This question seemed hard enough for the advanced users...
A bit ago I made a robot walker that would walk across flat terrain. I would
figure out which leg was on the ground, look at the angles, and use basic
trig to calculate how far it pushed the robot.
Even though the feet didn't slide, there were a number of problems. These
are listed in order of importance.
1. It couldn't turn.
2. It had to have at least one foot on the ground at all times so it
couldn't run realisticly.
3. It's body could be off center, so that it would fall over in real life.
Now, I want to make a more dynamic model, with non-uniform steps to make it
more realistic. Anything to make it's gait look more natural would help. I
am almose clueless on how to do it myself, so even just ideas would be nice
as well.
Thanks tons,
Fingolfin
In real life, that's just what you're doing when you walk; you're
displacing your centre of gravity, then falling forwards. Of course,
your foot usually stops you from falling completely down, at which
point you repeat the process.
Tim Cook
Version: 3.12
> non-uniform steps to make it more realistic.
> would help. I am almose clueless on how to do
> as well.
Perhaps you can get ideas from these threads:
http://news.povray.org/povray.binaries.animations/19401/
http://news.povray.org/povray.binaries.animations/19441/
http://news.povray.org/povray.binaries.animations/19800/
http://news.povray.org/povray.binaries.animations/19816/
http://news.povray.org/povray.binaries.animations/21006/
http://news.povray.org/povray.binaries.animations/21060/
Rune
rune|vision: http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
Timothy: Good point about the center of gravity. The thing was, it was off
center toward it's back, not it's front, which isn't what really happens...
Rune: Thanks a million for all the links. Aside from making me feel horibly
defficient, they helped a lot.
Fingolfin
Do you have:
i) an incredibly sophisticated input system: a spline plus lots of extra
calculations that you do yourself telling it where to put feet?
or
ii) an incredibly sophisticated number crunching system that figures out
where to put feet based soley on the input from a single spline?
I've admired your work and the ii) option is what I'd like to implement but
haven't figured out how it works (yes, I know you were so kind as to once
provide a commented listing but I'm sorry it was over my head). Perhaps the
job isn't so hard because your input variable is like i).
Greg M. Johnson wrote:
> Do you have:
> a spline plus lots of extra calculations that
> or
> system that figures out where to put feet based
That would be ii). For example, for that spider animation I certainly
didn't want to place all footsteps by hand. :) You can find more
information in the threads I linked to.
> what I'd like to implement but haven't figured
> as to once provide a commented listing but I'm
Well I'm sorry, but explaining everything in detail in an easy
accessible way would require a vast amount of time, and I don't have
that right now. The system *is* rather sophisticated, and not very easy
for me to explain in a short and precise manner.
Rune
