POV-Ray : Newsgroups : povray.advanced-users : Perfect Antialiasing ??? Server Time
17 May 2026 18:56:00 EDT (-0400)
  Perfect Antialiasing ??? (Message 15 to 24 of 24)
Subject: Re: Perfect Antialiasing ???
Date: 23 Apr 2003 02:38:06
Message: <Pine.GSO.4.53.0304230228300.7720@blastwave>
On Tue, 22 Apr 2003, Christopher James Huff wrote:
>In article <Pine.GSO.4.53.0304221845420.6559@blastwave>,
> Dennis Clarke <dcl### [at] blastwaveorg> wrote:
>>   In what way is antialiasing within a single pixel different from blur of
>>  a single pixel.
>You can't blur a pixel, you need a set of pixels. The algorithm used is
>somewhat similar, but the goal and result are different. Blurring
>removes information from an image, spreading colors out across adjacent
>pixels.
  well .. not really.  If by "blur" we mean the optical result of an image
 being out-of-focus then the data is all there, simply not arranged in a
 fashion that people prefer.  A digital blur of a digital image by way of
 a gaussian ( or similar algorithm ) approach merely distributes the data.
 There are algorithms that will un-blur an image.  These are the same tools
 that are used to unblur the linear movement of a projectile or the rotation
 of an engine component within a photograph.
> Antialiasing adds data, coloring each pixel with the overall
>color of the area it covers instead of a single point within that area,
>and is not dependant on the colors of adjacent pixels.
  ok .. I'm with you on that.  We are talking about using multiple sample
  points within a pixel then, probably distributed as a square matrix of
  samples.  This would be the same then as simply having a higher resolution
  image and then doing a blur of the pixels on a block by block basis while
  ignoring neighbors.  At least that is how I perceive the issue.  The
  removal of jagged edges on lines and sharp boundaries can be achieved with
  either a high resolution image blured or a low-resolution image with a
  multi-sample per pixel approach.
> You can use an
>antialiasing algorithm with a large image as input, but you will get a
>smaller image as a result.
  well yes, that is clear.  It makes no difference whether you sample each
  pixel 9 times ( 3x3 ) within a 100x100 data array or simply blur the 3x3
  pixel blocks of a 300x300 data array to produce a 100x100 result set. I
  think, however, that the result from the latter would be smoother than the
  former.
Dennis
Date: 23 Apr 2003 03:59:07
Message: <jshcavomts2nvma6edrvim84npc3lrvp3o@4ax.com>
On Tue, 22 Apr 2003 19:21:20 +0100, "Andrew Coppin"
<orp### [at] btinternetcom> wrote:
>(From someone who has now MEMORISED the zillion-digit product key for my
>copy of Windows 2000 Advanced Server... what does that tell you???)
That you had to reinstall it so many times you have the number burned
on your retina?
Peter Popov ICQ : 15002700
Date: 23 Apr 2003 04:04:22
Message: <22icav4v4rfsmsaue3rbijffon1g935u3h@4ax.com>
On Tue, 22 Apr 2003 23:04:29 -0400, Christopher James Huff
<cja### [at] earthlinknet> wrote:
>Manually blurring won't help much here, if at all. It really only helps
>with the "nearest neighbor" algorithm, which won't be used by any decent
>graphics program and would be useless for removing aliasing.
Disagreed. Perhaps you're confusing blur with mosaic here? Mosaic does
wonders with nearest neighbor, if you scale down by an integer factor
and use the same number for the mosaic size. Thus you get the exact
same result as +a0.0 +rn, where n is the scale factor.
Gaussian blur helps a lot in most other downsampling algorithms, with
the slight drawback that some careful work with unsharp mask is need
after the resizing to bring out the (now) subpixel details.
Date: 23 Apr 2003 13:54:34
Message: <3ea6d35a$1@news.povray.org>
> on your retina?
BINGO!
Andrew.
Date: 23 Apr 2003 19:52:23
Message: <cjameshuff-C0F4A1.19521923042003@netplex.aussie.org>
In article <22icav4v4rfsmsaue3rbijffon1g935u3h@4ax.com>,
No, I am thinking of blur. (How could I confuse it with mosaiac?!?)
And mosaiac will only "do wonders with nearest neighbor" if it does just
what the resampling algorithm would do anyway. What you suggest here is
equivalent to downsampling with some good algorithm, upsampling back to
the original size with nearest neighbor, and then downsampling again
with nearest neighbor. You also assume mosaiac itself doesn't use
nearest neighbor.
And this can all be handled by the downsampling algorithm itself, in
which case you will just be doing more work than necessary at best, or
get in its way and get inferior results at the worst. A good algorithm
will sample the area around the destination pixel, if the source image
is blurred you will get bleed over in the final image. The resulting
image will be blurrier than it should be.
http://tag.povray.org/
Date: 23 Apr 2003 20:06:31
Message: <cjameshuff-8FCB52.20063123042003@netplex.aussie.org>
In article <Pine.GSO.4.53.0304230228300.7720@blastwave>,
No, the blurred image contains less information. Small details are gone,
geometry and spatial information is lost.
No there aren't, not in the way you seem to be thinking anyway. You've
watched too many Hollywood movies. Information is irretrievably lost in
the blur process, you can not recover the exact original.
This is a bit different...you have information about the motion other
than what is contained in the photo, and can use that to at least
partially reconstruct the original. And then you can't completely
recover the original.
Go ahead and blur a high-res image...you get a blurry high-res image
with no edges, not a smooth-edged one. Antialiasing requires inputting
several samples and outputting one, you have to end up with a smaller
image.
>   former.
You don't get a smaller result set with a blur, you get one of the same
size as the source data. What you are talking about is downsampling.
Date: 24 Apr 2003 11:58:28
Message: <3ea809a4@news.povray.org>
3.1415926535897932384626 IIRC
Date: 24 Apr 2003 12:47:08
Message: <Pine.GSO.4.53.0304241237290.13274@blastwave>
 ha ha .. yes .. more or less .. off the top of my head I recall
  3.14159 26535 89793 23846 26433 83279 50288
 more or less ... I think that I can do at least fifty digits in five
 digit groups .. for no good reason.
 In any case .. perhaps a POV render of Pi related art could be done?
 hmmmmm
 Dennis
Date: 24 Apr 2003 15:38:58
Message: <3ea83d52$1@news.povray.org>
3.1415926535897932384626433832975028841971693993 :-P
Likewise; whenever anyone asks why my memory is so bad, I tell them I
already used it up with pi. (And statments like "the diffusional rate of a
gas is inverstly proportional to the square root of its density" or "a
relation is a subset of the extended Cartesian product of the domains of its
attributes". And the op-code for RTS in 6502 machine code - in hex and
decimal. Man, I need a life...)
I know (or rather, have on file) a rather neat algorithm for calculating
pi... used it to write a program which could find hundreds of digits fairly
fast... hmmm...
Andrew.
Date: 24 Apr 2003 16:41:28
Message: <Pine.GSO.4.53.0304241619100.13841@blastwave>
    I know that you have it in your head ( why? ) but you fingers had minor
    dyslexia !  :)
   oh God!  another math-physics major!
   I used to be able to program 6502 assembly off the top of my head also,
   many years ago.  Back when the Commodore 64 with 64K or RAM was huge!
>fast... hmmm...
  well .. maybe there is a way to do a render in which a really slow method
  of finding pi could be used to do successive image frames of geometric
  objects where the approximation to pi would be used to generate the object
  structures.  After about 100 frames we could have pretty much perfection but
  the initial fifty frames would be akin to a Salvador Dali painting coming
  to life with lots of bent and twisted objects.
  Sound cool?
  The slowest convergence to pi is achieved with a Riemann sum where s=2
  thus :
  zeta(s) = 1 + (1/2)^s + (1/3)^s + (1/4)^s + (1/5)^s + ... + (1/n)^s  where
  n should be inf.  It was Leonhard Euler that discovered in the 1700's that
  zeta(2) converges on the square of pi divided by six. This simple and slow
  fact has been used by me for two decades now to benchmark the floating ops
  of various processors.  The Sun UltraSparc III had an initial NAN problem
  that would induce a massive wait state in the processor.  This has since
  been fixed.  I have a Intel Pentium P90 processor system here with the math
  flaw and it produces the same result on either of its two processors.
  In any case, it would be neat, in a very geeky kind of way, to produce an
  animation of various objects sorting themselves out with various n.
SunOS ag0 5.8 Generic_108528-10 sun4u sparc SUNW,Sun-Fire-280R
$ time -p ./pi
  pi at n=1073741823 is 3.14159264498
real 30.81
user 30.80
sys 0.01
  As you can see from the above, it takes a large n to get any real precision.
 Dennis Clarke
/* Standard PI calculation using an infinite series - Dennis Clarke */
/* Purpose : Calculate pi using the least efficient method known    */
/*           without actually resorting to drawing a circle in the  */
/*           sand and measuring it.                                 */
/*                                   dcl### [at] blastwaveorg          */
#include <locale.h>
#include <stdio.h>
#include <sys/time.h>
#include <math.h>
int main(int argc, char *argv[]) {
     double pi = (double) 0.0;
     unsigned long i;
     /** sum the series 1/(x^2)                          **/
     fprintf ( stdout, "\n\n" );
     for (i = 1; i < 1073741823; i++) {
         pi = pi + (double)1.0/( (double)i * (double)i );
     fprintf(stdout, " pi at n=%9u is %.12g \n", i, sqrt( pi * (double)6.0 ));
     exit(1);
