POV-Ray : Newsgroups : povray.advanced-users : bigPatch update Server Time
17 May 2026 18:55:15 EDT (-0400)
  bigPatch update (Message 11 to 13 of 13)
Subject: Re: bigPatch update - 2 attachments
Date: 31 Mar 2003 23:03:43
Message: <Xns93503DEEF4A43torolavkhotmailcom@204.213.191.226>
Ken <tyl### [at] pacbellnet> wrote in news:3E890E1F.946701EB@pacbell.net:
> Tor Olav Kristensen wrote:
>> I have attached two images
>>  [Image]
>>  [Image]
> Um... Tor...
Sorry Ken
Tor Olav
Date: 31 Mar 2003 23:04:30
Message: <Xns93503E1103368torolavkhotmailcom@204.213.191.226>
"Will W" <wil### [at] NOSPAMwizzardsnet> wrote in
news:3e888420@news.povray.org:
> Tor wrote in message
> news:Xns### [at] 204213191226...
>> Will wrote in news:3e8783bc@news.povray.org:
> <snip>
>> I have some ideas on how to define all the
>> control points. It's quite simple, but I'm
>> too tired to explain it right now.
> Looking forward to hearing from you about this!
I thought that
if on are to connect two cubic Bezier curves
smoothly, the "last" control point for the first
curve, the point connecting the curves and the
"first" control point in the last curve must lie
on a line (as written in the docs),
then in order to connect 4 bicubic Bezier
patches smoothly, all the 8 control points around
the point connecting the 4 patches should all lie
in same plane.
I'll post two images to povray.binaries.images
showing how to choose this plane and where to
place the control points.
Tor Olav
Date: 1 Apr 2003 01:56:32
Message: <3e893820@news.povray.org>
Tor Olav wrote in message
> I thought that
That's my understanding as well. The two control vectors must lie on the
tangent to the curve at the data point.
> in same plane.
Which is what I found to be true empirically-- and then realized I should
have been able to reason out from the above statement. Sometimes I do things
the hard way.
> Tor Olav
Nice images, Tor Olav-- thanks very much. bigPatch01_03.jpg does the best
job I've seen of showing how each "control vector" has to parallel the slope
of the line between the neighbors of the data point.
Now the tough question is once you've found the control vector's direction,
how far out should you position the control point along it? Your diagram and
all others I've seen (at this point I think that's every one that google can
find) have all shown the control points to be spaced at one third and two
thirds of the flat distance between two neighbors. But this appears to be
arbitrary; there is nothing I've run across which says it needs to be this
way. Note that in this scheme the control points on the diagonals are about
41% longer than the others-- and this all seems to be due more to ease of
presentation than to any underlying mathematic principles. And of course the
data points themselves don't have to lay on rectangular grid.
bigPatch superimposes both control points on the midpoint between the data
points (though of course the y values will often be quite different). This
seems neither a better nor worse approximation than doing the usual 1/3 and
2/3-- but it is a different approximation. The "ess" curves will be
different. As near as I can tell, getting accurate "ess" curves would
require solving a series of cubic polynomials-- which I expect would be very
slow, and is certainly beyond the effort I'm willing to put into this.
I've used the feedback I've gotten to make a complete revision of the
bigPatch code which I'll send in a separate post as soon as I reveiw the
forum's rules. I think it's short enough I can put it in the message body--
things have compacted down very nicely!
Will Woodhull
Thornhenge, SW Oregon, USA
willl.at.thornhenge.net
