POV-Ray : Newsgroups : povray.advanced-users : A question of physics Server Time
9 Jun 2026 23:44:32 EDT (-0400)
  A question of physics (Message 27 to 36 of 36)
Subject: Re: A question of physics
Date: 16 May 2003 08:57:32
Message: <3ec4e03b@news.povray.org>
simian <sim### [at] localhostlocaldomain> wrote:
> 	Observable and invisible are different things.
  Right. They are opposite things.
> The hot air over a road is invisible but
> observable by the turbulent distortion.
  It can't be invisible if it's observable. :)
Date: 16 May 2003 09:51:42
Message: <3ec4ecee@news.povray.org>
3eba0869@news.povray.org...
> Hmm... gases don't *appear* reflective... but does a gas have a surface???
The point is IOR variation : on a hot tarmac you can observe air reflecting
the sky  because the temperature of the air film is higher than the ambient
air.
If you have density variation between 2 medias or inside a media, you get
refraction (and reflection if the ior gradient is high enough).
Marc
Date: 16 May 2003 11:15:45
Message: <cjameshuff-8C796B.11161416052003@netplex.aussie.org>
In article <3ec4ecee@news.povray.org>,
> air.
Also, I've read somewhere about the possibility of using high-density
plasma as a mirror. This was in the context of a nuclear-pumped X-ray
laser, where the mirror didn't have to exist for more than a few
microseconds.
I'm not sure about the exact principles behind that one though...since
light interacts through electromagnetic effects, I'm guessing a
highly-ionized plasma will have quite different optical properties
compared to the neutral gas, maybe acting more metallic. One place I
know of this kind of difference is in atmospheric nitrogen lasers...they
lase in the ultraviolet range, but produce very short pulses because the
lasing medium (atmospheric pressure air with a corona discharge through
it) becomes highly opaque to the wavelength being emitted.
And this is all about specular reflection...gases do reflect diffusely,
scattering in other words. For example, our atmosphere scatters blue
wavelengths more than red ones, making the sky appear blue except for at
sunrise and sunset, where you're seeing the wavelengths that weren't
scattered as highly. This effect is enhanced by dust in the air, but I
don't think it depends on it.
http://tag.povray.org/
Date: 16 May 2003 11:43:27
Message: <9l1acvo9rnd6u8ci0pehb6qv6pvguudkla@4ax.com>
On Fri, 16 May 2003 11:16:15 -0400, Christopher James Huff
It's just that the nitrogen molecule scatters blue. Dust can be of any
color, making up for some gorgeous sunsets after a sandstorm (we had
some last month when a heat wave from North Sahara hit us.)
Peter Popov ICQ : 15002700
Date: 16 May 2003 21:32:16
Message: <3ec59120@news.povray.org>
>> The hot air over a road is invisible but observable by the turbulent
>> distortion.
	Assume wise expression and far away look.
	Can you see the wind, Grasshopper?
Date: 16 May 2003 21:39:09
Message: <3ec592bd$1@news.povray.org>
Trees moving back and forth makes the wind blow.
Tim Cook
Version: 3.12
Date: 16 May 2003 21:56:42
Message: <cjameshuff-FA41E4.20571416052003@netplex.aussie.org>
In article <9l1acvo9rnd6u8ci0pehb6qv6pvguudkla@4ax.com>,
Well, dust can be of any colored substance, but particles of the size
that will stay in the atmosphere for any significant amount of time are
small enough that they scatter blue wavelengths more. Similar to the
reasons shorter wavelengths are used for higher magnification microscopy.
Try pouring a little milk into a glass of water and shine a flashlight
through it...depending on the angle you observe it at, the scattered
beam will appear blue or orange.
Date: 17 May 2003 02:13:03
Message: <3ec5d2ef$1@news.povray.org>
On Fri, 16 May 2003 21:39:44 -0400, Tim Cook wrote:
> simian wrote:
>> 	Assume wise expression and far away look. Can you see the wind,
>> 	Grasshopper?
	Is the rippling grass to be ignored because we trample it underfoot?
	Are the clouds to be forgotten because we cannot reach them?
	Is the man off stage with the big fan to be given no credit?
	You have only answers, Grasshopper, should you not be asking questions?
Date: 17 May 2003 03:22:15
Message: <3ec5e30d.231115766@news.povray.org>
You can observe something without seeing it. The meaning of  "observe" is not
the same as the meaning of visible.
Regards
Date: 23 May 2003 06:15:28
Message: <3ecdf4c0@news.povray.org>
"sascha" <sas### [at] userssourceforgenet> wrote in message
news:3eba479a@news.povray.org...
> At school a teacher told us that reflection is caused if the surface is
> electroconductive
Interesting anyway. Seems this discussion is including refraction as being a
part of reflection, then I happened to think about how shallow angles cause
more reflection (Fresnel) and so could easily be thought of as a refractive
effect instead of purely a reflective one. That being to do with air or an
atmospheric effect anyhow. I don't know if this holds true for solid objects
and absolute voids (vacuum of space) or not. Never learned enough from
physics, myself, to know.
But going by what you said there, glancing lightwaves could be electrically
different than ones bouncing directly off of a surface.
