POV-Ray : Newsgroups : povray.advanced-users : Fractal noise Server Time
9 Jun 2026 19:08:39 EDT (-0400)
  Fractal noise (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Fractal noise
Date: 10 May 2003 13:06:24
Message: <3ebd3190$1@news.povray.org>
The perlin-noise function itself has got nothing to do with fractals
(correct me if I'm wrong :-)
You get something that's called "Fractal Brownian Motion" (FBM) when you
add "turbulence" to the pigment. The POV-Documentation explains how
turbulence works.
-Sascha
Andrew Coppin wrote:
> A fairly good introduction can be found on:
> http://freespace.virgin.net/hugo.elias/models/m_perlin.htm
> Thanks. This was helpful.
> So, essentially, the Perlin noise function is built on a normal random
> function where a point (in whatever dimensionallity of space) is the seed,
> yielding the randomness between distant points. Then interpolation is used
> to make points nearby have similar values. Oh, and the fractal bit - several
> different interpolated random functions of different wavelengths and
> amplitudes are added together for extra "natralness". Is that about how it
> works?
> Andrew.
Date: 10 May 2003 13:56:47
Message: <3EBD3D5F.E6047064@gmx.de>
> turbulence works.
'fBm' stands for 'fractional Brownian motion'.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 11 May 2003 03:18:55
Message: <3ebdf95f@news.povray.org>
You're right, of course.
>>turbulence works.
> Christoph
Date: 12 May 2003 04:19:15
Message: <q7lubvcvspu6h4f1sabho2niej44dcp26q@4ax.com>
On Sat, 10 May 2003 19:06:21 +0200, sascha
I think what "fractal" stands for in this context is that is
inherently self-similar in different scales (to a limited extent
though, unlike "true" fractals)
Peter Popov ICQ : 15002700
Date: 12 May 2003 07:36:13
Message: <3ebf872c@news.povray.org>
  No, the word "fractal" does not imply self-similarity. The origin of
the word is related to mathematical calculations of the dimensions of
a fractal shape, which is fractional in a mathematical sense.
Date: 12 May 2003 12:13:55
Message: <cjameshuff-1A40E6.12140512052003@netplex.aussie.org>
In article <3ebf872c@news.povray.org>, Warp <war### [at] tagpovrayorg>
Actually, it has nothing to do with that. The words "fractal" and
"fraction" have a common root, but "fractal" is more closely related to
"fractured" and "fragment". Mandelbrot coined the word "fractal" from
the Latin "fractus", which means rough, irregular, or broken, and it
does refer to the self-similarity aspect: if you were to break a fractal
into pieces ("fracts"?), each fragment would appear similar to the
others.
Here's a quote from Mandelbrot himself: "I coined fractal from the Latin
adjective fractus. The corresponding Latin verb fragere means 'to
break': to create irregular fragments...how appropriate for our needs!"
http://tag.povray.org/
Date: 12 May 2003 12:20:41
Message: <cjameshuff-EB9197.12204512052003@netplex.aussie.org>
In article <q7lubvcvspu6h4f1sabho2niej44dcp26q@4ax.com>,
Perlin noise is not self-similar at different scales, though. It is
self-similar at one scale only.
Now, things like sum 1/F-noise are fractal. (wrinkles, granite)
http://astronomy.swin.edu.au/~pbourke/texture/perlin/
Date: 12 May 2003 15:13:05
Message: <3ebff241$1@news.povray.org>
Oh no... don't tell me I've inadvertantly started a "what is a fractal" holy
war... *wink*
Andrew.
(Let's just accept that there is no accepted definition ;-)
Date: 12 May 2003 15:19:21
Message: <3ebff3b8@news.povray.org>
  I think that's a wrong statement.
Date: 13 May 2003 05:09:40
Message: <lgd1cvo12ocnacen81jrcu06oltjn72pdr@4ax.com>
On Mon, 12 May 2003 12:20:45 -0400, Christopher James Huff
You're right, of course. Perhaps I should have specified that some of
the patterns in POV that implement Perlin noise use it in 1/F fractal
noise implementations. Nitpick :)
