POV-Ray : Newsgroups : povray.advanced-users : Preferable OS for fastest rendering? Server Time
17 May 2026 17:32:31 EDT (-0400)
  Preferable OS for fastest rendering? (Message 11 to 13 of 13)
Subject: Re: Preferable OS for fastest rendering?
Date: 20 May 2003 21:11:44
Message: <3ecad250@news.povray.org>
Micha Riser wrote:
> I have made icc binaries, you can get them from
> http://www.povworld.org/povray/binaries.html
>Pentium4 optimized
>icc, no sse2
>povray.p4.nosse2.bz2 (1538779 bytes)
SSE2 seems to be the most powerful hardware feature
for speed optimisation with P4,
so why is it off? Does it run faster without
this option?
Date: 21 May 2003 11:27:55
Message: <3ecb9afb@news.povray.org>
>>Pentium4 optimized
>>icc, no sse2
> this option?
I've tried it.. but it got slower. I don't *exactly* know why but there are
some things to consider:
- while you can use SSE2 for double precision, you can only do 2 operations
on double at once with it
- this means e.g. for the 3D-vector calculations: you save max. 1 out of 3
operation
- memory misalignment: If the memory is not 128-bit aligned it can get slow
(don't know the details here)
Conlusion: The loops that occure with POV-Ray are probably too small to gain
anything from SSE/SSE2 (there may be some exceptions) or the icc doesn't a
well enough job at generationg code for it (actually I think it was icc 6.0
when I tried it) and you would need to optimize it "by hand" (as Intel has
done for the windows binary with the noise calculations (which I failed to
"port" to Intel, that is I used Intel's special source code for the linux
binary but it got slower..)). Also I did not have a pentium4 to experiment
myself at that time. Mabye I'll give it a try once again.
- Micha
POV-Ray Objects Collection: http://objects.povworld.org
Date: 22 May 2003 15:26:23
Message: <3ecd245f@news.povray.org>
Micha Riser wrote:
>>>Pentium4 optimized
>>>icc, no sse2
>>this option?
> operation
> - Micha
I see. Thank you for this binary,
it run really faster than gcc version.
My quick test shows that it is even
a bit faster than standard icl under W2k.
I'll try to get more tests soon(hope).
Gleb
