POV-Ray : Newsgroups : povray.advanced-users : mapping a texture to a height field Server Time
23 Feb 2025 12:39:24 EST (-0500)
  mapping a texture to a height field (Message 1 to 3 of 3)
Subject: mapping a texture to a height field
Date: 27 Apr 2003 10:06:05
Message: <3eabe3cd$1@news.povray.org>
Hi, I have a problem when trying to map a grass texture to a height field.
Basically what I have is your normal height field representing a few hills
and a river bed. But when I go to map a gras texture I made in Paint Shop,
the rendered image comes out with what looks like skewed lines on all the
flat areas of the height field. I was wondering if I had a parameter set
incorrectly or something. After I create the height field, I scale it to
make it larger, could this be causing the problem? If so, is there a way to
work around it? I have pasted the height field code below.
height_field {
  sys
  "height_map.bmp"
 smooth
 pigment { image_map { sys "grass.bmp" once interpolate 2}}
 scale <20, 4, 20>
 translate <-4, 0, 0>
Subject: Re: mapping a texture to a height field
Date: 27 Apr 2003 10:35:02
Message: <3EABEA53.F436E13B@pacbell.net>
> height_field {
>   sys
>   "height_map.bmp"
>  smooth
>  scale <20, 4, 20>
Try adding "rotate -90*x" to the image map statement.
i.e.
height_field {
  sys
  "height_map.bmp"
 smooth
 pigment { image_map { sys "grass.bmp" once interpolate 2} rotate -90*x }
 scale <20, 4, 20>
The HF is created by default on the x+z plane while the image map is created
by default on the x+y plane. Think of an HF as being on the floor while the
image is on the wall.
Ken Tyler
Date: 27 Apr 2003 10:48:34
Message: <3eabedc2@news.povray.org>
Ken, Thanks for the help. I had to rotate it by a +90 as opposed to a -90.
Ben A.
