POV-Ray : Newsgroups : povray.advanced-users : Why?... Because!! Server Time
17 May 2026 18:52:58 EDT (-0400)
  Why?... Because!! (Message 12 to 21 of 21)
Subject: Re: Why?... Because!!
Date: 25 Mar 2003 04:17:30
Message: <3E801CBC.70706@nodomain.com>
If you want to create your own CPU on silicon, then you should have a
look at either VHDL or Verilog. This are languages used to design
hardware. You can use Xilinx tools and FPGA technology to realise this.
There are loads of tutorials and on the web and books that teach how to
design a CPU with either VHDL or Verilog. In fact, I think there is a
guy that created a complete NES system with Verilog.
Have a look at http://www.xilinx.com
You are going to find all the information there about their tools and
languages.
Since I was a kid I always wanted to create my own electronic devices.
So I started teaching myself electronics. I also took a course in
Electronics and a degree in computer engineering, which covered all the
electronics I needed to fulfil my dreams. Up until now I have designed
an 8-bit CPU similar to the 6502 using VHDL and FPGA technology, a
couple of alarm systems, music amplifiers, etc.... My next goal will be
to design a hardware based raytracer. I don't really have the time now,
but one day I will.
As for you project, I think it was a good idea to generate the stuff
with povray.
All the best
Fidel.
Date: 25 Mar 2003 04:29:15
Message: <3E801F7D.2060906@nodomain.com>
Rohan Bernett wrote:
> Andrew Coppin wrote:
>>>The obvious next step:  port MAME to SDL.
>>Port whatty?!?
> MAME = Multi Arcade Machine Emulator
> I haven't used it personally, but it's supposed to be really good. I've
> heard there are even ports of it for several consoles.
> Well, here's something even loonier than making an emulator in SDL: Make a
> whole game in it. Just imagine Warcraft III or Duke3d with raytraced
> graphics! Drool drool drool! Pity, no current computer is fast enough to do
> it in real time.
SDL is not a 3D engine nor a drawing API. It is mostly used as an
alternative to directx, but that works on several platforms.
To render 3D stuff, you need OpenGL. I don't know if the Windows version
does support Direct3D as well, but the Mac version, which is the one I
am using, only supports opengl because Direct3D is a Microsoft thing.
As for making the games, I don't quite understand what you are trying to
say. There are loads of games written in SDL. But this are tile based
games. For 3D games they use opengl for the rendering side of it and SDL
is used for the sound, keyboard, joystick, system initialisation, etc...
There is a version of Tron which uses SDL and OpenGL. Just have a look
around the web.
As for MAME it is implemented in SDL (at least the Mac version is).
As for the raytraced thing. There are loads of games that use real-time
raytracing. Have a look on the web and you'll see.
All the best
Fidel.
Date: 25 Mar 2003 04:51:50
Message: <3e8026b6$1@news.povray.org>
SDL as in "Scene Description Language" and not "Simple Device Layer"
(right?).
/Nathan
> All the best
> Fidel.
Date: 25 Mar 2003 04:59:10
Message: <3E802681.5050703@nodomain.com>
> (right?).
Oh, now I got confused. Were you guys talking about povray SDL or SDL
(Simple DirectMedia Layer)?
If it was povray SDL, then what I have said doesn't apply.
All the best
Fidel
PS:There are so many SDL nomenclatures that I get confused.
Date: 25 Mar 2003 15:42:17
Message: <3e80bf29@news.povray.org>
Hey, cool. Thanks - will take a look.
> but one day I will.
Glad I'm not the only crazy person on this earth ;-)
> with povray.
Yeah, building hardware is fun, but software is way more convinient...
Especially for testing!
Date: 25 Mar 2003 19:40:04
Message: <web.3e80f50d528171f8c571aa6c0@news.povray.org>
Patrick Elliott wrote:
>Also, some people have even build arcade cabinets to hold their computers
>and monitors, then wired in the original arcade controls to them.
Yeah. I've seen photos of some impressive cabinents some people have built
in the HotBox section in Atomic. I don't think I could make one myself,
though.
>void main () {
>    call functional_code()
>  else
>    call crash_windows();
Heh Heh Heh. I like it, I like it. :-) Seems quite appropriate to WinME,
judging by the trouble dad had with it until he got rid of the stupid
thing.
Rohan _e_ii
Date: 26 Mar 2003 03:31:46
Message: <3E816383.602@nodomain.com>
I wouldn't say crazy because the CPU I did was an assignment for the
advanced digital design module.
>>with povray.
With VHDL you write your hardware with software. Then there are two ways
of writing programs in VHDL, one is for testing purposes, which works
pretty much like your emulator written in c or c++, but it runs
concurrently and it has got timers, etc... The other program you write
is for the actual generation of the hardware. You create an interface,
which tells how the your device is composed inside and then you write a
behavioural model to test the funcionality of the circuit and once it is
working to your satisfaction, then you write the architecture module
which is where you connect all the circuitry. Once you compile it, your
compiler will generate logic gates interconnected to generate your
circuit. Then you just transfer that to an FPGA IC and that's it. you
are done.
Anyway, keep up with your inventions. Have you got screenshots of your
povray renderings?
All the best
Fidel.
Date: 26 Mar 2003 16:04:05
Message: <3e8215c5@news.povray.org>
Ah... That would make more sense ;-)
Sounds really cool... I gotta check this out... (Oh yeah - I said that
yesterday too, didn't I? I'm a busy person sadly....)
> are done.
So you mean if I buy the right stuff I can actually have running silicon???
(Well, actually it's Germanium these days isn't it? Or is it? I have no idea
really...)
> povray renderings?
I do have images - they're not terribly exciting tho. Will post one in a
sec. Also note that I've got a (unfinished) logic diagram currently on
povray.binaries.images. (Took me hours - I think I'm doing it the hard way!
Will investigate easier methods ;-)
Thanks!
Andrew.
Date: 27 Mar 2003 11:55:11
Message: <3E832AFC.5000005@nodomain.com>
If you are based in London, then try to check this bookcase shops around
I got one on verilog and it comes with the foundation tools. Then you
need to buy the actual programmer device and the appropriate FPGA chip
for you project.
>>are done.
> really...)
Yep, you can have the whole NES system on a single chip. (this includes
the graphics processor or PPU (pixels processing unit) as it is called.)
All the best
Fidel.
Date: 31 Mar 2003 15:58:42
Message: <3e88ac02@news.povray.org>
> for you project.
I'm not based in London, but I can get there ;-) Might be easier to check my
local bookstores tho (or even Amazon).
I now have broadband :-)
[Aren't birthdays wonderful?]
Anyway, on the Xilinx website, you can download a thingy called ISE WebPACK
for free apparently. I don't follow most of the jargon, so I don't know what
it does... I get the impression that this thing will actually allow you to
design stuff - the idea being that you'll then have to pay "real money" for
the equiptment to put it into hardware.
silicon???
You know a lot about this stuff, don't ya? (Oh yeah - you did a course. Ok,
ok, I'm stupid...)
Basically, I know - theoritically - how a logic gate works. I also built
stuff out of 7400 chips (if you happen to know what that means). Actually, a
while back a bought a whole load of them, but suddenly I can't seem to get
them to work properly. (It's been a while.)
Anyway, drifting somewhat off-topic here...
Thanks a lot!
Andrew.
