POV-Ray : Newsgroups : povray.advanced-users : Materials Server Time
17 May 2026 17:35:23 EDT (-0400)
  Materials (Message 1 to 3 of 3)
Subject: Materials
Date: 8 Feb 2003 09:37:49
Message: <3e45163d$1@news.povray.org>
Is there any extensive list of texture attributes for various materials?
I mean is there other way to set attributes (diffuse ambient  specular
roughness brilliance reflection...)
than trying random numbers?:-)
I have some exact material ... like clear diamond, copper, etc.. and I'd
like to know how to set those atributes.
Thanks
Subject: Re: Materials
Date: 8 Feb 2003 10:45:32
Message: <3E45261E.5090609@videotron.ca>
Program ended abnormally on 2/8/03 9:39 AM, Due to a catastrophic
Kosina.Josef error:
> Thanks
Unfortunately, the sites I have bookmarked are usually waaaaaaaaaaaaay
too technical for POV as these values vary with wavelength of the
lightsource used and are hard to isolate experimentally (i.e., one can
not easily separate the amount of light given by "diffuse" from the
amount given by "reflection" or "specular")
This being said,
You can get IOR values for many materials here:
http://www.io.tudelft.nl/research/dfs/idemat/Onl_db/od_frame.htm
And reflectance-by-wavelength values here:
http://speclib.jpl.nasa.gov/Search.htm
This should allow you to find the "diffuse" value of some constrution or
mineral materials, by either averaging the different values given, or if
your lightsource is a specific color, using the proper wavelength value.
But it's usually mostly a trial-and-error process.
Hope this helps.
Date: 10 Feb 2003 18:50:06
Message: <cjameshuff-93F8EA.18470810022003@netplex.aussie.org>
In article <3e45163d$1@news.povray.org>,
Have you looked at the include files that come with POV?
http://tag.povray.org/
