POV-Ray : Newsgroups : povray.advanced-users : A question of physics Server Time
10 Jun 2026 04:04:41 EDT (-0400)
  A question of physics (Message 7 to 16 of 36)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: A question of physics
Date: 8 May 2003 03:49:40
Message: <3eba0c14$1@news.povray.org>
OK, well, a lump of shashed up ice doesn't look reflective at all... but
take a bit and polish it to give it a nice smooth surface and you find that
it actually IS reflective. Was thinking, if you have a layer of gas, it's
surface probably isn't smooth, which might explain why it doesn't look
reflective.
If that makes sense.
Andrew.
Date: 8 May 2003 03:58:36
Message: <233kbv4bikb70rgnc9k1cso1a1kdqicgh8@4ax.com>
On Thu, 8 May 2003 08:48:09 +0100, "Andrew Coppin" <orp### [at] btinternetcom> wrote:
But I think it is reflective, just with a lot of blur :-)
> reflective.
On desert you can see images in the air. You know how ?
http://www.islandnet.com/~see/weather/graphics/photos/supmirag.gif
ABX
Date: 8 May 2003 06:17:03
Message: <3eba2e9f@news.povray.org>
Andrew <ast### [at] hotmailcom> wrote:
> If something was truly non-reflective,
> it would be perfectly invisible
  A transparent object which refracts light is never invisible.
Date: 8 May 2003 06:34:53
Message: <3EBA32CD.AF03425E@schunter.etc.tu-bs.de>
Andrew Coppin wrote:
> Here's a simple enough question...
> Is it possible for a transparent substance to be non-reflective? Or are all
> transparent substances inherantly reflective to a certain degree?
Reflection is an inherent effect on all interfaces between materials of
different optical density (i.e. ior, speed of light in the material)
The amount of reflection depending on the incident angle and the materials
can be calculated with the fresnel equations.  This works for both a
transit from less dense to more dense medium as well as the other way
round.  More information can be found in the links from:
http://www-public.tu-bs.de:8080/~y0013390/pov/water/water_app1.html#reflect
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 8 May 2003 08:03:38
Message: <3eba479a@news.povray.org>
At school a teacher told us that reflection is caused if the surface is
electroconductive (at the frequency of the light-wave). In that case it
will "short-circuit" the "electric part" of the wave (light is an
electromagnetic-wave) - because the electric and the magnetic vectors
are perpendicular the angle of reflection is equal to the angle of
incidence.
I have got no idea if this is true - could be complete nonsense...
-sascha
> Christoph
Date: 8 May 2003 16:56:25
Message: <3ebac479$1@news.povray.org>
...unless it's an even-thickness slab, viewed exactly square-on *grin*
Andrew.
Date: 8 May 2003 16:58:40
Message: <3ebac500@news.povray.org>
Right. That would seem to explain why no one has ever managed to make
invisible glass for windows yet...
...and once again I'm left saying I'll check it out later... oh to have more
time! lol
Thanks.
Andrew.
Date: 9 May 2003 03:14:33
Message: <j8lmbv06alojocq1n85roto7ud1kudf0gt@4ax.com>
On Thu, 8 May 2003 21:54:54 +0100, "Andrew Coppin"
You'll see the edges and side walls due to perspective unless the side
walls are parallel to the viewing rays, but then again you'll have to
look at it with one eye closed.
Peter Popov ICQ : 15002700
Date: 9 May 2003 11:22:16
Message: <cjameshuff-FE1A25.11221809052003@netplex.aussie.org>
In article <3eb95e52@news.povray.org>,
All known substances are reflective to some degree. (Though neutronium
may be an exception...)
http://tag.povray.org/
Date: 9 May 2003 11:25:42
Message: <cjameshuff-42DB0B.11254409052003@netplex.aussie.org>
In article <3eba0869@news.povray.org>,
> Hmm... gases don't *appear* reflective... but does a gas have a surface???
Mirages. The varying density can cause reflections.
