POV-Ray : Newsgroups : povray.advanced-users : Photons Q Server Time
13 Oct 2025 03:57:19 EDT (-0400)
  Photons Q (Message 1 to 5 of 5)
Subject: Photons Q
Date: 30 Apr 2003 12:59:41
Message: <3eb000fd@news.povray.org>
Is it possible to simulate a projected image using photons and radiosity?
My basic scene setup is as follows:
C = Cylinder (Object (ideally) projected)
L = Lens (A curved peice of glass)
B = White box ('Screen')
P = Light Source
                                        PP
                                        PP
CC                                      BB
CC                    LL                BB
CC                    LL                BB
CC                    LL                BB
So far, no luck.
Scene source follows.
global_settings{
        photons{
                count 50000
                        autostop 0
                        jitter .4
        radiosity{
        pretrace_start 0.08
                pretrace_end   0.04
                count 35
                nearest_count 5
                error_bound 1.8
                recursion_limit 3
                low_error_factor 0.5
                gray_threshold 0.0
                minimum_reuse 0.015
                brightness 1
                adc_bailout 0.01/2
                max_trace_level 20
camera{
        location <10,10,-30>
        look_at <0,10,-10>
cylinder{<0,0,-40>,<0,20,-40>,3 pigment{rgb <0,1,0>}
photons{
        reflection on
light_source{<0,100,50>,1
photons{
        refraction on
        reflection on
box{<-50,0,-50>,<50,-1,50> pigment{rgb .2}
photons {collect on}
cylinder{
        <0,5,0>,<0,15,0>,5
        scale <1,1,.25>
texture{
                pigment{
                        rgbf <1,1,1,.97>
        interior{
                ior 1.2
        translate <0,0,-10>
        photons{
                target
                refraction on
                reflection on
                collect off
box{<10,0,10>,<-10,20,11> texture{pigment{rgb 1}} photons{collect on}}
CC                                      BB
Subject: Re: Photons Q
Date: 30 Apr 2003 14:40:44
Message: <cjameshuff-3140F5.14384930042003@netplex.aussie.org>
In article <3eb000fd@news.povray.org>, Tyler Eaves <tyl### [at] cg1org>
Basically, you want to use a lens to focus light reflected from a scene
onto a screen? This is possible in theory, but would be very, very slow.
There's a reason raytracers like POV-Ray primarily follow light
backwards from the camera.
Photons and radiosity do simulate light travelling through the scene,
but the current implementation of photons doesn't simulate diffuse
scattering and you would need insane radiosity settings to get more than
a blurry glow. This is just not the type of thing you want to simulate
fully, your best bet is to do some kind of mock-up. You could render a
view of the scene from what the "camera" would see and use that on a
transparent image map with light shining through it onto the screen,
perhaps using projected_through to get the lighting set up right. In
MegaPOV, I think you could skip the first render stage and use a camera
pigment for the projection filter.
http://tag.povray.org/
Date: 30 Apr 2003 16:15:06
Message: <3eb02ec9$1@news.povray.org>
Okay, darn. I wasn't interested in the "effect" so much as the modeling.
I've been learning some basic optics in my physics class, and wanted to see
if I could model some of it in pov.
Date: 1 May 2003 17:40:06
Message: <web.3eb193f9d01eb52e2a3ff2e70@news.povray.org>
You might be better off modelling a telescope or microscope.  Use focal
blur, that "simulates" your eye.  If the image is blurry, your focal
lengths are off.
I've done it myself, rendering a 4.5 inch reflector telescope, with a 910mm
focal length primary mirror with a diameter of 114mm, and a small 45 degree
inclined secondary mirror, and then I created a 25mm focal length
refracting lens.  Turned on focal blur, and adjusted the position of the
objective lens until I got it to focus.  It was a very satisfying project,
though it took forever to test each rendering.
Date: 20 May 2003 02:00:50
Message: <3ec9c492@news.povray.org>
"Tyler Eaves" <tyl### [at] cg1org> wrote in message
news:3eb000fd@news.povray.org...
I've been able to create a slide projection using photons (not radiosity),
but with strange results.
There are curious artifacts in the projected image.
http://images.walkington.net
Alan
