ==================================================================
Date: 10 Jun 2003 14:20:20
Message: <3ee62164@news.povray.org>
I'll have a look into this... (when my mum stops pestering me! *sigh*)
Thanks.
Andrew.
