POV-Ray : Newsgroups : povray.advanced-users : Morphing Server Time
29 Sep 2024 12:18:32 EDT (-0400)
  Morphing (Message 1 to 2 of 2)
Subject: Morphing
Date: 21 Jan 2003 14:29:54
Message: <3e2d9fb2@news.povray.org>
Is there a mesh morphing macro anywhere?  I've been using Milkshape 3d with
Poseray to create meshes.  I'd like to be able to morph between different
keyframes in Povray.
Subject: Re: Morphing
Date: 21 Jan 2003 16:02:09
Message: <3e2db550@news.povray.org>
  If the two meshes have the same amount of vertices and triangles and
they are listed in the same order, you can use the PCM macros:
http://www.geocities.com/ccolefax/pcm.html
